Here is more information about my example projec. Here is my .pro file:
TARGET = TestCUDA
# Define output directories
DESTDIR = release
OBJECTS_DIR = release/obj
CUDA_OBJECTS_DIR = release/cuda
# Source files
SOURCES += main.cpp
# This makes the .cu files appear in your project
# CUDA settings <-- may change depending on your system
CUDA_SOURCES += vectorAddition.cu
CUDA_SDK = "C:/ProgramData/NVIDIA Corporation/CUDA Samples/v8.0" # Path to cuda SDK install
CUDA_DIR = "C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v8.0" # Path to cuda toolkit install
SYSTEM_NAME = Win64 # Depending on your system either 'Win32', 'x64', or 'Win64'
SYSTEM_TYPE = 64 # '32' or '64', depending on your system
CUDA_ARCH = compute_52 # Type of CUDA architecture, for example 'compute_10', 'compute_11', 'sm_10'
NVCC_OPTIONS = --use_fast_math
# include paths
INCLUDEPATH += $$CUDA_DIR/include \
$$CUDA_SDK/common/inc/ \
$$CUDA_SDK/../shared/inc/
# library directories
QMAKE_LIBDIR += $$CUDA_DIR/lib/$$SYSTEM_NAME \
$$CUDA_SDK/common/lib/$$SYSTEM_NAME \
$$CUDA_SDK/../shared/lib/$$SYSTEM_NAME
# Add the necessary libraries
LIBS += -lcuda -lcudart
LIBS += -L\"C:/Program Files (x86)/Windows Kits/10/Lib/10.0.14393.0/um/x86\"
#INCLUDEPATH += "C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/"
INCLUDEPATH += "C:/Program Files (x86)/Windows Kits/10/Include/10.0.10150.0/ucrt"
#INCLUDEPATH += -L"C:/Program Files (x86)/Windows Kits/10/Lib/10.0.14393.0/um/x86"
# The following library conflicts with something in Cuda
#QMAKE_LFLAGS_RELEASE = /NODEFAULTLIB:msvcrt.lib
#QMAKE_LFLAGS_DEBUG = /NODEFAULTLIB:msvcrtd.lib
# The following makes sure all path names (which often include spaces) are put between quotation marks
CUDA_INC = $$join(INCLUDEPATH,'" -I"','-I"','"')
# Configuration of the Cuda compiler
CONFIG(debug, debug|release) {
# Debug mode
cuda_d.input = CUDA_SOURCES
cuda_d.output = ${QMAKE_FILE_BASE}_cuda.o
cuda_d.commands = $$CUDA_DIR/bin/nvcc.exe -D_DEBUG $$NVCC_OPTIONS $$CUDA_INC $$LIBS --machine $$SYSTEM_TYPE -arch=$$CUDA_ARCH -c -o ${QMAKE_FILE_OUT} vectorAddition.cu
cuda_d.dependency_type = TYPE_C
QMAKE_EXTRA_COMPILERS += cuda_d
else {
# Release mode
cuda.input = CUDA_SOURCES
cuda.output = ${QMAKE_FILE_BASE}_cuda.o
cuda.commands = $$CUDA_DIR/bin/nvcc.exe $$NVCC_OPTIONS $$CUDA_INC $$LIBS --machine $$SYSTEM_TYPE -arch=$$CUDA_ARCH -o ${QMAKE_FILE_OUT} ../CudaWindows/vectorAddition.cu
cuda.dependency_type = TYPE_C
My main file:
#include <cuda.h>
#include <builtin_types.h>
#include <drvapi_error_string.h>
#include <QtCore/QCoreApplication>
#include <QDebug>
// Forward declare the function in the .cu file
void vectorAddition(const float* a, const float* b, float* c, int n);
void printArray(const float* a, const unsigned int n) {
QString s = "(";
unsigned int ii;
for (ii = 0; ii < n - 1; ++ii)
s.append(QString::number(a[ii])).append(", ");
s.append(QString::number(a[ii])).append(")");
qDebug() << s;
int main(int argc, char* argv [])
// QCoreApplication(argc, argv);
int deviceCount = 0;
int cudaDevice = 0;
char cudaDeviceName [100];
unsigned int N = 50;
float *a, *b, *c;
cuInit(0);
cuDeviceGetCount(&deviceCount);
cuDeviceGet(&cudaDevice, 0);
cuDeviceGetName(cudaDeviceName, 100, cudaDevice);
qDebug() << "Number of devices: " << deviceCount;
qDebug() << "Device name:" << cudaDeviceName;
a = new float [N]; b = new float [N]; c = new float [N];
for (unsigned int ii = 0; ii < N; ++ii) {
a[ii] = qrand();
b[ii] = qrand();
// This is the function call in which the kernel is called
vectorAddition(a, b, c, N);
// qDebug() << "input a:"; printArray(a, N);
// qDebug() << "input b:"; printArray(b, N);
// qDebug() << "output c:"; printArray(c, N);
if (a) delete a;
if (b) delete b;
if (c) delete c;
And my vectorAddition.cu :
#include <cuda.h>
extern "C"
__global__ void vectorAdditionCUDA(const float* a, const float* b, float* c, int n)
int ii = blockDim.x * blockIdx.x + threadIdx.x;
if (ii < n)
c[ii] = a[ii] + b[ii];
void vectorAddition(const float* a, const float* b, float* c, int n) {
float *a_cuda, *b_cuda, *c_cuda;
unsigned int nBytes = sizeof(float) * n;
int threadsPerBlock = 256;
int blocksPerGrid = (n + threadsPerBlock - 1) / threadsPerBlock;
// allocate and copy memory into the device
cudaMalloc((void **)& a_cuda, nBytes);
cudaMalloc((void **)& b_cuda, nBytes);
cudaMalloc((void **)& c_cuda, nBytes);
cudaMemcpy(a_cuda, a, nBytes, cudaMemcpyHostToDevice);
cudaMemcpy(b_cuda, b, nBytes, cudaMemcpyHostToDevice);
vectorAdditionCUDA<<<blocksPerGrid, threadsPerBlock>>>(a_cuda, b_cuda, c_cuda, n);
// load the answer back into the host
cudaMemcpy(c, c_cuda, nBytes, cudaMemcpyDeviceToHost);
cudaFree(a_cuda);
cudaFree(b_cuda);
cudaFree(c_cuda);
I try have that error:
cudart_static.lib(cuda_runtime_api.obj) : error LNK2005: __cudaUnregisterFatBinary already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(cuda_runtime_api.obj) : error LNK2005: __cudaRegisterFunction already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaSetupArgument already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaMalloc already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaFree already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaMemcpy already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaLaunch already defined in cudart.lib(cudart64_80.dll)
cudart_static.lib(generated_cuda_runtime_api.obj) : error LNK2005: cudaConfigureCall already defined in cudart.lib(cudart64_80.dll)
Creating library vectorAddition_cuda.lib and object vectorAddition_cuda.exp
LINK : fatal error LNK1561: entry point must be defined
I tried to modify links but I try have that error.
