Hoping someone can suggest a solution … am trying to build libnvinfer_plugin.so but getting the error " more than one instance of overloaded function "
T4 GPU
deepstream:6.0-triton
TensorRT Version=8.0.1
NVIDIA GPU Driver Version 470.82.01
Compile error. trying to follow the instructions for Build TensorRT OSS Plugin - libnvinfer_plugin.so - the make command produces this error:
“error: more than one instance of overloaded function”
Hello, thank you for your note. Had been building using that material (the README.md) . I used CMake 3.19 and the checkout tag ‘release/8.0’ listed in that table 6.0 GA TRT 8.0.1 release/8.0
when I encountered those build errors which showed up based on one .h file
