When I run SimpleGL I get the following error:
cudaSafeCall() Runtime API error in file <simpleGL.cpp>, line 347 : unknown error.
When I run some of the other examples like deviceQuery or matrixMul, they run with no problem.
Here is some output that may help spot something wrong in my configuration. I am running Ubuntu 8.04 on a Xeon 64 bit processor.
First, output from deviceQuery:
There are 2 devices supporting CUDA
Device 0: “Tesla C1060”
Major revision number: 1
Minor revision number: 3
Total amount of global memory: 4294705152 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: Yes
Device 1: “Quadro FX 570”
Minor revision number: 1
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 2
Number of cores: 16
Total number of registers available per block: 8192
Warp size: 32
Clock rate: 0.92 GHz
Test PASSED
I am not planning to do run any Cuda on the FX 570.
Then some more hopefully useful output:
al@mit:~/Cuda/bin/linux/release$ lspci | grep VGA
03:00.0 VGA compatible controller: nVidia Corporation Quadro FX 570 (rev a1)
al@mit:~/Cuda/bin/linux/release$ glxinfo | grep rendering
direct rendering: Yes
al@mit:~/Cuda/bin/linux/release$ glxinfo | grep NVIDIA
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
OpenGL version string: 2.1.2 NVIDIA 180.06
al@mit:~/Cuda/bin/linux/release$ ldconfig -p | grep cuda
libicudata.so.38 (libc6,x86-64) => /usr/lib/libicudata.so.38
libcudart.so.2 (libc6,x86-64) => /usr/lib/libcudart.so.2
libcuda.so.1 (libc6,x86-64) => /usr/lib/libcuda.so.1
libcuda.so.1 (libc6) => /usr/lib32/libcuda.so.1
libcuda.so (libc6,x86-64) => /usr/lib/libcuda.so
libcuda.so (libc6) => /usr/lib32/libcuda.so
I wondering if maybe there is some library that it can’t find. Perhaps I did something wrong in installing. I couldn’t get LD_LIBRARY_PATH to work, for example, and put a soft link to libcudart.so.2 in /usr/lib. But then maybe this was not such a good idea because perhaps there are other libraries that I don’t know about that it can’t find. I thought I was home free when the make worked, but obviously not.
Also, I am using the Ubuntu generic driver with the FX 570. When I select the Ubuntu system driver option it tells me that the NVIDIA driver is not enabled, and I have left it that way.
Another weird clue is if I comment out the entire function which contains line 347 in SimpleGL and then make and run it, it runs and shows a group of red dots along the x and y axis.
Any help greatly appreciated.
-Al
