Error installing tensorflow in Xavier AGX
HI,
Getting the below error while installing tensorflow in my Jetson Xavier board.
xxxxx@einfoxavier:~/Desktop/xxxx/mtcnn$ sudo pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow==1.15.2+nv20.4
The directory ‘/home/einfochips/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
The directory ‘/home/einfochips/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Collecting tensorflow==1.15.2+nv20.4
Downloading https://developer.download.nvidia.com/compute/redist/jp/v44/tensorflow/tensorflow-1.15.2+nv20.4-cp36-cp36m-linux_aarch64.whl (233.6MB)
100% |████████████████████████████████| 233.6MB 5.3kB/s
Collecting termcolor>=1.1.0 (from tensorflow==1.15.2+nv20.4)
Exception:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 342, in run
requirement_set.prepare_files(finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 795, in get_page
resp.raise_for_status()
File “/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/models.py”, line 935, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://developer.download.nvidia.com/compute/redist/jp/v44/termcolor/
