@kayccc
[from post could not set the configuration for crtc 394 - #4 by james1122]
I am facing the same issue on my Jetson Nano.
I am using jetpack4.4. Previously with jetpack4.3, I don’t have any such error msg alert.
I don’t see such msg alert on my Jetson NX (jetpack4.4).
Any solution found?
What is needed to trigger this error?
Hi @WayneWWW
I have been testing the stability of Jetson Nano and Jetson NX.
I ran the Yolov4-416 object detection (standalone) with tensorRT framework overnight.
Jetson Nano had this alert message quite consistantly and reboot at adhoc interval (ie sometime 5-6 hrs, sometime 2-3hrs reboot once – still cannot find what is really causing the reboot – suspecting power issue).
Whereas Jetson NX has no such issue. Todate, I have been running the Yolov4 with tensorRT framework for over 36 hrs continuously.
To answer your question directly, to reproduce the alert message, just flash jetpack4.4 and run yolov3 / yolov4 on tensorRT overnight, and you will see the message.
Is it pure jetpack release + nvidia devkit?
Ok. We will try to reproduce it.
During this time, could you also help check your dmesg and see if any error is from kernel?
$ dmesg
[45984.653822] extcon-disp-state extcon:disp-state: cable 47 state 1
[45984.653826] Extcon AUX1(HDMI) enable
[45984.654020] extcon-disp-state extcon:disp-state: cable 51 state 1
[45984.654025] Extcon HDMI: HPD enabled
[45984.654060] tegradc tegradc.0: hdmi: plugged
[45984.673138] tegradc tegradc.0: unblank
[45984.673151] tegradc tegradc.1: blank - powerdown
[46007.202412] extcon-disp-state extcon:disp-state: cable 47 state 0
[46007.202418] Extcon AUX1(HDMI) disable
[46007.227489] tegradc tegradc.0: blank - powerdown
[46007.227664] extcon-disp-state extcon:disp-state: cable 51 state 0
[46007.227669] Extcon HDMI: HPD disabled
[46007.227750] tegradc tegradc.0: hdmi: unplugged
[46007.253916] tegradc tegradc.0: blank - powerdown
[46007.253934] tegradc tegradc.0: unblank
[46007.253984] tegradc tegradc.0: unblank
[46007.253997] tegradc tegradc.1: blank - powerdown
[46007.799298] tegradc tegradc.0: blank - powerdown
[46007.799318] tegradc tegradc.0: unblank
[46007.805594] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46007.805725] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46007.811477] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46007.811489] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46007.850184] extcon-disp-state extcon:disp-state: cable 47 state 1
[46007.850188] Extcon AUX1(HDMI) enable
[46007.850405] extcon-disp-state extcon:disp-state: cable 51 state 1
[46007.850409] Extcon HDMI: HPD enabled
[46007.850455] tegradc tegradc.0: hdmi: plugged
[46007.894819] tegradc tegradc.0: unblank
[46007.894835] tegradc tegradc.1: blank - powerdown
[46025.378423] extcon-disp-state extcon:disp-state: cable 47 state 0
[46025.378428] Extcon AUX1(HDMI) disable
[46025.402272] tegradc tegradc.0: blank - powerdown
[46025.402472] extcon-disp-state extcon:disp-state: cable 51 state 0
[46025.402477] Extcon HDMI: HPD disabled
[46025.402566] tegradc tegradc.0: hdmi: unplugged
[46025.440029] tegradc tegradc.0: blank - powerdown
[46025.440045] tegradc tegradc.0: unblank
[46025.440078] tegradc tegradc.0: unblank
[46025.440091] tegradc tegradc.1: blank - powerdown
[46026.567129] tegradc tegradc.0: blank - powerdown
[46026.567152] tegradc tegradc.0: unblank
[46026.574405] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46026.580366] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46026.581546] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46026.581557] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46026.622206] extcon-disp-state extcon:disp-state: cable 47 state 1
[46026.622211] Extcon AUX1(HDMI) enable
[46026.622464] extcon-disp-state extcon:disp-state: cable 51 state 1
[46026.622469] Extcon HDMI: HPD enabled
[46026.622593] tegradc tegradc.0: hdmi: plugged
[46026.678671] tegradc tegradc.0: unblank
[46026.678684] tegradc tegradc.1: blank - powerdown
[46050.265216] extcon-disp-state extcon:disp-state: cable 47 state 0
[46050.265222] Extcon AUX1(HDMI) disable
[46050.290276] tegradc tegradc.0: blank - powerdown
[46050.290428] extcon-disp-state extcon:disp-state: cable 51 state 0
[46050.290433] Extcon HDMI: HPD disabled
[46050.290865] tegradc tegradc.0: hdmi: unplugged
[46050.320649] tegradc tegradc.0: blank - powerdown
[46050.320668] tegradc tegradc.0: unblank
[46050.320710] tegradc tegradc.0: unblank
[46050.320723] tegradc tegradc.1: blank - powerdown
[46050.862602] tegradc tegradc.0: blank - powerdown
[46050.862622] tegradc tegradc.0: unblank
[46050.873229] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46050.876611] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46050.880130] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46050.880142] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46050.915157] extcon-disp-state extcon:disp-state: cable 47 state 1
[46050.915161] Extcon AUX1(HDMI) enable
[46050.915341] extcon-disp-state extcon:disp-state: cable 51 state 1
[46050.915345] Extcon HDMI: HPD enabled
[46050.915378] tegradc tegradc.0: hdmi: plugged
[46050.989186] tegradc tegradc.0: unblank
[46050.989391] tegradc tegradc.1: blank - powerdown
[46073.913768] extcon-disp-state extcon:disp-state: cable 47 state 0
[46073.913775] Extcon AUX1(HDMI) disable
[46073.934713] tegradc tegradc.0: blank - powerdown
[46073.934817] extcon-disp-state extcon:disp-state: cable 51 state 0
[46073.934822] Extcon HDMI: HPD disabled
[46073.934857] tegradc tegradc.0: hdmi: unplugged
[46073.962581] tegradc tegradc.0: blank - powerdown
[46073.962598] tegradc tegradc.0: unblank
[46073.962635] tegradc tegradc.0: unblank
[46073.962648] tegradc tegradc.1: blank - powerdown
[46074.514962] tegradc tegradc.0: blank - powerdown
[46074.514983] tegradc tegradc.0: unblank
[46074.522121] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46074.526928] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46074.528295] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46074.528306] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46074.568505] extcon-disp-state extcon:disp-state: cable 47 state 1
[46074.568509] Extcon AUX1(HDMI) enable
[46074.579134] extcon-disp-state extcon:disp-state: cable 51 state 1
[46074.579141] Extcon HDMI: HPD enabled
[46074.579270] tegradc tegradc.0: hdmi: plugged
[46074.599470] tegradc tegradc.0: unblank
[46074.599484] tegradc tegradc.1: blank - powerdown
[46103.111954] extcon-disp-state extcon:disp-state: cable 47 state 0
[46103.111961] Extcon AUX1(HDMI) disable
[46103.135539] tegradc tegradc.0: blank - powerdown
[46103.135692] extcon-disp-state extcon:disp-state: cable 51 state 0
[46103.135697] Extcon HDMI: HPD disabled
[46103.135783] tegradc tegradc.0: hdmi: unplugged
[46103.201760] tegradc tegradc.0: blank - powerdown
[46103.201778] tegradc tegradc.0: unblank
[46103.201903] tegradc tegradc.0: unblank
[46103.201916] tegradc tegradc.1: blank - powerdown
[46103.697741] tegradc tegradc.0: blank - powerdown
[46103.697762] tegradc tegradc.0: unblank
[46103.704919] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46103.711241] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46103.712354] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46103.712367] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46103.753840] extcon-disp-state extcon:disp-state: cable 47 state 1
[46103.753844] Extcon AUX1(HDMI) enable
[46103.755200] extcon-disp-state extcon:disp-state: cable 51 state 1
[46103.755205] Extcon HDMI: HPD enabled
[46103.755290] tegradc tegradc.0: hdmi: plugged
[46103.915695] tegradc tegradc.0: unblank
[46103.915901] tegradc tegradc.1: blank - powerdown
[46196.595845] extcon-disp-state extcon:disp-state: cable 47 state 0
[46196.595852] Extcon AUX1(HDMI) disable
[46196.618876] tegradc tegradc.0: blank - powerdown
[46196.619040] extcon-disp-state extcon:disp-state: cable 51 state 0
[46196.619045] Extcon HDMI: HPD disabled
[46196.619180] tegradc tegradc.0: hdmi: unplugged
[46196.664695] tegradc tegradc.0: blank - powerdown
[46196.664712] tegradc tegradc.0: unblank
[46196.664754] tegradc tegradc.0: unblank
[46196.664768] tegradc tegradc.1: blank - powerdown
[46197.192118] tegradc tegradc.0: blank - powerdown
[46197.192141] tegradc tegradc.0: unblank
[46197.198891] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46197.204086] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46197.205545] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46197.205556] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46197.240463] extcon-disp-state extcon:disp-state: cable 47 state 1
[46197.240467] Extcon AUX1(HDMI) enable
[46197.240654] extcon-disp-state extcon:disp-state: cable 51 state 1
[46197.240658] Extcon HDMI: HPD enabled
[46197.240692] tegradc tegradc.0: hdmi: plugged
[46197.292564] tegradc tegradc.0: unblank
[46197.292577] tegradc tegradc.1: blank - powerdown
[46243.905802] extcon-disp-state extcon:disp-state: cable 47 state 0
[46243.905809] Extcon AUX1(HDMI) disable
[46243.931623] tegradc tegradc.0: blank - powerdown
[46243.931792] extcon-disp-state extcon:disp-state: cable 51 state 0
[46243.931797] Extcon HDMI: HPD disabled
[46243.931878] tegradc tegradc.0: hdmi: unplugged
[46243.945368] tegradc tegradc.0: blank - powerdown
[46243.945387] tegradc tegradc.0: unblank
[46243.945429] tegradc tegradc.0: unblank
[46243.945443] tegradc tegradc.1: blank - powerdown
[46245.091703] tegradc tegradc.0: blank - powerdown
[46245.091725] tegradc tegradc.0: unblank
[46245.098053] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46245.098180] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46245.102638] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46245.102651] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46245.144029] extcon-disp-state extcon:disp-state: cable 47 state 1
[46245.144034] Extcon AUX1(HDMI) enable
[46245.144422] extcon-disp-state extcon:disp-state: cable 51 state 1
[46245.144427] Extcon HDMI: HPD enabled
[46245.144513] tegradc tegradc.0: hdmi: plugged
[46245.193153] tegradc tegradc.0: unblank
[46245.193361] tegradc tegradc.1: blank - powerdown
[46290.188857] extcon-disp-state extcon:disp-state: cable 47 state 0
[46290.188876] Extcon AUX1(HDMI) disable
[46290.214713] tegradc tegradc.0: blank - powerdown
[46290.214842] extcon-disp-state extcon:disp-state: cable 51 state 0
[46290.214846] Extcon HDMI: HPD disabled
[46290.214885] tegradc tegradc.0: hdmi: unplugged
[46290.220813] tegradc tegradc.0: blank - powerdown
[46290.220830] tegradc tegradc.0: unblank
[46290.220866] tegradc tegradc.0: unblank
[46290.220879] tegradc tegradc.1: blank - powerdown
[46290.782525] tegradc tegradc.0: blank - powerdown
[46290.782546] tegradc tegradc.0: unblank
[46290.788928] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46290.794439] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46290.795824] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46290.795835] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46290.833812] extcon-disp-state extcon:disp-state: cable 47 state 1
[46290.833815] Extcon AUX1(HDMI) enable
[46290.835056] extcon-disp-state extcon:disp-state: cable 51 state 1
[46290.835061] Extcon HDMI: HPD enabled
[46290.835145] tegradc tegradc.0: hdmi: plugged
[46290.850672] tegradc tegradc.0: unblank
[46290.851160] tegradc tegradc.1: blank - powerdown
[46349.279375] extcon-disp-state extcon:disp-state: cable 47 state 0
[46349.279382] Extcon AUX1(HDMI) disable
[46349.300784] tegradc tegradc.0: blank - powerdown
[46349.300877] extcon-disp-state extcon:disp-state: cable 51 state 0
[46349.300882] Extcon HDMI: HPD disabled
[46349.300974] tegradc tegradc.0: hdmi: unplugged
[46349.313559] tegradc tegradc.0: blank - powerdown
[46349.313576] tegradc tegradc.0: unblank
[46349.313653] tegradc tegradc.0: unblank
[46349.313667] tegradc tegradc.1: blank - powerdown
[46349.865428] tegradc tegradc.0: blank - powerdown
[46349.865449] tegradc tegradc.0: unblank
[46349.872894] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46349.874158] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46349.875288] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46349.875299] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46349.910355] extcon-disp-state extcon:disp-state: cable 47 state 1
[46349.910359] Extcon AUX1(HDMI) enable
[46349.910536] extcon-disp-state extcon:disp-state: cable 51 state 1
[46349.910540] Extcon HDMI: HPD enabled
[46349.910574] tegradc tegradc.0: hdmi: plugged
[46349.931675] tegradc tegradc.0: unblank
[46349.931699] tegradc tegradc.1: blank - powerdown
[46383.575549] extcon-disp-state extcon:disp-state: cable 47 state 0
[46383.575556] Extcon AUX1(HDMI) disable
[46383.600273] tegradc tegradc.0: blank - powerdown
[46383.601092] extcon-disp-state extcon:disp-state: cable 51 state 0
[46383.601098] Extcon HDMI: HPD disabled
[46383.601200] tegradc tegradc.0: hdmi: unplugged
[46383.655098] tegradc tegradc.0: blank - powerdown
[46383.655115] tegradc tegradc.0: unblank
[46383.655147] tegradc tegradc.0: unblank
[46383.655160] tegradc tegradc.1: blank - powerdown
[46384.756874] tegradc tegradc.0: blank - powerdown
[46384.756894] tegradc tegradc.0: unblank
[46384.763487] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46384.764833] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46384.770491] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46384.770503] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46384.807367] extcon-disp-state extcon:disp-state: cable 47 state 1
[46384.807371] Extcon AUX1(HDMI) enable
[46384.807606] extcon-disp-state extcon:disp-state: cable 51 state 1
[46384.807610] Extcon HDMI: HPD enabled
[46384.807648] tegradc tegradc.0: hdmi: plugged
[46384.834883] tegradc tegradc.0: unblank
[46384.834896] tegradc tegradc.1: blank - powerdown
[46415.120759] extcon-disp-state extcon:disp-state: cable 47 state 0
[46415.120765] Extcon AUX1(HDMI) disable
[46415.143890] tegradc tegradc.0: blank - powerdown
[46415.144148] extcon-disp-state extcon:disp-state: cable 51 state 0
[46415.144153] Extcon HDMI: HPD disabled
[46415.144242] tegradc tegradc.0: hdmi: unplugged
[46415.189280] tegradc tegradc.0: blank - powerdown
[46415.189297] tegradc tegradc.0: unblank
[46415.189334] tegradc tegradc.0: unblank
[46415.189347] tegradc tegradc.1: blank - powerdown
[46415.708704] tegradc tegradc.0: blank - powerdown
[46415.708725] tegradc tegradc.0: unblank
[46415.715530] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46415.719469] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46415.720749] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46415.720760] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46415.760982] extcon-disp-state extcon:disp-state: cable 47 state 1
[46415.760986] Extcon AUX1(HDMI) enable
[46415.761239] extcon-disp-state extcon:disp-state: cable 51 state 1
[46415.761244] Extcon HDMI: HPD enabled
[46415.761367] tegradc tegradc.0: hdmi: plugged
[46415.863749] tegradc tegradc.0: unblank
[46415.864014] tegradc tegradc.1: blank - powerdown
[46452.287672] extcon-disp-state extcon:disp-state: cable 47 state 0
[46452.287677] Extcon AUX1(HDMI) disable
[46452.313818] tegradc tegradc.0: blank - powerdown
[46452.313928] extcon-disp-state extcon:disp-state: cable 51 state 0
[46452.313933] Extcon HDMI: HPD disabled
[46452.313975] tegradc tegradc.0: hdmi: unplugged
[46452.344774] tegradc tegradc.0: blank - powerdown
[46452.344792] tegradc tegradc.0: unblank
[46452.344838] tegradc tegradc.0: unblank
[46452.344851] tegradc tegradc.1: blank - powerdown
[46452.884338] tegradc tegradc.0: blank - powerdown
[46452.884357] tegradc tegradc.0: unblank
[46452.890760] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46452.894912] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46452.897165] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46452.897176] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46452.936505] extcon-disp-state extcon:disp-state: cable 47 state 1
[46452.936509] Extcon AUX1(HDMI) enable
[46452.936841] extcon-disp-state extcon:disp-state: cable 51 state 1
[46452.936846] Extcon HDMI: HPD enabled
[46452.936888] tegradc tegradc.0: hdmi: plugged
[46452.987008] tegradc tegradc.0: unblank
[46452.987023] tegradc tegradc.1: blank - powerdown
[46480.030791] extcon-disp-state extcon:disp-state: cable 47 state 0
[46480.030799] Extcon AUX1(HDMI) disable
[46480.055104] tegradc tegradc.0: blank - powerdown
[46480.055242] extcon-disp-state extcon:disp-state: cable 51 state 0
[46480.055247] Extcon HDMI: HPD disabled
[46480.055329] tegradc tegradc.0: hdmi: unplugged
[46480.099234] tegradc tegradc.0: blank - powerdown
[46480.099250] tegradc tegradc.0: unblank
[46480.099344] tegradc tegradc.0: unblank
[46480.099802] tegradc tegradc.1: blank - powerdown
[46480.631087] tegradc tegradc.0: blank - powerdown
[46480.631111] tegradc tegradc.0: unblank
[46480.638108] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46480.643355] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46480.644840] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46480.644850] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46480.681074] extcon-disp-state extcon:disp-state: cable 47 state 1
[46480.681078] Extcon AUX1(HDMI) enable
[46480.683600] extcon-disp-state extcon:disp-state: cable 51 state 1
[46480.683605] Extcon HDMI: HPD enabled
[46480.683647] tegradc tegradc.0: hdmi: plugged
[46480.737392] tegradc tegradc.0: unblank
[46480.737405] tegradc tegradc.1: blank - powerdown
[46573.128310] extcon-disp-state extcon:disp-state: cable 47 state 0
[46573.128316] Extcon AUX1(HDMI) disable
[46573.154057] tegradc tegradc.0: blank - powerdown
[46573.154319] extcon-disp-state extcon:disp-state: cable 51 state 0
[46573.154324] Extcon HDMI: HPD disabled
[46573.154414] tegradc tegradc.0: hdmi: unplugged
[46573.188130] tegradc tegradc.0: blank - powerdown
[46573.188148] tegradc tegradc.0: unblank
[46573.188188] tegradc tegradc.0: unblank
[46573.188201] tegradc tegradc.1: blank - powerdown
[46573.709610] tegradc tegradc.0: blank - powerdown
[46573.709630] tegradc tegradc.0: unblank
[46573.715945] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46573.716082] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46573.726307] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46573.726326] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46573.761357] extcon-disp-state extcon:disp-state: cable 47 state 1
[46573.761360] Extcon AUX1(HDMI) enable
[46573.761552] extcon-disp-state extcon:disp-state: cable 51 state 1
[46573.761557] Extcon HDMI: HPD enabled
[46573.761591] tegradc tegradc.0: hdmi: plugged
[46573.781039] tegradc tegradc.0: unblank
[46573.781053] tegradc tegradc.1: blank - powerdown
[46593.693318] extcon-disp-state extcon:disp-state: cable 47 state 0
[46593.693324] Extcon AUX1(HDMI) disable
[46593.717323] tegradc tegradc.0: blank - powerdown
[46593.717545] extcon-disp-state extcon:disp-state: cable 51 state 0
[46593.717550] Extcon HDMI: HPD disabled
[46593.717644] tegradc tegradc.0: hdmi: unplugged
[46593.735395] tegradc tegradc.0: blank - powerdown
[46593.735413] tegradc tegradc.0: unblank
[46593.735453] tegradc tegradc.0: unblank
[46593.735466] tegradc tegradc.1: blank - powerdown
[46594.293548] tegradc tegradc.0: blank - powerdown
[46594.293573] tegradc tegradc.0: unblank
[46594.300839] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46594.303961] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46594.305708] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46594.305721] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46594.341356] extcon-disp-state extcon:disp-state: cable 47 state 1
[46594.341360] Extcon AUX1(HDMI) enable
[46594.341684] extcon-disp-state extcon:disp-state: cable 51 state 1
[46594.341689] Extcon HDMI: HPD enabled
[46594.341779] tegradc tegradc.0: hdmi: plugged
[46594.375670] tegradc tegradc.0: unblank
[46594.375874] tegradc tegradc.1: blank - powerdown
[46669.572526] extcon-disp-state extcon:disp-state: cable 47 state 0
[46669.572531] Extcon AUX1(HDMI) disable
[46669.597088] tegradc tegradc.0: blank - powerdown
[46669.598406] extcon-disp-state extcon:disp-state: cable 51 state 0
[46669.598412] Extcon HDMI: HPD disabled
[46669.598527] tegradc tegradc.0: hdmi: unplugged
[46669.620913] tegradc tegradc.0: blank - powerdown
[46669.620930] tegradc tegradc.0: unblank
[46669.620968] tegradc tegradc.0: unblank
[46669.620981] tegradc tegradc.1: blank - powerdown
[46670.768297] tegradc tegradc.0: blank - powerdown
[46670.768319] tegradc tegradc.0: unblank
[46670.775481] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46670.781135] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46670.782373] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46670.782385] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46670.820873] extcon-disp-state extcon:disp-state: cable 47 state 1
[46670.820877] Extcon AUX1(HDMI) enable
[46670.822132] extcon-disp-state extcon:disp-state: cable 51 state 1
[46670.822137] Extcon HDMI: HPD enabled
[46670.822222] tegradc tegradc.0: hdmi: plugged
[46670.897073] tegradc tegradc.0: unblank
[46670.897088] tegradc tegradc.1: blank - powerdown
[46694.266146] extcon-disp-state extcon:disp-state: cable 47 state 0
[46694.266152] Extcon AUX1(HDMI) disable
[46694.291478] tegradc tegradc.0: blank - powerdown
[46694.291628] extcon-disp-state extcon:disp-state: cable 51 state 0
[46694.291633] Extcon HDMI: HPD disabled
[46694.291717] tegradc tegradc.0: hdmi: unplugged
[46694.339190] tegradc tegradc.0: blank - powerdown
[46694.339208] tegradc tegradc.0: unblank
[46694.339245] tegradc tegradc.0: unblank
[46694.339258] tegradc tegradc.1: blank - powerdown
[46694.847526] tegradc tegradc.0: blank - powerdown
[46694.847547] tegradc tegradc.0: unblank
[46694.853825] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46694.860526] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46694.861645] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46694.861659] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46694.902321] extcon-disp-state extcon:disp-state: cable 47 state 1
[46694.902325] Extcon AUX1(HDMI) enable
[46694.902543] extcon-disp-state extcon:disp-state: cable 51 state 1
[46694.902547] Extcon HDMI: HPD enabled
[46694.902582] tegradc tegradc.0: hdmi: plugged
[46695.086947] tegradc tegradc.0: unblank
[46695.087149] tegradc tegradc.1: blank - powerdown
[46767.061845] extcon-disp-state extcon:disp-state: cable 47 state 0
[46767.061851] Extcon AUX1(HDMI) disable
[46767.086797] tegradc tegradc.0: blank - powerdown
[46767.086981] extcon-disp-state extcon:disp-state: cable 51 state 0
[46767.086986] Extcon HDMI: HPD disabled
[46767.087077] tegradc tegradc.0: hdmi: unplugged
[46767.115102] tegradc tegradc.0: blank - powerdown
[46767.115122] tegradc tegradc.0: unblank
[46767.115154] tegradc tegradc.0: unblank
[46767.115167] tegradc tegradc.1: blank - powerdown
[46768.242603] tegradc tegradc.0: blank - powerdown
[46768.242625] tegradc tegradc.0: unblank
[46768.249255] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46768.251415] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46768.252968] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46768.252979] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46768.289743] extcon-disp-state extcon:disp-state: cable 47 state 1
[46768.289747] Extcon AUX1(HDMI) enable
[46768.294214] extcon-disp-state extcon:disp-state: cable 51 state 1
[46768.294219] Extcon HDMI: HPD enabled
[46768.294321] tegradc tegradc.0: hdmi: plugged
[46768.338041] tegradc tegradc.0: unblank
[46768.338056] tegradc tegradc.1: blank - powerdown
[46863.620269] extcon-disp-state extcon:disp-state: cable 47 state 0
[46863.620275] Extcon AUX1(HDMI) disable
[46863.643736] tegradc tegradc.0: blank - powerdown
[46863.643887] extcon-disp-state extcon:disp-state: cable 51 state 0
[46863.643892] Extcon HDMI: HPD disabled
[46863.643977] tegradc tegradc.0: hdmi: unplugged
[46863.683395] tegradc tegradc.0: blank - powerdown
[46863.683412] tegradc tegradc.0: unblank
[46863.683454] tegradc tegradc.0: unblank
[46863.683467] tegradc tegradc.1: blank - powerdown
[46864.229008] tegra_edid_read_block **: checksum failed and did not match consecutive reads. Previous remainder was 1. New remainder is 112. Failed at attempt 1**
[46864.254281] i2c i2c-3: clk rate 50000 not supported
[46864.264457] **Could not change i2c_ddc sclk rate**
[46864.276918] **Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read**
[46864.381292] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[46864.418177] tegra_i2c_handle_xfer_error **: 3 callbacks suppressed**
[46864.418185] tegra-i2c 7000c700.i2c **: no acknowledge from address 0x30**
[46864.521208] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[46864.639774] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[46864.703309] tegradc tegradc.0: blank - powerdown
[46864.703330] tegradc tegradc.0: unblank
[46864.703436] extcon-disp-state extcon:disp-state: cable 51 state 1
[46864.703442] Extcon HDMI: HPD enabled
[46864.703481] tegradc tegradc.0: hdmi: plugged
[46864.703536] extcon-disp-state extcon:disp-state: cable 51 state 0
[46864.703540] Extcon HDMI: HPD disabled
[46864.706436] tegradc tegradc.0: hdmi: unplugged
[46864.719370] tegradc tegradc.0: blank - powerdown
[46864.719398] tegradc tegradc.0: unblank
[46864.719437] tegradc tegradc.0: unblank
[46864.719450] tegradc tegradc.1: blank - powerdown
[46864.763513] tegradc tegradc.0: blank - powerdown
[46864.763531] tegradc tegradc.0: unblank
[46864.763567] tegradc tegradc.0: unblank
[46864.763580] tegradc tegradc.1: blank - powerdown
[46864.976856] tegradc tegradc.0: blank - powerdown
[46864.976877] tegradc tegradc.0: unblank
[46864.983092] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46864.985071] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46864.989221] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46864.989245] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46865.028383] extcon-disp-state extcon:disp-state: cable 47 state 1
[46865.028386] Extcon AUX1(HDMI) enable
[46865.028723] extcon-disp-state extcon:disp-state: cable 51 state 1
[46865.028728] Extcon HDMI: HPD enabled
[46865.028859] tegradc tegradc.0: hdmi: plugged
[46865.097954] tegradc tegradc.0: unblank
[46865.098155] tegradc tegradc.1: blank - powerdown
[46876.989604] extcon-disp-state extcon:disp-state: cable 47 state 0
[46876.989609] Extcon AUX1(HDMI) disable
[46877.015940] tegradc tegradc.0: blank - powerdown
[46877.016132] extcon-disp-state extcon:disp-state: cable 51 state 0
[46877.016137] Extcon HDMI: HPD disabled
[46877.016228] tegradc tegradc.0: hdmi: unplugged
[46877.028070] tegradc tegradc.0: blank - powerdown
[46877.028087] tegradc tegradc.0: unblank
[46877.028122] tegradc tegradc.0: unblank
[46877.028135] tegradc tegradc.1: blank - powerdown
[46877.584562] tegradc tegradc.0: blank - powerdown
[46877.584584] tegradc tegradc.0: unblank
[46877.591892] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46877.593665] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46877.597358] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46877.597372] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46877.634157] extcon-disp-state extcon:disp-state: cable 47 state 1
[46877.634161] Extcon AUX1(HDMI) enable
[46877.634336] extcon-disp-state extcon:disp-state: cable 51 state 1
[46877.634340] Extcon HDMI: HPD enabled
[46877.634376] tegradc tegradc.0: hdmi: plugged
[46877.667818] tegradc tegradc.0: unblank
[46877.667832] tegradc tegradc.1: blank - powerdown
[46933.780938] extcon-disp-state extcon:disp-state: cable 47 state 0
[46933.780945] Extcon AUX1(HDMI) disable
[46933.807631] tegradc tegradc.0: blank - powerdown
[46933.807766] extcon-disp-state extcon:disp-state: cable 51 state 0
[46933.807771] Extcon HDMI: HPD disabled
[46933.807811] tegradc tegradc.0: hdmi: unplugged
[46933.824025] tegradc tegradc.0: blank - powerdown
[46933.824043] tegradc tegradc.0: unblank
[46933.824080] tegradc tegradc.0: unblank
[46933.824093] tegradc tegradc.1: blank - powerdown
[46934.943592] tegradc tegradc.0: blank - powerdown
[46934.943613] tegradc tegradc.0: unblank
[46934.950290] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46934.950505] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46934.954472] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46934.954483] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46934.995351] extcon-disp-state extcon:disp-state: cable 47 state 1
[46934.995354] Extcon AUX1(HDMI) enable
[46935.001702] extcon-disp-state extcon:disp-state: cable 51 state 1
[46935.001709] Extcon HDMI: HPD enabled
[46935.001850] tegradc tegradc.0: hdmi: plugged
[46935.061358] tegradc tegradc.0: unblank
[46935.061372] tegradc tegradc.1: blank - powerdown
[46974.621551] extcon-disp-state extcon:disp-state: cable 47 state 0
[46974.621557] Extcon AUX1(HDMI) disable
[46974.646916] tegradc tegradc.0: blank - powerdown
[46974.647111] extcon-disp-state extcon:disp-state: cable 51 state 0
[46974.647116] Extcon HDMI: HPD disabled
[46974.647179] tegradc tegradc.0: hdmi: unplugged
[46974.717262] tegradc tegradc.0: blank - powerdown
[46974.717281] tegradc tegradc.0: unblank
[46974.717320] tegradc tegradc.0: unblank
[46974.717334] tegradc tegradc.1: blank - powerdown
[46975.214813] tegradc tegradc.0: blank - powerdown
[46975.214833] tegradc tegradc.0: unblank
[46975.221146] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[46975.228081] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[46975.231427] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[46975.231439] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[46975.267971] extcon-disp-state extcon:disp-state: cable 47 state 1
[46975.267977] Extcon AUX1(HDMI) enable
[46975.269634] extcon-disp-state extcon:disp-state: cable 51 state 1
[46975.269639] Extcon HDMI: HPD enabled
[46975.269745] tegradc tegradc.0: hdmi: plugged
[46975.319685] tegradc tegradc.0: unblank
[46975.319701] tegradc tegradc.1: blank - powerdown
[47068.014830] extcon-disp-state extcon:disp-state: cable 47 state 0
[47068.014836] Extcon AUX1(HDMI) disable
[47068.037170] tegradc tegradc.0: blank - powerdown
[47068.037464] extcon-disp-state extcon:disp-state: cable 51 state 0
[47068.037469] Extcon HDMI: HPD disabled
[47068.037563] tegradc tegradc.0: hdmi: unplugged
[47068.097577] tegradc tegradc.0: blank - powerdown
[47068.097595] tegradc tegradc.0: unblank
[47068.097636] tegradc tegradc.0: unblank
[47068.097648] tegradc tegradc.1: blank - powerdown
[47069.189666] tegradc tegradc.0: blank - powerdown
[47069.189688] tegradc tegradc.0: unblank
[47069.199326] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47069.206342] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47069.207439] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47069.207451] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47069.243862] extcon-disp-state extcon:disp-state: cable 47 state 1
[47069.243867] Extcon AUX1(HDMI) enable
[47069.245640] extcon-disp-state extcon:disp-state: cable 51 state 1
[47069.245645] Extcon HDMI: HPD enabled
[47069.245730] tegradc tegradc.0: hdmi: plugged
[47069.297787] tegradc tegradc.0: unblank
[47069.297800] tegradc tegradc.1: blank - powerdown
[47084.614079] extcon-disp-state extcon:disp-state: cable 47 state 0
[47084.614085] Extcon AUX1(HDMI) disable
[47084.631791] tegradc tegradc.0: blank - powerdown
[47084.631911] extcon-disp-state extcon:disp-state: cable 51 state 0
[47084.631915] Extcon HDMI: HPD disabled
[47084.632017] tegradc tegradc.0: hdmi: unplugged
[47084.638939] tegradc tegradc.0: blank - powerdown
[47084.638957] tegradc tegradc.0: unblank
[47084.638990] tegradc tegradc.0: unblank
[47084.639003] tegradc tegradc.1: blank - powerdown
[47085.212877] tegra_edid_read_block **: checksum failed and did not match consecutive reads. Previous remainder was 132. New remainder is 29. Failed at attempt 1**
[47085.229002] i2c i2c-3: clk rate 50000 not supported
[47085.236105] **Could not change i2c_ddc sclk rate**
[47085.244050] **Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read**
[47085.342126] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47085.375784] tegra_i2c_handle_xfer_error **: 2 callbacks suppressed**
[47085.375794] tegra-i2c 7000c700.i2c **: no acknowledge from address 0x30**
[47085.479428] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47085.594504] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47085.661187] tegradc tegradc.0: blank - powerdown
[47085.661209] tegradc tegradc.0: unblank
[47085.661330] extcon-disp-state extcon:disp-state: cable 51 state 1
[47085.661335] Extcon HDMI: HPD enabled
[47085.661374] tegradc tegradc.0: hdmi: plugged
[47085.661433] extcon-disp-state extcon:disp-state: cable 51 state 0
[47085.661437] Extcon HDMI: HPD disabled
[47085.661471] tegradc tegradc.0: hdmi: unplugged
[47085.676235] tegradc tegradc.0: blank - powerdown
[47085.676264] tegradc tegradc.0: unblank
[47085.676303] tegradc tegradc.0: unblank
[47085.676315] tegradc tegradc.1: blank - powerdown
[47085.715646] tegradc tegradc.0: blank - powerdown
[47085.715665] tegradc tegradc.0: unblank
[47085.715701] tegradc tegradc.0: unblank
[47085.715713] tegradc tegradc.1: blank - powerdown
[47085.956895] tegradc tegradc.0: blank - powerdown
[47085.956916] tegradc tegradc.0: unblank
[47085.963642] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47085.968425] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47085.969813] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47085.969823] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47086.005756] extcon-disp-state extcon:disp-state: cable 47 state 1
[47086.005760] Extcon AUX1(HDMI) enable
[47086.007278] extcon-disp-state extcon:disp-state: cable 51 state 1
[47086.007283] Extcon HDMI: HPD enabled
[47086.007379] tegradc tegradc.0: hdmi: plugged
[47086.030178] tegradc tegradc.0: unblank
[47086.030192] tegradc tegradc.1: blank - powerdown
[47160.469966] extcon-disp-state extcon:disp-state: cable 47 state 0
[47160.469972] Extcon AUX1(HDMI) disable
[47160.494751] tegradc tegradc.0: blank - powerdown
[47160.494921] extcon-disp-state extcon:disp-state: cable 51 state 0
[47160.494926] Extcon HDMI: HPD disabled
[47160.495035] tegradc tegradc.0: hdmi: unplugged
[47160.529696] tegradc tegradc.0: blank - powerdown
[47160.529714] tegradc tegradc.0: unblank
[47160.529750] tegradc tegradc.0: unblank
[47160.529763] tegradc tegradc.1: blank - powerdown
[47161.067473] tegradc tegradc.0: blank - powerdown
[47161.067496] tegradc tegradc.0: unblank
[47161.074134] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47161.074332] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47161.078100] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47161.078112] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47161.118740] extcon-disp-state extcon:disp-state: cable 47 state 1
[47161.118744] Extcon AUX1(HDMI) enable
[47161.119043] extcon-disp-state extcon:disp-state: cable 51 state 1
[47161.119047] Extcon HDMI: HPD enabled
[47161.119129] tegradc tegradc.0: hdmi: plugged
[47161.145561] tegradc tegradc.0: unblank
[47161.146074] tegradc tegradc.1: blank - powerdown
[47224.495808] extcon-disp-state extcon:disp-state: cable 47 state 0
[47224.495814] Extcon AUX1(HDMI) disable
[47224.522357] tegradc tegradc.0: blank - powerdown
[47224.522487] extcon-disp-state extcon:disp-state: cable 51 state 0
[47224.522492] Extcon HDMI: HPD disabled
[47224.522529] tegradc tegradc.0: hdmi: unplugged
[47224.543875] tegradc tegradc.0: blank - powerdown
[47224.543893] tegradc tegradc.0: unblank
[47224.543933] tegradc tegradc.0: unblank
[47224.543946] tegradc tegradc.1: blank - powerdown
[47225.070339] tegradc tegradc.0: blank - powerdown
[47225.070360] tegradc tegradc.0: unblank
[47225.076662] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47225.076786] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47225.082617] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47225.082629] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47225.118595] extcon-disp-state extcon:disp-state: cable 47 state 1
[47225.118598] Extcon AUX1(HDMI) enable
[47225.120298] extcon-disp-state extcon:disp-state: cable 51 state 1
[47225.120303] Extcon HDMI: HPD enabled
[47225.125386] tegradc tegradc.0: hdmi: plugged
[47225.249789] tegradc tegradc.0: unblank
[47225.249802] tegradc tegradc.1: blank - powerdown
[47308.132818] extcon-disp-state extcon:disp-state: cable 47 state 0
[47308.132825] Extcon AUX1(HDMI) disable
[47308.159283] tegradc tegradc.0: blank - powerdown
[47308.159394] extcon-disp-state extcon:disp-state: cable 51 state 0
[47308.159399] Extcon HDMI: HPD disabled
[47308.159442] tegradc tegradc.0: hdmi: unplugged
[47308.187693] tegradc tegradc.0: blank - powerdown
[47308.187750] tegradc tegradc.0: unblank
[47308.187787] tegradc tegradc.0: unblank
[47308.187800] tegradc tegradc.1: blank - powerdown
[47308.724548] tegradc tegradc.0: blank - powerdown
[47308.724569] tegradc tegradc.0: unblank
[47308.731427] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47308.737019] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47308.738267] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47308.738278] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47308.777565] extcon-disp-state extcon:disp-state: cable 47 state 1
[47308.777569] Extcon AUX1(HDMI) enable
[47308.780979] extcon-disp-state extcon:disp-state: cable 51 state 1
[47308.780984] Extcon HDMI: HPD enabled
[47308.781065] tegradc tegradc.0: hdmi: plugged
[47308.810027] tegradc tegradc.0: unblank
[47308.810524] tegradc tegradc.1: blank - powerdown
[47323.705244] extcon-disp-state extcon:disp-state: cable 47 state 0
[47323.705250] Extcon AUX1(HDMI) disable
[47323.728065] tegradc tegradc.0: blank - powerdown
[47323.728716] extcon-disp-state extcon:disp-state: cable 51 state 0
[47323.728722] Extcon HDMI: HPD disabled
[47323.728865] tegradc tegradc.0: hdmi: unplugged
[47323.739228] tegradc tegradc.0: blank - powerdown
[47323.739247] tegradc tegradc.0: unblank
[47323.739295] tegradc tegradc.0: unblank
[47323.739310] tegradc tegradc.1: blank - powerdown
[47324.300280] tegradc tegradc.0: blank - powerdown
[47324.300303] tegradc tegradc.0: unblank
[47324.307201] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47324.312743] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47324.313833] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47324.313843] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47324.350222] extcon-disp-state extcon:disp-state: cable 47 state 1
[47324.350226] Extcon AUX1(HDMI) enable
[47324.352619] extcon-disp-state extcon:disp-state: cable 51 state 1
[47324.352623] Extcon HDMI: HPD enabled
[47324.352703] tegradc tegradc.0: hdmi: plugged
[47324.400483] tegradc tegradc.0: unblank
[47324.400497] tegradc tegradc.1: blank - powerdown
[47411.663980] extcon-disp-state extcon:disp-state: cable 47 state 0
[47411.663986] Extcon AUX1(HDMI) disable
[47411.687243] tegradc tegradc.0: blank - powerdown
[47411.687491] extcon-disp-state extcon:disp-state: cable 51 state 0
[47411.687496] Extcon HDMI: HPD disabled
[47411.688959] tegradc tegradc.0: hdmi: unplugged
[47411.794382] tegradc tegradc.0: blank - powerdown
[47411.794399] tegradc tegradc.0: unblank
[47411.794435] tegradc tegradc.0: unblank
[47411.794448] tegradc tegradc.1: blank - powerdown
[47412.842584] tegradc tegradc.0: blank - powerdown
[47412.842604] tegradc tegradc.0: unblank
[47412.849663] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47412.849871] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47412.855005] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47412.855017] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47412.894769] extcon-disp-state extcon:disp-state: cable 47 state 1
[47412.894772] Extcon AUX1(HDMI) enable
[47412.895101] extcon-disp-state extcon:disp-state: cable 51 state 1
[47412.895105] Extcon HDMI: HPD enabled
[47412.895185] tegradc tegradc.0: hdmi: plugged
[47412.933137] tegradc tegradc.0: unblank
[47412.933161] tegradc tegradc.1: blank - powerdown
[47507.505143] extcon-disp-state extcon:disp-state: cable 47 state 0
[47507.505151] Extcon AUX1(HDMI) disable
[47507.530452] tegradc tegradc.0: blank - powerdown
[47507.530613] extcon-disp-state extcon:disp-state: cable 51 state 0
[47507.530618] Extcon HDMI: HPD disabled
[47507.530701] tegradc tegradc.0: hdmi: unplugged
[47507.568481] tegradc tegradc.0: blank - powerdown
[47507.568499] tegradc tegradc.0: unblank
[47507.568541] tegradc tegradc.0: unblank
[47507.568555] tegradc tegradc.1: blank - powerdown
[47508.100552] tegradc tegradc.0: blank - powerdown
[47508.100571] tegradc tegradc.0: unblank
[47508.107678] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47508.113050] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47508.114127] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47508.114137] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47508.149286] extcon-disp-state extcon:disp-state: cable 47 state 1
[47508.149290] Extcon AUX1(HDMI) enable
[47508.149480] extcon-disp-state extcon:disp-state: cable 51 state 1
[47508.149484] Extcon HDMI: HPD enabled
[47508.149518] tegradc tegradc.0: hdmi: plugged
[47508.189837] tegradc tegradc.0: unblank
[47508.191356] tegradc tegradc.1: blank - powerdown
[47536.797735] extcon-disp-state extcon:disp-state: cable 47 state 0
[47536.797741] Extcon AUX1(HDMI) disable
[47536.824006] tegradc tegradc.0: blank - powerdown
[47536.824169] extcon-disp-state extcon:disp-state: cable 51 state 0
[47536.824174] Extcon HDMI: HPD disabled
[47536.824255] tegradc tegradc.0: hdmi: unplugged
[47536.854506] tegradc tegradc.0: blank - powerdown
[47536.854524] tegradc tegradc.0: unblank
[47536.854560] tegradc tegradc.0: unblank
[47536.854573] tegradc tegradc.1: blank - powerdown
[47537.988235] tegradc tegradc.0: blank - powerdown
[47537.988257] tegradc tegradc.0: unblank
[47537.994822] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47537.994967] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47538.001324] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47538.001335] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47538.037473] extcon-disp-state extcon:disp-state: cable 47 state 1
[47538.037478] Extcon AUX1(HDMI) enable
[47538.039753] extcon-disp-state extcon:disp-state: cable 51 state 1
[47538.039759] Extcon HDMI: HPD enabled
[47538.039849] tegradc tegradc.0: hdmi: plugged
[47538.054861] tegradc tegradc.0: unblank
[47538.057152] tegradc tegradc.1: blank - powerdown
[47550.001631] extcon-disp-state extcon:disp-state: cable 47 state 0
[47550.001638] Extcon AUX1(HDMI) disable
[47550.024313] tegradc tegradc.0: blank - powerdown
[47550.024483] extcon-disp-state extcon:disp-state: cable 51 state 0
[47550.024488] Extcon HDMI: HPD disabled
[47550.024575] tegradc tegradc.0: hdmi: unplugged
[47550.111594] tegradc tegradc.0: blank - powerdown
[47550.111611] tegradc tegradc.0: unblank
[47550.111651] tegradc tegradc.0: unblank
[47550.111664] tegradc tegradc.1: blank - powerdown
[47550.595667] tegra_i2c_handle_xfer_error **: 2 callbacks suppressed**
[47550.595676] tegra-i2c 7000c700.i2c **: no acknowledge from address 0x50**
[47550.704462] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47550.824095] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47550.944758] tegra_edid_read_block **: remainder is 218 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 202**
[47551.032224] tegra_edid_read_block **: checksum failed and did not match consecutive reads. Previous remainder was 218. New remainder is 37. Failed at attempt 2**
[47551.046354] i2c i2c-3: clk rate 50000 not supported
[47551.051537] **Could not change i2c_ddc sclk rate**
[47551.056849] **Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read**
[47551.104000] tegradc tegradc.0: blank - powerdown
[47551.104024] tegradc tegradc.0: unblank
[47551.104507] extcon-disp-state extcon:disp-state: cable 51 state 1
[47551.104512] Extcon HDMI: HPD enabled
[47551.104547] tegradc tegradc.0: hdmi: plugged
[47551.104602] extcon-disp-state extcon:disp-state: cable 51 state 0
[47551.104606] Extcon HDMI: HPD disabled
[47551.104637] tegradc tegradc.0: hdmi: unplugged
[47551.140351] tegradc tegradc.0: blank - powerdown
[47551.140380] tegradc tegradc.0: unblank
[47551.140415] tegradc tegradc.0: unblank
[47551.140428] tegradc tegradc.1: blank - powerdown
[47551.171392] tegradc tegradc.0: blank - powerdown
[47551.171409] tegradc tegradc.0: unblank
[47551.171444] tegradc tegradc.0: unblank
[47551.171457] tegradc tegradc.1: blank - powerdown
[47551.356210] tegradc tegradc.0: blank - powerdown
[47551.356233] tegradc tegradc.0: unblank
[47551.364603] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47551.365983] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47551.368548] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47551.368560] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47551.409546] extcon-disp-state extcon:disp-state: cable 47 state 1
[47551.409550] Extcon AUX1(HDMI) enable
[47551.409761] extcon-disp-state extcon:disp-state: cable 51 state 1
[47551.409765] Extcon HDMI: HPD enabled
[47551.409802] tegradc tegradc.0: hdmi: plugged
[47551.498372] tegradc tegradc.0: unblank
[47551.498387] tegradc tegradc.1: blank - powerdown
[47585.018817] extcon-disp-state extcon:disp-state: cable 47 state 0
[47585.018824] Extcon AUX1(HDMI) disable
[47585.045474] tegradc tegradc.0: blank - powerdown
[47585.045622] extcon-disp-state extcon:disp-state: cable 51 state 0
[47585.045627] Extcon HDMI: HPD disabled
[47585.045715] tegradc tegradc.0: hdmi: unplugged
[47585.074512] tegradc tegradc.0: blank - powerdown
[47585.074530] tegradc tegradc.0: unblank
[47585.074565] tegradc tegradc.0: unblank
[47585.074578] tegradc tegradc.1: blank - powerdown
[47585.619447] tegradc tegradc.0: blank - powerdown
[47585.619470] tegradc tegradc.0: unblank
[47585.625888] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47585.631598] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47585.636389] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47585.636402] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47585.677726] extcon-disp-state extcon:disp-state: cable 47 state 1
[47585.677730] Extcon AUX1(HDMI) enable
[47585.678028] extcon-disp-state extcon:disp-state: cable 51 state 1
[47585.678033] Extcon HDMI: HPD enabled
[47585.678084] tegradc tegradc.0: hdmi: plugged
[47585.761452] tegradc tegradc.0: unblank
[47585.761826] tegradc tegradc.1: blank - powerdown
[47618.919986] extcon-disp-state extcon:disp-state: cable 47 state 0
[47618.919994] Extcon AUX1(HDMI) disable
[47618.946645] tegradc tegradc.0: blank - powerdown
[47618.946747] extcon-disp-state extcon:disp-state: cable 51 state 0
[47618.946751] Extcon HDMI: HPD disabled
[47618.946841] tegradc tegradc.0: hdmi: unplugged
[47618.979478] tegradc tegradc.0: blank - powerdown
[47618.979495] tegradc tegradc.0: unblank
[47618.979531] tegradc tegradc.0: unblank
[47618.979543] tegradc tegradc.1: blank - powerdown
[47619.506688] tegradc tegradc.0: blank - powerdown
[47619.506710] tegradc tegradc.0: unblank
[47619.513397] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47619.516830] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47619.519826] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47619.519837] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47619.554932] extcon-disp-state extcon:disp-state: cable 47 state 1
[47619.555003] Extcon AUX1(HDMI) enable
[47619.555498] extcon-disp-state extcon:disp-state: cable 51 state 1
[47619.555503] Extcon HDMI: HPD enabled
[47619.555588] tegradc tegradc.0: hdmi: plugged
[47619.610882] tegradc tegradc.0: unblank
[47619.611059] tegradc tegradc.1: blank - powerdown
[47635.303456] extcon-disp-state extcon:disp-state: cable 47 state 0
[47635.303461] Extcon AUX1(HDMI) disable
[47635.325073] tegradc tegradc.0: blank - powerdown
[47635.330685] extcon-disp-state extcon:disp-state: cable 51 state 0
[47635.330691] Extcon HDMI: HPD disabled
[47635.330776] tegradc tegradc.0: hdmi: unplugged
[47635.350910] tegradc tegradc.0: blank - powerdown
[47635.350928] tegradc tegradc.0: unblank
[47635.350970] tegradc tegradc.0: unblank
[47635.350983] tegradc tegradc.1: blank - powerdown
[47635.890927] tegradc tegradc.0: blank - powerdown
[47635.891008] tegradc tegradc.0: unblank
[47635.901849] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47635.907646] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47635.909399] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47635.909410] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47635.944636] extcon-disp-state extcon:disp-state: cable 47 state 1
[47635.944640] Extcon AUX1(HDMI) enable
[47635.944948] extcon-disp-state extcon:disp-state: cable 51 state 1
[47635.944954] Extcon HDMI: HPD enabled
[47635.944989] tegradc tegradc.0: hdmi: plugged
[47636.026446] tegradc tegradc.0: unblank
[47636.027118] tegradc tegradc.1: blank - powerdown
[47651.376454] extcon-disp-state extcon:disp-state: cable 47 state 0
[47651.376460] Extcon AUX1(HDMI) disable
[47651.399520] tegradc tegradc.0: blank - powerdown
[47651.399671] extcon-disp-state extcon:disp-state: cable 51 state 0
[47651.399676] Extcon HDMI: HPD disabled
[47651.399759] tegradc tegradc.0: hdmi: unplugged
[47651.416478] tegradc tegradc.0: blank - powerdown
[47651.416496] tegradc tegradc.0: unblank
[47651.416545] tegradc tegradc.0: unblank
[47651.416558] tegradc tegradc.1: blank - powerdown
[47651.971260] tegradc tegradc.0: blank - powerdown
[47651.971279] tegradc tegradc.0: unblank
[47651.981420] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47651.986156] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47651.987654] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47651.987708] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47652.023247] extcon-disp-state extcon:disp-state: cable 47 state 1
[47652.023250] Extcon AUX1(HDMI) enable
[47652.025652] extcon-disp-state extcon:disp-state: cable 51 state 1
[47652.025658] Extcon HDMI: HPD enabled
[47652.025749] tegradc tegradc.0: hdmi: plugged
[47652.072873] tegradc tegradc.0: unblank
[47652.072888] tegradc tegradc.1: blank - powerdown
[47683.421655] extcon-disp-state extcon:disp-state: cable 47 state 0
[47683.421660] Extcon AUX1(HDMI) disable
[47683.450101] tegradc tegradc.0: blank - powerdown
[47683.450275] extcon-disp-state extcon:disp-state: cable 51 state 0
[47683.450280] Extcon HDMI: HPD disabled
[47683.450364] tegradc tegradc.0: hdmi: unplugged
[47683.460032] tegradc tegradc.0: blank - powerdown
[47683.460049] tegradc tegradc.0: unblank
[47683.460083] tegradc tegradc.0: unblank
[47683.460096] tegradc tegradc.1: blank - powerdown
[47684.017364] tegradc tegradc.0: blank - powerdown
[47684.017386] tegradc tegradc.0: unblank
[47684.023937] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47684.028711] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47684.029793] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47684.029803] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47684.073026] extcon-disp-state extcon:disp-state: cable 47 state 1
[47684.073030] Extcon AUX1(HDMI) enable
[47684.073218] extcon-disp-state extcon:disp-state: cable 51 state 1
[47684.073223] Extcon HDMI: HPD enabled
[47684.073257] tegradc tegradc.0: hdmi: plugged
[47684.134699] tegradc tegradc.0: unblank
[47684.134713] tegradc tegradc.1: blank - powerdown
[47734.530001] extcon-disp-state extcon:disp-state: cable 47 state 0
[47734.530007] Extcon AUX1(HDMI) disable
[47734.551067] tegradc tegradc.0: blank - powerdown
[47734.551226] extcon-disp-state extcon:disp-state: cable 51 state 0
[47734.551231] Extcon HDMI: HPD disabled
[47734.551321] tegradc tegradc.0: hdmi: unplugged
[47734.564308] tegradc tegradc.0: blank - powerdown
[47734.564325] tegradc tegradc.0: unblank
[47734.564361] tegradc tegradc.0: unblank
[47734.564373] tegradc tegradc.1: blank - powerdown
[47735.120614] tegradc tegradc.0: blank - powerdown
[47735.120635] tegradc tegradc.0: unblank
[47735.131013] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47735.132311] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47735.136982] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47735.136993] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47735.173277] extcon-disp-state extcon:disp-state: cable 47 state 1
[47735.173314] Extcon AUX1(HDMI) enable
[47735.176868] extcon-disp-state extcon:disp-state: cable 51 state 1
[47735.176874] Extcon HDMI: HPD enabled
[47735.176972] tegradc tegradc.0: hdmi: plugged
[47735.222553] tegradc tegradc.0: unblank
[47735.222567] tegradc tegradc.1: blank - powerdown
[47759.503864] extcon-disp-state extcon:disp-state: cable 47 state 0
[47759.503876] Extcon AUX1(HDMI) disable
[47759.525671] tegradc tegradc.0: blank - powerdown
[47759.532270] extcon-disp-state extcon:disp-state: cable 51 state 0
[47759.532277] Extcon HDMI: HPD disabled
[47759.532393] tegradc tegradc.0: hdmi: unplugged
[47759.535925] tegradc tegradc.0: blank - powerdown
[47759.535942] tegradc tegradc.0: unblank
[47759.535980] tegradc tegradc.0: unblank
[47759.535993] tegradc tegradc.1: blank - powerdown
[47760.100308] tegradc tegradc.0: blank - powerdown
[47760.100329] tegradc tegradc.0: unblank
[47760.107035] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47760.109559] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47760.110645] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47760.110656] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47760.149052] extcon-disp-state extcon:disp-state: cable 47 state 1
[47760.149056] Extcon AUX1(HDMI) enable
[47760.151303] extcon-disp-state extcon:disp-state: cable 51 state 1
[47760.151310] Extcon HDMI: HPD enabled
[47760.151348] tegradc tegradc.0: hdmi: plugged
[47760.209681] tegradc tegradc.0: unblank
[47760.209704] tegradc tegradc.1: blank - powerdown
[47776.194284] extcon-disp-state extcon:disp-state: cable 47 state 0
[47776.194290] Extcon AUX1(HDMI) disable
[47776.219364] tegradc tegradc.0: blank - powerdown
[47776.219565] extcon-disp-state extcon:disp-state: cable 51 state 0
[47776.219570] Extcon HDMI: HPD disabled
[47776.219655] tegradc tegradc.0: hdmi: unplugged
[47776.259393] tegradc tegradc.0: blank - powerdown
[47776.259411] tegradc tegradc.0: unblank
[47776.259446] tegradc tegradc.0: unblank
[47776.259459] tegradc tegradc.1: blank - powerdown
[47776.791829] tegradc tegradc.0: blank - powerdown
[47776.791852] tegradc tegradc.0: unblank
[47776.798289] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47776.800013] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47776.801123] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47776.801135] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47776.841742] extcon-disp-state extcon:disp-state: cable 47 state 1
[47776.841747] Extcon AUX1(HDMI) enable
[47776.841973] extcon-disp-state extcon:disp-state: cable 51 state 1
[47776.841978] Extcon HDMI: HPD enabled
[47776.842060] tegradc tegradc.0: hdmi: plugged
[47776.983238] tegradc tegradc.0: unblank
[47776.983252] tegradc tegradc.1: blank - powerdown
[47808.351487] extcon-disp-state extcon:disp-state: cable 47 state 0
[47808.351493] Extcon AUX1(HDMI) disable
[47808.373716] tegradc tegradc.0: blank - powerdown
[47808.373900] extcon-disp-state extcon:disp-state: cable 51 state 0
[47808.373905] Extcon HDMI: HPD disabled
[47808.374018] tegradc tegradc.0: hdmi: unplugged
[47808.416352] tegradc tegradc.0: blank - powerdown
[47808.416370] tegradc tegradc.0: unblank
[47808.416409] tegradc tegradc.0: unblank
[47808.416422] tegradc tegradc.1: blank - powerdown
[47808.947918] tegradc tegradc.0: blank - powerdown
[47808.947940] tegradc tegradc.0: unblank
[47808.954931] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47808.960351] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47808.962813] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47808.962825] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47808.998331] extcon-disp-state extcon:disp-state: cable 47 state 1
[47808.998335] Extcon AUX1(HDMI) enable
[47808.998638] extcon-disp-state extcon:disp-state: cable 51 state 1
[47808.998643] Extcon HDMI: HPD enabled
[47808.998728] tegradc tegradc.0: hdmi: plugged
[47809.027275] tegradc tegradc.0: unblank
[47809.027289] tegradc tegradc.1: blank - powerdown
[47860.796374] extcon-disp-state extcon:disp-state: cable 47 state 0
[47860.796379] Extcon AUX1(HDMI) disable
[47860.817823] tegradc tegradc.0: blank - powerdown
[47860.817986] extcon-disp-state extcon:disp-state: cable 51 state 0
[47860.817991] Extcon HDMI: HPD disabled
[47860.818077] tegradc tegradc.0: hdmi: unplugged
[47860.926239] tegradc tegradc.0: blank - powerdown
[47860.926257] tegradc tegradc.0: unblank
[47860.926291] tegradc tegradc.0: unblank
[47860.926304] tegradc tegradc.1: blank - powerdown
[47861.382510] tegradc tegradc.0: blank - powerdown
[47861.382539] tegradc tegradc.0: unblank
[47861.397914] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47861.404874] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47861.405965] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47861.405976] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47861.446447] extcon-disp-state extcon:disp-state: cable 47 state 1
[47861.446451] Extcon AUX1(HDMI) enable
[47861.446699] extcon-disp-state extcon:disp-state: cable 51 state 1
[47861.446703] Extcon HDMI: HPD enabled
[47861.446746] tegradc tegradc.0: hdmi: plugged
[47861.473646] tegradc tegradc.0: unblank
[47861.473660] tegradc tegradc.1: blank - powerdown
[47877.072997] extcon-disp-state extcon:disp-state: cable 47 state 0
[47877.073001] Extcon AUX1(HDMI) disable
[47877.096956] tegradc tegradc.0: blank - powerdown
[47877.097400] extcon-disp-state extcon:disp-state: cable 51 state 0
[47877.097405] Extcon HDMI: HPD disabled
[47877.097574] tegradc tegradc.0: hdmi: unplugged
[47877.116687] tegradc tegradc.0: blank - powerdown
[47877.116704] tegradc tegradc.0: unblank
[47877.116736] tegradc tegradc.0: unblank
[47877.116749] tegradc tegradc.1: blank - powerdown
[47877.658629] tegradc tegradc.0: blank - powerdown
[47877.658648] tegradc tegradc.0: unblank
[47877.665428] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47877.669672] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47877.671116] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47877.671128] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47877.709306] extcon-disp-state extcon:disp-state: cable 47 state 1
[47877.709310] Extcon AUX1(HDMI) enable
[47877.709792] extcon-disp-state extcon:disp-state: cable 51 state 1
[47877.709798] Extcon HDMI: HPD enabled
[47877.709854] tegradc tegradc.0: hdmi: plugged
[47877.746550] tegradc tegradc.0: unblank
[47877.746658] tegradc tegradc.1: blank - powerdown
[47893.038119] extcon-disp-state extcon:disp-state: cable 47 state 0
[47893.038125] Extcon AUX1(HDMI) disable
[47893.061310] tegradc tegradc.0: blank - powerdown
[47893.061495] extcon-disp-state extcon:disp-state: cable 51 state 0
[47893.061501] Extcon HDMI: HPD disabled
[47893.061594] tegradc tegradc.0: hdmi: unplugged
[47893.086142] tegradc tegradc.0: blank - powerdown
[47893.086159] tegradc tegradc.0: unblank
[47893.086199] tegradc tegradc.0: unblank
[47893.086212] tegradc tegradc.1: blank - powerdown
[47893.629560] tegradc tegradc.0: blank - powerdown
[47893.629581] tegradc tegradc.0: unblank
[47893.639932] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47893.644399] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47893.647171] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47893.647226] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47893.682690] extcon-disp-state extcon:disp-state: cable 47 state 1
[47893.682693] Extcon AUX1(HDMI) enable
[47893.683058] extcon-disp-state extcon:disp-state: cable 51 state 1
[47893.683063] Extcon HDMI: HPD enabled
[47893.683151] tegradc tegradc.0: hdmi: plugged
[47893.700313] tegradc tegradc.0: unblank
[47893.700339] tegradc tegradc.1: blank - powerdown
[47905.064339] extcon-disp-state extcon:disp-state: cable 47 state 0
[47905.064345] Extcon AUX1(HDMI) disable
[47905.087741] tegradc tegradc.0: blank - powerdown
[47905.087917] extcon-disp-state extcon:disp-state: cable 51 state 0
[47905.087922] Extcon HDMI: HPD disabled
[47905.088012] tegradc tegradc.0: hdmi: unplugged
[47905.111004] tegradc tegradc.0: blank - powerdown
[47905.111022] tegradc tegradc.0: unblank
[47905.111058] tegradc tegradc.0: unblank
[47905.111071] tegradc tegradc.1: blank - powerdown
[47905.649378] tegradc tegradc.0: blank - powerdown
[47905.649397] tegradc tegradc.0: unblank
[47905.656275] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47905.661950] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47905.663057] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47905.663068] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47905.706339] extcon-disp-state extcon:disp-state: cable 47 state 1
[47905.706343] Extcon AUX1(HDMI) enable
[47905.707578] extcon-disp-state extcon:disp-state: cable 51 state 1
[47905.707584] Extcon HDMI: HPD enabled
[47905.707667] tegradc tegradc.0: hdmi: plugged
[47905.724606] tegradc tegradc.0: unblank
[47905.724619] tegradc tegradc.1: blank - powerdown
[47925.196685] extcon-disp-state extcon:disp-state: cable 47 state 0
[47925.196691] Extcon AUX1(HDMI) disable
[47925.219644] tegradc tegradc.0: blank - powerdown
[47925.219806] extcon-disp-state extcon:disp-state: cable 51 state 0
[47925.219811] Extcon HDMI: HPD disabled
[47925.219906] tegradc tegradc.0: hdmi: unplugged
[47925.240252] tegradc tegradc.0: blank - powerdown
[47925.240269] tegradc tegradc.0: unblank
[47925.240306] tegradc tegradc.0: unblank
[47925.240319] tegradc tegradc.1: blank - powerdown
[47926.369375] tegradc tegradc.0: blank - powerdown
[47926.369396] tegradc tegradc.0: unblank
[47926.376052] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47926.381471] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47926.382572] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47926.382583] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47926.422814] extcon-disp-state extcon:disp-state: cable 47 state 1
[47926.422818] Extcon AUX1(HDMI) enable
[47926.423054] extcon-disp-state extcon:disp-state: cable 51 state 1
[47926.423058] Extcon HDMI: HPD enabled
[47926.423108] tegradc tegradc.0: hdmi: plugged
[47926.442407] tegradc tegradc.0: unblank
[47926.445375] tegradc tegradc.1: blank - powerdown
[47987.866159] extcon-disp-state extcon:disp-state: cable 47 state 0
[47987.866166] Extcon AUX1(HDMI) disable
[47987.887886] tegradc tegradc.0: blank - powerdown
[47987.888087] extcon-disp-state extcon:disp-state: cable 51 state 0
[47987.888144] Extcon HDMI: HPD disabled
[47987.888231] tegradc tegradc.0: hdmi: unplugged
[47987.917071] tegradc tegradc.0: blank - powerdown
[47987.917088] tegradc tegradc.0: unblank
[47987.917123] tegradc tegradc.0: unblank
[47987.917136] tegradc tegradc.1: blank - powerdown
[47988.456007] tegradc tegradc.0: blank - powerdown
[47988.456031] tegradc tegradc.0: unblank
[47988.462374] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[47988.464321] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[47988.466467] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[47988.466479] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[47988.502608] extcon-disp-state extcon:disp-state: cable 47 state 1
[47988.502612] Extcon AUX1(HDMI) enable
[47988.502818] extcon-disp-state extcon:disp-state: cable 51 state 1
[47988.502823] Extcon HDMI: HPD enabled
[47988.502856] tegradc tegradc.0: hdmi: plugged
[47988.560142] tegradc tegradc.0: unblank
[47988.560166] tegradc tegradc.1: blank - powerdown
[48004.350121] extcon-disp-state extcon:disp-state: cable 47 state 0
[48004.350128] Extcon AUX1(HDMI) disable
[48004.372415] tegradc tegradc.0: blank - powerdown
[48004.372792] extcon-disp-state extcon:disp-state: cable 51 state 0
[48004.372797] Extcon HDMI: HPD disabled
[48004.374211] tegradc tegradc.0: hdmi: unplugged
[48004.417249] tegradc tegradc.0: blank - powerdown
[48004.417268] tegradc tegradc.0: unblank
[48004.417306] tegradc tegradc.0: unblank
[48004.417320] tegradc tegradc.1: blank - powerdown
[48005.527718] tegradc tegradc.0: blank - powerdown
[48005.527738] tegradc tegradc.0: unblank
[48005.534240] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48005.535587] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48005.538506] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48005.538518] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48005.573474] extcon-disp-state extcon:disp-state: cable 47 state 1
[48005.573478] Extcon AUX1(HDMI) enable
[48005.573761] extcon-disp-state extcon:disp-state: cable 51 state 1
[48005.573765] Extcon HDMI: HPD enabled
[48005.573845] tegradc tegradc.0: hdmi: plugged
[48005.646605] tegradc tegradc.0: unblank
[48005.646619] tegradc tegradc.1: blank - powerdown
[48020.322144] extcon-disp-state extcon:disp-state: cable 47 state 0
[48020.322150] Extcon AUX1(HDMI) disable
[48020.347196] tegradc tegradc.0: blank - powerdown
[48020.347349] extcon-disp-state extcon:disp-state: cable 51 state 0
[48020.347353] Extcon HDMI: HPD disabled
[48020.347437] tegradc tegradc.0: hdmi: unplugged
[48020.371415] tegradc tegradc.0: blank - powerdown
[48020.371434] tegradc tegradc.0: unblank
[48020.371476] tegradc tegradc.0: unblank
[48020.371490] tegradc tegradc.1: blank - powerdown
[48020.911397] tegradc tegradc.0: blank - powerdown
[48020.911419] tegradc tegradc.0: unblank
[48020.917758] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48020.923668] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48020.925327] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48020.925338] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48020.963668] extcon-disp-state extcon:disp-state: cable 47 state 1
[48020.963672] Extcon AUX1(HDMI) enable
[48020.964706] extcon-disp-state extcon:disp-state: cable 51 state 1
[48020.964711] Extcon HDMI: HPD enabled
[48020.964820] tegradc tegradc.0: hdmi: plugged
[48020.994101] tegradc tegradc.0: unblank
[48020.994375] tegradc tegradc.1: blank - powerdown
[48052.381612] extcon-disp-state extcon:disp-state: cable 47 state 0
[48052.381618] Extcon AUX1(HDMI) disable
[48052.401116] tegradc tegradc.0: blank - powerdown
[48052.401323] extcon-disp-state extcon:disp-state: cable 51 state 0
[48052.401328] Extcon HDMI: HPD disabled
[48052.401438] tegradc tegradc.0: hdmi: unplugged
[48052.441656] tegradc tegradc.0: blank - powerdown
[48052.441674] tegradc tegradc.0: unblank
[48052.441710] tegradc tegradc.0: unblank
[48052.441723] tegradc tegradc.1: blank - powerdown
[48052.962873] tegradc tegradc.0: blank - powerdown
[48052.962894] tegradc tegradc.0: unblank
[48052.969184] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48052.971095] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48052.975444] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48052.975455] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48053.015945] extcon-disp-state extcon:disp-state: cable 47 state 1
[48053.015948] Extcon AUX1(HDMI) enable
[48053.016161] extcon-disp-state extcon:disp-state: cable 51 state 1
[48053.016165] Extcon HDMI: HPD enabled
[48053.016201] tegradc tegradc.0: hdmi: plugged
[48053.069772] tegradc tegradc.0: unblank
[48053.069786] tegradc tegradc.1: blank - powerdown
[48085.042450] extcon-disp-state extcon:disp-state: cable 47 state 0
[48085.042457] Extcon AUX1(HDMI) disable
[48085.068412] tegradc tegradc.0: blank - powerdown
[48085.069074] extcon-disp-state extcon:disp-state: cable 51 state 0
[48085.069079] Extcon HDMI: HPD disabled
[48085.069190] tegradc tegradc.0: hdmi: unplugged
[48085.077490] tegradc tegradc.0: blank - powerdown
[48085.077507] tegradc tegradc.0: unblank
[48085.077549] tegradc tegradc.0: unblank
[48085.077562] tegradc tegradc.1: blank - powerdown
[48085.626083] tegradc tegradc.0: blank - powerdown
[48085.626103] tegradc tegradc.0: unblank
[48085.635832] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48085.642245] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48085.646007] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48085.646018] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48085.686251] extcon-disp-state extcon:disp-state: cable 47 state 1
[48085.686254] Extcon AUX1(HDMI) enable
[48085.686530] extcon-disp-state extcon:disp-state: cable 51 state 1
[48085.686534] Extcon HDMI: HPD enabled
[48085.686624] tegradc tegradc.0: hdmi: plugged
[48085.736400] tegradc tegradc.0: unblank
[48085.736458] tegradc tegradc.1: blank - powerdown
[48113.396292] extcon-disp-state extcon:disp-state: cable 47 state 0
[48113.396298] Extcon AUX1(HDMI) disable
[48113.419655] tegradc tegradc.0: blank - powerdown
[48113.419868] extcon-disp-state extcon:disp-state: cable 51 state 0
[48113.419873] Extcon HDMI: HPD disabled
[48113.419990] tegradc tegradc.0: hdmi: unplugged
[48113.465484] tegradc tegradc.0: blank - powerdown
[48113.465501] tegradc tegradc.0: unblank
[48113.465537] tegradc tegradc.0: unblank
[48113.465551] tegradc tegradc.1: blank - powerdown
[48113.993684] tegradc tegradc.0: blank - powerdown
[48113.993705] tegradc tegradc.0: unblank
[48114.000048] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48114.004991] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48114.006883] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48114.006894] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48114.047171] extcon-disp-state extcon:disp-state: cable 47 state 1
[48114.047175] Extcon AUX1(HDMI) enable
[48114.047381] extcon-disp-state extcon:disp-state: cable 51 state 1
[48114.047386] Extcon HDMI: HPD enabled
[48114.047426] tegradc tegradc.0: hdmi: plugged
[48114.067054] tegradc tegradc.0: unblank
[48114.067353] tegradc tegradc.1: blank - powerdown
[48129.573883] extcon-disp-state extcon:disp-state: cable 47 state 0
[48129.573890] Extcon AUX1(HDMI) disable
[48129.598322] tegradc tegradc.0: blank - powerdown
[48129.598504] extcon-disp-state extcon:disp-state: cable 51 state 0
[48129.598509] Extcon HDMI: HPD disabled
[48129.598597] tegradc tegradc.0: hdmi: unplugged
[48129.617307] tegradc tegradc.0: blank - powerdown
[48129.617325] tegradc tegradc.0: unblank
[48129.617362] tegradc tegradc.0: unblank
[48129.617375] tegradc tegradc.1: blank - powerdown
[48130.173599] tegradc tegradc.0: blank - powerdown
[48130.173622] tegradc tegradc.0: unblank
[48130.187147] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48130.192375] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48130.193762] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48130.193773] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48130.232937] extcon-disp-state extcon:disp-state: cable 47 state 1
[48130.232941] Extcon AUX1(HDMI) enable
[48130.233163] extcon-disp-state extcon:disp-state: cable 51 state 1
[48130.233168] Extcon HDMI: HPD enabled
[48130.233203] tegradc tegradc.0: hdmi: plugged
[48130.249145] tegradc tegradc.0: unblank
[48130.249159] tegradc tegradc.1: blank - powerdown
[48145.660759] extcon-disp-state extcon:disp-state: cable 47 state 0
[48145.660766] Extcon AUX1(HDMI) disable
[48145.682004] tegradc tegradc.0: blank - powerdown
[48145.686493] extcon-disp-state extcon:disp-state: cable 51 state 0
[48145.686499] Extcon HDMI: HPD disabled
[48145.686565] tegradc tegradc.0: hdmi: unplugged
[48145.734289] tegradc tegradc.0: blank - powerdown
[48145.734305] tegradc tegradc.0: unblank
[48145.734344] tegradc tegradc.0: unblank
[48145.734356] tegradc tegradc.1: blank - powerdown
[48146.249119] tegradc tegradc.0: blank - powerdown
[48146.249142] tegradc tegradc.0: unblank
[48146.255405] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48146.255535] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48146.262086] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48146.262100] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48146.302792] extcon-disp-state extcon:disp-state: cable 47 state 1
[48146.303133] Extcon AUX1(HDMI) enable
[48146.305122] extcon-disp-state extcon:disp-state: cable 51 state 1
[48146.305129] Extcon HDMI: HPD enabled
[48146.305246] tegradc tegradc.0: hdmi: plugged
[48146.448798] tegradc tegradc.0: unblank
[48146.449003] tegradc tegradc.1: blank - powerdown
[48177.712366] extcon-disp-state extcon:disp-state: cable 47 state 0
[48177.712372] Extcon AUX1(HDMI) disable
[48177.734473] tegradc tegradc.0: blank - powerdown
[48177.734766] extcon-disp-state extcon:disp-state: cable 51 state 0
[48177.734771] Extcon HDMI: HPD disabled
[48177.734862] tegradc tegradc.0: hdmi: unplugged
[48177.781500] tegradc tegradc.0: blank - powerdown
[48177.781517] tegradc tegradc.0: unblank
[48177.781552] tegradc tegradc.0: unblank
[48177.781564] tegradc tegradc.1: blank - powerdown
[48178.300945] tegradc tegradc.0: blank - powerdown
[48178.301022] tegradc tegradc.0: unblank
[48178.320801] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[48178.320998] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[48178.324654] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[48178.324666] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[48178.360907] extcon-disp-state extcon:disp-state: cable 47 state 1
[48178.360910] Extcon AUX1(HDMI) enable
[48178.361192] extcon-disp-state extcon:disp-state: cable 51 state 1
[48178.361196] Extcon HDMI: HPD enabled
[48178.361277] tegradc tegradc.0: hdmi: plugged
[48178.393271] tegradc tegradc.0: unblank
[48178.393284] tegradc tegradc.1: blank - powerdown
Can you point out which part is the one that this error happened? You just share a log that has 2000 sec gap here.
Also, why did you keep hotplug the hdmi cable?
I am using my TV as HDMI monitor. I have my jetson nano and jetson nx connected to my TV HDMI3 and HDMI4 port.
I left both jetson nano and jetson nx running over few days, and MANUALLY switch the tv hdmi channel regularly (at few hours interval) to check whether they are sill running.
I dont know how to read the dmesg output…
Ok, could you tell me… when did this issue happen? Did it happen before or after you started to switch between HDMI1/2?
This msg alert happened after I flash jetpack4.4 and ran my yolov4 object detection code. Initially, I did not pay too much attention, just clicked “ok” and hope to find solution for what triggered the reboot and the msg alert by surfing the forum…
the message alert kept coming back consistently (not immediately ) despite repeated clicking “ok”
Then please pay attention to it now. Just use Nano only and try to monitor it and check if you can see it. After it shows up, immediately share us the dmesg and syslog.
cat /var/log/syslog
this output is a lot. you need me to put into a text file?
syslog is under /var/log/syslog.
Copy it out, share it as a text file here and tell us the timestamp. Syslog records the clock time in it, unlike dmesg.
the syslog is 6MB. max upload file is limited to 4MB. I will break the syslog into 2 txt file
BTW, I need to know the timestamp. So I guess you should take another day to reproduce it now, right?
