When trying to assess the second lesson for this course it would always give me an error message and now it says I completed 100% of the course and my grade is 33% even though I havent completed the course yet. I spent a lot of time understanding the topic and I also spent 80$ how can I fix this?
Course completion and course grade are separate metrics – you can “complete” a course by reviewing all the material in a course, while your grade is based on the assessment of the course. Receiving a passing grade in the course is what is required to receive a certificate.
Ok, but why does it give me an error every time I try to assess my code?
What error are you seeing? If the issue only occurs when you click “Assess task”, that likely means there is a problem in your code that needs to be fixed in order to successfully pass the assessment, in which case I can ask one of our course developers to provide you with assistance.
