error in the clBuildProgram
i , I’m a beginner in OpenCL i got this error message in the build fucntion
Code:
ptxas application ptx input, line 858; error   : Label expected for argument 0 of instruction 'call'
ptxas application ptx input, line 858; error   : Call target not recognized
ptxas application ptx input, line 858; error   : Function 'RGB' not declared in this scope
ptxas application ptx input, line 1722; error   : Label expected for argument 0 of instruction 'call'
ptxas application ptx input, line 1722; error   : Call target not recognized
ptxas application ptx input, line 1722; error   : Function 'RGB' not declared in this scope
ptxas application ptx input, line 859; error   : Unknown symbol 'RGB'
ptxas application ptx input, line 1723; error   : Unknown symbol 'RGB'
ptxas fatal   : Ptx assembly aborted due to errors
error   : Ptx compilation failed: gpu='sm_11', device code='cuModuleLoadDataEx_4'
: Considering profile 'compute_11' for gpu='sm_11' in 'cuModuleLoadDataEx_4'
: Retrieving binary for 'cuModuleLoadDataEx_4', for gpu='sm_11', usage mode='  '
: Control flags for 'cuModuleLoadDataEx_4' disable search path
: Ptx binary found for 'cuModuleLoadDataEx_4', architecture='compute_11'
: Ptx compilation for 'cuModuleLoadDataEx_4', for gpu='sm_11', ocg options='  '
my kernels are as follow
__kernel void
render_vr_cuda_kernel(__global   uint *_image_result, tdst_3d_volume _3d_volume, tdstMatrix _matrix, tdstPlan _plans,int nbr_lignes,__global uchar4 * ColorTex, __global float * OpacityTex,__read_only image3d_t tex, sampler_t samplerA)
{			 //unsigned int i = get_global_id(0);
	uint i =  get_global_id(0);
   uint j =  get_global_id(1) + nbr_lignes;
	//uint j = __umul24(blockIdx.y, blockDim.y) + threadIdx.y + nbr_lignes;
   //   uint i = __umul24(blockIdx.x, blockDim.x) + threadIdx.x;
	//uint j = __umul24(blockIdx.y, blockDim.y) + threadIdx.y;
float II = ((float)_3d_volume.TAILLE_VUE_W * (float)i)/512.0;
   float JJ = ((float)_3d_volume.TAILLE_VUE_W * (float)(j))/512.0;
float3 _FirstPointVolume;
   float3 _LastPointVolume;
int ij = i + _3d_volume.colomns*j;
if(!GetFirstcontact(II,_3d_volume.TAILLE_VUE_W - JJ,_FirstPointVolume,_LastPointVolume,_3d_volume,_matrix, _plans))
	  //_image_result[ij] = 0;
	  //return;
   _image_result[i + _3d_volume.colomns*j] = cuda_rayon_vr_hq_4(_3d_volume,_plans,_FirstPointVolume,_LastPointVolume,Col
orTex,OpacityTex,tex,samplerA);
__kernel void
render_vr_cuda_kernel_2(__global uint *_image_result, tdst_3d_volume _3d_volume, tdstMatrix _matrix, tdstPlan _plans, int nbr_lignes,__global uchar4 * ColorTex, __global float * OpacityTex,__read_only image3d_t tex, sampler_t samplerA)
		  short i =  get_global_id(0) * 2;
		short j =  get_global_id(1) * 2 + nbr_lignes;
   //short i = (__umul24(blockIdx.x, blockDim.x) + threadIdx.x)*2;
	//short j = (__umul24(blockIdx.y, blockDim.y) + threadIdx.y)*2 + nbr_lignes;
	  //return;
   _image_result[i + _3d_volume.colomns*j] = cuda_rayon_vr_hq_2(_3d_volume,_plans,_FirstPointVolume,_LastPointVolume,Col
and other functions
uint cuda_rayon_vr_hq_4(tdst_3d_volume _3d_volume, tdstPlan _plans,float3 _FirstPointVolume,float3 _LastPointVolume,global uchar4 * ColorTex,global float * OpacityTex,image3d_t tex,sampler_t samplerA){.....}
uint cuda_rayon_vr_hq_2(tdst_3d_volume _3d_volume, tdstPlan _plans,float3 _FirstPointVolume,float3 _LastPointVolume,global uchar4 * ColorTex,global float * OpacityTex,image3d_t tex,sampler_t samplerA){.....}
does someone have an idea on how to deal with this??
never mind just a function i didn’t define External Image
