Hi!
I have a Jetson TX1 Developer Kit with L4T installed, and Im trying to change the monitor refresh rate from 60Hz to 74Hz with no success. Ive tried xrandr to modify this value, but I get the following error. Even if I set the refresh rate to 60Hz (with the same method), the same error occurs.
Could anyone help me how to change the refresh rate of the monitor, please?
ubuntu@tegra-ubuntu:~$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 510mm x 290mm
1920x1080 60.0*+ 60.1
1680x1050 60.0
1600x900 60.1 60.0
1440x900 59.9
1400x1050 60.0 60.0
1280x1024 75.0 60.0
1280x800 59.8
1280x720 60.1 60.0
1152x864 75.0
1024x768 75.0 60.1 60.0
832x624 75.0
800x600 75.0 60.3 56.3
720x400 70.0
640x480 75.0 60.0
ubuntu@tegra-ubuntu:~$ gtf 1920 1080 74.0
# 1920x1080 @ 74.00 Hz (GTF) hsync: 83.40 kHz; pclk: 217.50 MHz
Modeline "1920x1080_74.00" 217.50 1920 2056 2264 2608 1080 1081 1084 1127 -HSync +Vsync
ubuntu@tegra-ubuntu:~$ xrandr --newmode "1920x1080_74.00" 217.50 1920 2056 2264 2608 1080 1081 1084 1127 -HSync +Vsync
ubuntu@tegra-ubuntu:~$ xrandr --addmode HDMI-0 1920x1080_74.00
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 20
Current serial number in output stream: 21
What do you get from “get-edid | edid-decode” (may need packages “read-edid” and “edid-decode”)? Is 1920x1080@75Hz listed?
Thank you for your reply!
Unfortunately, I don’t have a chance to try this out right now (because I don’t have the dev kit with me), but I will definitely contact you if I get any result.
Anyway, I think the reason of the error is something different, because if I create a new mode with 60Hz, I get the same error. And 1920x1080 60.0 Hz configuration is the default configuration, so it must be supported.
Hi!
I have installed packages “edid-decode” and “read-edid”, but executing command “get-edid” got the following output.
ubuntu@tegra-ubuntu:~$ sudo get-edid
This is read-edid version 3.0.1. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 0
No EDID on bus 1
No EDID on bus 3
No EDID on bus 4
No EDID on bus 5
No EDID on bus 6
1 potential busses found: 2
Bus 2 doesn't really have an EDID...
Couldn't find an accessible EDID on this computer.
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.
This means your monitor did not reply with a query on what it is. Typically get-edid returns binary data, and then it is piped through something like parse-edid or edid-decode to put it in human readable format. If you are using an old style 15-pin D-sub connector at any point (such as an adapter), this would cause the failure. What is the exact cabling of the monitor?
Anyway, from a Windows Desktop via NVIDIA Control Panel I managed to set 1920x1080@74Hz.
Jetson TX1 connects to the monitor through a HDMI-DVI cable. (So I use the DVI-D input of the monitor)
I would think that would work, but I’m still a bit suspicious since get-edid did not find any response. What is the monitor model? Is there a URL showing its specs? Also, some DVI cables are analog only, so I’m wondering if you have other DVI cables to try.
It would also be interesting to see what get-edid shows if you were to use that monitor on your desktop using a live Ubuntu CD (no install needed, runs in RAM…if you’re feeling ambitious).
Sorry for my English…my bad.
What I meant to say is: Jetson TX1 is connected to the monitor through a HDMI-DVI cable. (So I am using the DVI-D input of the monitor).
The monitor I am currently testing is LG 23MB35, but my ultimate goal is to display (74Hz) using a DLP LightCrafter 4500 projector (which is connected to the Jetson TX1 via HDMI). I tested the projector, too, to change the refresh rate with ‘xrandr’ and also tried ‘get-edid’ command to get some info, but exactly the same errors occur. So I assume it is not a monitor related problem.
If I have no choice, I will try live Ubuntu, but I don’t see how it could help.
Is there no other way to change the refresh rate?
Is it possible to try a different HDMI-DVI cable? It wouldn’t be unusual for a cable with conversion between connector types to cause issues. The monitor itself should work fine, as the DVI-D should support EDID (the cable is the suspicious part). Seeing the cable behavior on a different Linux system would also be useful (Windows uses differet software, finding EDID from a desktop Linux system would be a very helpful test).
The main reason why a cable becomes suspicious is that if the cable were intended to work with DVI-A, then the wire for EDID could be missing…yet the cable would perhaps otherwise look similar. Although the monitor claims the connector is DVI-D, it may in fact also support mixed analog function…the monitor specs say it has a D-Sub connector supporting analog…this in turn would mean a DVI-A cable would work for video if the video source happened to work at a compatible speed/setting. Historically, cables and adapters have been found to be the issue for a number of Jetson EDID video quirks, so this would not be unusual if it is the cause.
I tested a different cable and got the same error. Even checked the DVI connector of the cable, it must be DVI-D since it has no analog pins. (http://www.amazon.com/dp/B014I8UQJY/ this description also says it is DVI-D compatible)
I think there is no problem with the cable.
Back to the beginning, the default configuration is 1920x1080@60.0Hz. If I create a “new 1920x1080_60.00 mode” with the standard method with xrandr, I got the same error. So it is neither a monitor or configuration compatible problem (because 1920x1080@60.0Hz is 100% supported).
ubuntu@tegra-ubuntu:~$ xrandr --addmode HDMI-0 1920x1080_60.00
I don’t know what it is, but it may be a Linux for Tegra or an xrandr bug/error.
Any good ideas? I am truly grateful for your help.
Which L4T release is being used? JTX1 ships with R23.1, but R23.2 fixed some video issues.
It might be interesting to see what dmesg and /var/log/Xorg.0.log changes show up upon removal and reconnect of the DVI-D cable. So basically boot up normally, try to run X11 as normal, and then unplug and re-plug the video cable (check logs before and after).
I think L4T I am using is the latest release, but will check it later.
Relevant part of /var/log/Xorg.0.log after unplugging and re-plugging:
[ 479.316] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 908.188] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 908.189] (**) NVIDIA(0): device LG Electronics 23MB35 (DFP-0) (Using EDID
[ 908.190] (**) NVIDIA(0): frequencies has been enabled on all display devices.)
[ 908.243] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 908.941] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Relevant part of dmesg after unplugging and re-plugging:
[ 479.224777] tegradc tegradc.1 hdmi unplugged
[ 479.319378] tegradc tegradc.1 blank - powerdown
[ 479.319525] tegradc tegradc.1 unblank
[ 479.319587] tegradc tegradc.1 unblank
[ 908.189753] tegradc tegradc.1 hdmi plugged
[ 908.247121] tegradc tegradc.1 blank - powerdown
[ 908.247292] tegradc tegradc.1 unblank
[ 908.270851] tegradc tegradc.1 nominal-pclk148500000 parent148500000 div1.0 pclk148500000 147015000~161865000
[ 908.639557] smmu_dump_pagetable() fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 908.639609] mc-err [mcerr] (3) csr_displayhcb EMEM decode error on PDE or PTE entry
[ 908.639638] mc-err [mcerr] status = 0x60000011; addr = 0x00000000
[ 908.639665] mc-err [mcerr] secure no, access-type read, SMMU fault nr-nw-s
[ 908.656017] smmu_dump_pagetable() fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 908.656046] mc-err [mcerr] (3) csr_displayhcb EMEM decode error on PDE or PTE entry
[ 908.656072] mc-err [mcerr] status = 0x60000011; addr = 0x00000000
[ 908.656097] mc-err [mcerr] secure no, access-type read, SMMU fault nr-nw-s
[ 908.672488] smmu_dump_pagetable() fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 908.672493] mc-err [mcerr] (3) csr_displayhcb EMEM decode error on PDE or PTE entry
[ 908.672497] mc-err [mcerr] status = 0x60000011; addr = 0x00000000
[ 908.672501] mc-err [mcerr] secure no, access-type read, SMMU fault nr-nw-s
[ 908.689135] smmu_dump_pagetable() fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 908.689139] mc-err [mcerr] (3) csr_displayhcb EMEM decode error on PDE or PTE entry
[ 908.689142] mc-err [mcerr] status = 0x60000011; addr = 0x00000000
[ 908.689145] mc-err [mcerr] secure no, access-type read, SMMU fault nr-nw-s
[ 908.705809] smmu_dump_pagetable() fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 908.705813] mc-err [mcerr] (3) csr_displayhcb EMEM decode error on PDE or PTE entry
[ 908.705816] mc-err [mcerr] status = 0x60000011; addr = 0x00000000
[ 908.705819] mc-err [mcerr] secure no, access-type read, SMMU fault nr-nw-s
[ 908.722471] mc-err Too many MC errors; throttling prints
[ 908.804884] tegradc tegradc.1 unblank
[ 908.945257] tegradc tegradc.1 blank - powerdown
[ 908.995814] tegradc tegradc.1 unblank
[ 909.022674] tegradc tegradc.1 nominal-pclk148500000 parent148500000 div1.0 pclk148500000 147015000~161865000
[ 909.374169] tegradc tegradc.1 unblank
[ 917.369527] systemd-hostnamed[8701] Warning nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
It seems there are some errors…
This does look related, but can you try “get-edid | parse-edid” again to see the error message? Check after a fresh reboot and no disconnect/reconnect of the monitor, and then again after disconnect/reconnect (looking for error messages, and especially differences between the two attempts before/after).
For checking L4T release version, see this output:
head -n 1 /etc/nv_tegra_release
Ok I checked it, my L4T version is R23.2.
fresh restart → get-edid → unplug/re-plug → get-edid → dmesg:
[ 15.312267] tegradc tegradc.1: blank - powerdown
[ 15.372210] tegradc tegradc.1: unblank
[ 15.395094] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 15.451517] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 15.747351] tegradc tegradc.1: unblank
[ 66.523669] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 66.524067] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 67.521484] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 67.528365] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 67.533857] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 67.540969] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 67.546603] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 67.552454] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0xed
[ 67.557744] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 67.563082] tegra-i2c 7000c700.i2c: msg->len - 1
[ 67.567919] tegra-i2c 7000c700.i2c: is_msg_write - 1
[ 67.572928] tegra-i2c 7000c700.i2c: next_msg->len - 1
[ 67.578001] tegra-i2c 7000c700.i2c: is_next_msg_write - 0
[ 67.583409] tegra-i2c 7000c700.i2c: buf_remaining - 1
[ 67.588529] tegra-i2c 7000c700.i2c: i2c transfer timed out, addr 0x0050, data 0x00
[ 67.596393] tegra-i2c 7000d000.i2c: no acknowledge from address 0x50
[ 68.591436] tegra-i2c 7000d100.i2c: --- register dump for debugging ----
[ 68.598404] tegra-i2c 7000d100.i2c: I2C_CNFG - 0x22c00
[ 68.603919] tegra-i2c 7000d100.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 68.611309] tegra-i2c 7000d100.i2c: I2C_FIFO_CONTROL - 0xe0
[ 68.616938] tegra-i2c 7000d100.i2c: I2C_FIFO_STATUS - 0x800040
[ 68.622787] tegra-i2c 7000d100.i2c: I2C_INT_MASK - 0xed
[ 68.628013] tegra-i2c 7000d100.i2c: I2C_INT_STATUS - 0x0
[ 68.633465] tegra-i2c 7000d100.i2c: msg->len - 1
[ 68.638105] tegra-i2c 7000d100.i2c: is_msg_write - 1
[ 68.643166] tegra-i2c 7000d100.i2c: next_msg->len - 1
[ 68.648240] tegra-i2c 7000d100.i2c: is_next_msg_write - 0
[ 68.653650] tegra-i2c 7000d100.i2c: buf_remaining - 1
[ 68.658810] tegra-i2c 7000d100.i2c: i2c transfer timed out, addr 0x0050, data 0x00
[ 68.668025] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x50
[ 133.304576] init: plymouth-stop pre-start process (2784) terminated with status 1
[ 348.154597] tegradc tegradc.1: hdmi: unplugged
[ 348.267498] tegradc tegradc.1: blank - powerdown
[ 348.267678] tegradc tegradc.1: unblank
[ 348.267744] tegradc tegradc.1: unblank
[ 355.324980] tegradc tegradc.1: hdmi: plugged
[ 355.377042] tegradc tegradc.1: blank - powerdown
[ 355.377163] tegradc tegradc.1: unblank
[ 355.400686] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 355.769301] smmu_dump_pagetable(): fault_address=0x0000000002010000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 355.769306] mc-err: [mcerr] (3) csr_display0ab: EMEM decode error on PDE or PTE entry
[ 355.769310] mc-err: [mcerr] status = 0x60000002; addr = 0x02010000
[ 355.769314] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: nr-nw-s
[ 355.781177] smmu_dump_pagetable(): fault_address=0x0000000000000000 pa=0x0000000000000000 bytes=1000 #pte=67 in L2
[ 355.781236] mc-err: [mcerr] (3) csr_displayhcb: EMEM decode error on PDE or PTE entry
[ 355.781286] mc-err: [mcerr] status = 0x60000011; addr = 0x00000000
[ 355.781335] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: nr-nw-s
[ 355.781888] smmu_dump_pagetable(): fault_address=0x00000000025d0b80 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 355.781941] mc-err: [mcerr] (3) csr_display0ab: EMEM decode error on PDE or PTE entry
[ 355.781987] mc-err: [mcerr] status = 0x60046002; addr = 0x025d0b80
[ 355.782038] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: nr-nw-s
[ 355.782513] smmu_dump_pagetable(): fault_address=0x0000000002673740 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 355.782567] mc-err: [mcerr] (3) csr_display0ab: EMEM decode error on PDE or PTE entry
[ 355.782611] mc-err: [mcerr] status = 0x60005002; addr = 0x02673740
[ 355.782657] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: nr-nw-s
[ 355.783167] smmu_dump_pagetable(): fault_address=0x000000000274c180 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 355.783218] mc-err: [mcerr] (3) csr_display0ab: EMEM decode error on PDE or PTE entry
[ 355.783262] mc-err: [mcerr] status = 0x60046002; addr = 0x0274c180
[ 355.783308] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: nr-nw-s
[ 355.783735] mc-err: Too many MC errors; throttling prints
[ 355.943750] tegradc tegradc.1: unblank
[ 356.093815] tegradc tegradc.1: blank - powerdown
[ 356.142877] tegradc tegradc.1: unblank
[ 356.170729] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 356.522088] tegradc tegradc.1: unblank
[ 366.062740] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[ 366.063136] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[ 367.059621] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 367.066500] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 367.072071] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 367.079374] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 367.085085] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 367.091704] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0xed
[ 367.096993] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 367.102452] tegra-i2c 7000c700.i2c: msg->len - 1
[ 367.107131] tegra-i2c 7000c700.i2c: is_msg_write - 1
[ 367.112124] tegra-i2c 7000c700.i2c: next_msg->len - 1
[ 367.117198] tegra-i2c 7000c700.i2c: is_next_msg_write - 0
[ 367.122633] tegra-i2c 7000c700.i2c: buf_remaining - 1
[ 367.127725] tegra-i2c 7000c700.i2c: i2c transfer timed out, addr 0x0050, data 0x00
[ 367.135608] tegra-i2c 7000d000.i2c: no acknowledge from address 0x50
[ 368.130046] tegra-i2c 7000d100.i2c: --- register dump for debugging ----
[ 368.137036] tegra-i2c 7000d100.i2c: I2C_CNFG - 0x22c00
[ 368.142796] tegra-i2c 7000d100.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 368.152576] tegra-i2c 7000d100.i2c: I2C_FIFO_CONTROL - 0xe0
[ 368.158153] tegra-i2c 7000d100.i2c: I2C_FIFO_STATUS - 0x800040
[ 368.164019] tegra-i2c 7000d100.i2c: I2C_INT_MASK - 0xed
[ 368.169270] tegra-i2c 7000d100.i2c: I2C_INT_STATUS - 0x0
[ 368.174583] tegra-i2c 7000d100.i2c: msg->len - 1
[ 368.179223] tegra-i2c 7000d100.i2c: is_msg_write - 1
[ 368.184186] tegra-i2c 7000d100.i2c: next_msg->len - 1
[ 368.189254] tegra-i2c 7000d100.i2c: is_next_msg_write - 0
[ 368.194650] tegra-i2c 7000d100.i2c: buf_remaining - 1
[ 368.199758] tegra-i2c 7000d100.i2c: i2c transfer timed out, addr 0x0050, data 0x00
[ 368.208665] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x50
Obviously, the error message for get-edid is the same:
No EDID on bus 0
No EDID on bus 1
No EDID on bus 3
No EDID on bus 4
No EDID on bus 5
No EDID on bus 6
There is a definite failure to read EDID. The real mystery is why. Unplug/replug offers more details of the i2c failure, but i2c logs are something I am unable to debug. It seems that the gist of it is i2c from the monitor either not responding or responding in an invalid way, possibly causing other software trying to use the response to have issues.
Just to verify the nVidia-specific files are all in place, does everything show OK from:
sha1sum -c /etc/nv_tegra_release
It would be very useful to see how a desktop Linux computer responds to EDID query for that exact monitor.
The nVidia-specific files are all in place. I will check the EDID query response of a Linux computer soon.
“head -n 1 /etc/nv_tegra_release”:
ubuntu@tegra-ubuntu:~$ sha1sum -c /etc/nv_tegra_release
/usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_image.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmedia.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_utils.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libglx.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libscf.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvexif.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvrm_gpu.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmm_parser.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvrm.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmm_contentpipe.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvos.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvtnr.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvavp.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvjpeg.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvtvmr.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvdc.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libtegrav4l2.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmm.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvapputil.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvcameratools.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvcam_imageencoder.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_audio.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmm_utils.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvomxilclient.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvwinsys.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnveglstreamproducer.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvrm_graphics.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvddk_2d_v2.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvtestresults.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvparser.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvddk_vic.so: OK
/usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite.so: OK
/usr/lib/xorg/modules/drivers/nvidia_drv.so: OK
/usr/lib/xorg/modules/extensions/libglx.so: OK
I have executed “get-edid | parse-edid” on dektop Ubuntu with no problem:
Section "Monitor"
Identifier "23MB35"
ModelName "23MB35"
VendorName "GSM"
# Monitor Manufactured week 5 of 2015
# EDID version 1.3
# Analog Display
DisplaySize 510 290
Gamma 2.20
Option "DPMS" "true"
Horizsync 30-83
VertRefresh 56-75
# Maximum pixel clock is 150MHz
#Not giving standard mode: 1152x864, 75Hz
#Not giving standard mode: 1280x720, 60Hz
#Not giving standard mode: 1280x800, 60Hz
#Not giving standard mode: 1280x1024, 60Hz
#Not giving standard mode: 1440x900, 60Hz
#Not giving standard mode: 1400x1050, 60Hz
#Not giving standard mode: 1600x900, 60Hz
#Not giving standard mode: 1680x1050, 60Hz
Modeline
EndSection
“dmesg” has no error this time:
[ 0.477657] i2c /dev entries driver
[ 100.052318] i2c i2c-8: sendbytes: NAK bailout.
[ 100.052855] i2c i2c-8: sendbytes: NAK bailout.
[ 100.053391] i2c i2c-8: sendbytes: NAK bailout.
[ 100.053926] i2c i2c-8: sendbytes: NAK bailout.
[ 100.054461] i2c i2c-8: sendbytes: NAK bailout.
[ 100.054995] i2c i2c-8: sendbytes: NAK bailout.
[ 100.055531] i2c i2c-8: sendbytes: NAK bailout.
[ 100.056066] i2c i2c-8: sendbytes: NAK bailout.
[ 100.056615] i2c i2c-8: sendbytes: NAK bailout.
[ 100.057151] i2c i2c-8: sendbytes: NAK bailout.
[ 100.057687] i2c i2c-8: sendbytes: NAK bailout.
[ 100.058222] i2c i2c-8: sendbytes: NAK bailout.
[ 100.058757] i2c i2c-8: sendbytes: NAK bailout.
[ 100.059292] i2c i2c-8: sendbytes: NAK bailout.
[ 100.059827] i2c i2c-8: sendbytes: NAK bailout.
[ 100.060373] i2c i2c-8: sendbytes: NAK bailout.
[ 100.060909] i2c i2c-8: sendbytes: NAK bailout.
[ 100.061444] i2c i2c-8: sendbytes: NAK bailout.
[ 100.061979] i2c i2c-8: sendbytes: NAK bailout.
[ 100.062514] i2c i2c-8: sendbytes: NAK bailout.
[ 100.063049] i2c i2c-8: sendbytes: NAK bailout.
[ 100.063584] i2c i2c-8: sendbytes: NAK bailout.
[ 100.064119] i2c i2c-8: sendbytes: NAK bailout.
[ 100.064673] i2c i2c-8: sendbytes: NAK bailout.
[ 100.065209] i2c i2c-8: sendbytes: NAK bailout.
[ 100.065745] i2c i2c-8: sendbytes: NAK bailout.
[ 100.066280] i2c i2c-8: sendbytes: NAK bailout.
[ 100.066815] i2c i2c-8: sendbytes: NAK bailout.
[ 100.067350] i2c i2c-8: sendbytes: NAK bailout.
[ 100.067886] i2c i2c-8: sendbytes: NAK bailout.
[ 100.068440] i2c i2c-8: sendbytes: NAK bailout.
[ 100.068977] i2c i2c-8: sendbytes: NAK bailout.
[ 100.069512] i2c i2c-8: sendbytes: NAK bailout.
[ 100.070047] i2c i2c-8: sendbytes: NAK bailout.
[ 100.070582] i2c i2c-8: sendbytes: NAK bailout.
[ 100.071117] i2c i2c-8: sendbytes: NAK bailout.
[ 100.071655] i2c i2c-8: sendbytes: NAK bailout.
[ 100.072205] i2c i2c-8: sendbytes: NAK bailout.
[ 100.072750] i2c i2c-8: sendbytes: NAK bailout.
[ 100.073286] i2c i2c-8: sendbytes: NAK bailout.
[ 100.073822] i2c i2c-8: sendbytes: NAK bailout.
[ 100.074357] i2c i2c-8: sendbytes: NAK bailout.
[ 100.074893] i2c i2c-8: sendbytes: NAK bailout.
[ 100.075428] i2c i2c-8: sendbytes: NAK bailout.
[ 100.075963] i2c i2c-8: sendbytes: NAK bailout.
[ 100.076519] i2c i2c-8: sendbytes: NAK bailout.
[ 100.077055] i2c i2c-8: sendbytes: NAK bailout.
[ 100.077590] i2c i2c-8: sendbytes: NAK bailout.
[ 100.078125] i2c i2c-8: sendbytes: NAK bailout.
[ 100.078660] i2c i2c-8: sendbytes: NAK bailout.
[ 100.079196] i2c i2c-8: sendbytes: NAK bailout.
[ 100.079731] i2c i2c-8: sendbytes: NAK bailout.
[ 100.080287] i2c i2c-8: sendbytes: NAK bailout.
[ 100.080824] i2c i2c-8: sendbytes: NAK bailout.
[ 100.081359] i2c i2c-8: sendbytes: NAK bailout.
[ 100.081894] i2c i2c-8: sendbytes: NAK bailout.
[ 100.082429] i2c i2c-8: sendbytes: NAK bailout.
[ 100.082964] i2c i2c-8: sendbytes: NAK bailout.
[ 100.083499] i2c i2c-8: sendbytes: NAK bailout.
[ 100.084034] i2c i2c-8: sendbytes: NAK bailout.
[ 100.084579] i2c i2c-8: sendbytes: NAK bailout.
[ 100.085115] i2c i2c-8: sendbytes: NAK bailout.
[ 100.085650] i2c i2c-8: sendbytes: NAK bailout.
[ 100.086186] i2c i2c-8: sendbytes: NAK bailout.
[ 100.086721] i2c i2c-8: sendbytes: NAK bailout.
[ 100.087256] i2c i2c-8: sendbytes: NAK bailout.
[ 100.087791] i2c i2c-8: sendbytes: NAK bailout.
[ 100.088342] i2c i2c-8: sendbytes: NAK bailout.
[ 100.088878] i2c i2c-8: sendbytes: NAK bailout.
[ 100.089413] i2c i2c-8: sendbytes: NAK bailout.
[ 100.089948] i2c i2c-8: sendbytes: NAK bailout.
[ 100.090484] i2c i2c-8: sendbytes: NAK bailout.
[ 100.091019] i2c i2c-8: sendbytes: NAK bailout.
[ 100.091554] i2c i2c-8: sendbytes: NAK bailout.
[ 100.092089] i2c i2c-8: sendbytes: NAK bailout.
[ 100.092636] i2c i2c-8: sendbytes: NAK bailout.
[ 100.093172] i2c i2c-8: sendbytes: NAK bailout.
[ 100.093707] i2c i2c-8: sendbytes: NAK bailout.
[ 100.094242] i2c i2c-8: sendbytes: NAK bailout.
[ 100.094777] i2c i2c-8: sendbytes: NAK bailout.
[ 100.095312] i2c i2c-8: sendbytes: NAK bailout.
[ 100.095847] i2c i2c-8: sendbytes: NAK bailout.
[ 100.096399] i2c i2c-8: sendbytes: NAK bailout.
[ 100.096935] i2c i2c-8: sendbytes: NAK bailout.
[ 100.097470] i2c i2c-8: sendbytes: NAK bailout.
[ 100.098005] i2c i2c-8: sendbytes: NAK bailout.
[ 100.098540] i2c i2c-8: sendbytes: NAK bailout.
[ 100.099076] i2c i2c-8: sendbytes: NAK bailout.
[ 100.099611] i2c i2c-8: sendbytes: NAK bailout.
[ 100.100146] i2c i2c-8: sendbytes: NAK bailout.
[ 100.100694] i2c i2c-8: sendbytes: NAK bailout.
[ 100.101230] i2c i2c-8: sendbytes: NAK bailout.
[ 100.101765] i2c i2c-8: sendbytes: NAK bailout.
[ 100.102300] i2c i2c-8: sendbytes: NAK bailout.
[ 100.102836] i2c i2c-8: sendbytes: NAK bailout.
[ 100.103371] i2c i2c-8: sendbytes: NAK bailout.
[ 100.103906] i2c i2c-8: sendbytes: NAK bailout.
[ 100.104472] i2c i2c-8: sendbytes: NAK bailout.
[ 100.105011] i2c i2c-8: sendbytes: NAK bailout.
[ 100.105547] i2c i2c-8: sendbytes: NAK bailout.
[ 100.106082] i2c i2c-8: sendbytes: NAK bailout.
[ 100.106617] i2c i2c-8: sendbytes: NAK bailout.
[ 100.107152] i2c i2c-8: sendbytes: NAK bailout.
[ 100.107687] i2c i2c-8: sendbytes: NAK bailout.
[ 100.108236] i2c i2c-8: sendbytes: NAK bailout.
[ 100.108773] i2c i2c-8: sendbytes: NAK bailout.
[ 100.109308] i2c i2c-8: sendbytes: NAK bailout.
[ 100.109843] i2c i2c-8: sendbytes: NAK bailout.
[ 100.110378] i2c i2c-8: sendbytes: NAK bailout.
[ 100.110914] i2c i2c-8: sendbytes: NAK bailout.
[ 100.111449] i2c i2c-8: sendbytes: NAK bailout.
[ 100.111984] i2c i2c-8: sendbytes: NAK bailout.
[ 100.112537] i2c i2c-8: sendbytes: NAK bailout.
[ 100.113073] i2c i2c-8: sendbytes: NAK bailout.
[ 100.113608] i2c i2c-8: sendbytes: NAK bailout.
[ 100.114143] i2c i2c-8: sendbytes: NAK bailout.
[ 100.114678] i2c i2c-8: sendbytes: NAK bailout.
[ 100.115213] i2c i2c-8: sendbytes: NAK bailout.
[ 100.115748] i2c i2c-8: sendbytes: NAK bailout.
[ 100.116291] i2c i2c-8: sendbytes: NAK bailout.
[ 100.116827] i2c i2c-8: sendbytes: NAK bailout.
[ 100.117362] i2c i2c-8: sendbytes: NAK bailout.
[ 100.117897] i2c i2c-8: sendbytes: NAK bailout.
[ 100.118433] i2c i2c-8: sendbytes: NAK bailout.
[ 100.118968] i2c i2c-8: sendbytes: NAK bailout.
[ 100.119503] i2c i2c-8: sendbytes: NAK bailout.
[ 100.120038] i2c i2c-8: sendbytes: NAK bailout.
[ 100.120599] i2c i2c-8: sendbytes: NAK bailout.
[ 441.574356] i2c i2c-8: sendbytes: NAK bailout.
[ 441.574893] i2c i2c-8: sendbytes: NAK bailout.
[ 441.575428] i2c i2c-8: sendbytes: NAK bailout.
[ 441.575964] i2c i2c-8: sendbytes: NAK bailout.
[ 441.576499] i2c i2c-8: sendbytes: NAK bailout.
[ 441.577037] i2c i2c-8: sendbytes: NAK bailout.
[ 441.577572] i2c i2c-8: sendbytes: NAK bailout.
[ 441.578133] i2c i2c-8: sendbytes: NAK bailout.
[ 441.578668] i2c i2c-8: sendbytes: NAK bailout.
[ 441.579203] i2c i2c-8: sendbytes: NAK bailout.
[ 441.579738] i2c i2c-8: sendbytes: NAK bailout.
[ 441.580273] i2c i2c-8: sendbytes: NAK bailout.
[ 441.580808] i2c i2c-8: sendbytes: NAK bailout.
[ 441.581343] i2c i2c-8: sendbytes: NAK bailout.
[ 441.581887] i2c i2c-8: sendbytes: NAK bailout.
[ 441.582414] i2c i2c-8: sendbytes: NAK bailout.
[ 441.582958] i2c i2c-8: sendbytes: NAK bailout.
[ 441.583493] i2c i2c-8: sendbytes: NAK bailout.
[ 441.584029] i2c i2c-8: sendbytes: NAK bailout.
[ 441.584564] i2c i2c-8: sendbytes: NAK bailout.
[ 441.585099] i2c i2c-8: sendbytes: NAK bailout.
[ 441.585634] i2c i2c-8: sendbytes: NAK bailout.
[ 441.586198] i2c i2c-8: sendbytes: NAK bailout.
[ 441.586734] i2c i2c-8: sendbytes: NAK bailout.
[ 441.587269] i2c i2c-8: sendbytes: NAK bailout.
[ 441.587803] i2c i2c-8: sendbytes: NAK bailout.
[ 441.588338] i2c i2c-8: sendbytes: NAK bailout.
[ 441.588873] i2c i2c-8: sendbytes: NAK bailout.
[ 441.589408] i2c i2c-8: sendbytes: NAK bailout.
[ 441.589961] i2c i2c-8: sendbytes: NAK bailout.
[ 441.590497] i2c i2c-8: sendbytes: NAK bailout.
[ 441.591031] i2c i2c-8: sendbytes: NAK bailout.
[ 441.591567] i2c i2c-8: sendbytes: NAK bailout.
[ 441.592102] i2c i2c-8: sendbytes: NAK bailout.
[ 441.592637] i2c i2c-8: sendbytes: NAK bailout.
[ 441.593172] i2c i2c-8: sendbytes: NAK bailout.
[ 441.593717] i2c i2c-8: sendbytes: NAK bailout.
[ 441.594269] i2c i2c-8: sendbytes: NAK bailout.
[ 441.594804] i2c i2c-8: sendbytes: NAK bailout.
[ 441.595339] i2c i2c-8: sendbytes: NAK bailout.
[ 441.595874] i2c i2c-8: sendbytes: NAK bailout.
[ 441.596409] i2c i2c-8: sendbytes: NAK bailout.
[ 441.596944] i2c i2c-8: sendbytes: NAK bailout.
[ 441.597479] i2c i2c-8: sendbytes: NAK bailout.
[ 441.598043] i2c i2c-8: sendbytes: NAK bailout.
[ 441.598578] i2c i2c-8: sendbytes: NAK bailout.
[ 441.599113] i2c i2c-8: sendbytes: NAK bailout.
[ 441.599648] i2c i2c-8: sendbytes: NAK bailout.
[ 441.600183] i2c i2c-8: sendbytes: NAK bailout.
[ 441.600718] i2c i2c-8: sendbytes: NAK bailout.
[ 441.601253] i2c i2c-8: sendbytes: NAK bailout.
[ 441.601805] i2c i2c-8: sendbytes: NAK bailout.
[ 441.602341] i2c i2c-8: sendbytes: NAK bailout.
[ 441.602876] i2c i2c-8: sendbytes: NAK bailout.
[ 441.603411] i2c i2c-8: sendbytes: NAK bailout.
[ 441.603946] i2c i2c-8: sendbytes: NAK bailout.
[ 441.604481] i2c i2c-8: sendbytes: NAK bailout.
[ 441.605016] i2c i2c-8: sendbytes: NAK bailout.
[ 441.605551] i2c i2c-8: sendbytes: NAK bailout.
[ 441.606108] i2c i2c-8: sendbytes: NAK bailout.
[ 441.606643] i2c i2c-8: sendbytes: NAK bailout.
[ 441.607178] i2c i2c-8: sendbytes: NAK bailout.
[ 441.607713] i2c i2c-8: sendbytes: NAK bailout.
[ 441.608249] i2c i2c-8: sendbytes: NAK bailout.
[ 441.608784] i2c i2c-8: sendbytes: NAK bailout.
[ 441.609319] i2c i2c-8: sendbytes: NAK bailout.
[ 441.609888] i2c i2c-8: sendbytes: NAK bailout.
[ 441.610422] i2c i2c-8: sendbytes: NAK bailout.
[ 441.610957] i2c i2c-8: sendbytes: NAK bailout.
[ 441.611492] i2c i2c-8: sendbytes: NAK bailout.
[ 441.612028] i2c i2c-8: sendbytes: NAK bailout.
[ 441.612563] i2c i2c-8: sendbytes: NAK bailout.
[ 441.613098] i2c i2c-8: sendbytes: NAK bailout.
[ 441.613633] i2c i2c-8: sendbytes: NAK bailout.
[ 441.614190] i2c i2c-8: sendbytes: NAK bailout.
[ 441.614725] i2c i2c-8: sendbytes: NAK bailout.
[ 441.615260] i2c i2c-8: sendbytes: NAK bailout.
[ 441.615795] i2c i2c-8: sendbytes: NAK bailout.
[ 441.616331] i2c i2c-8: sendbytes: NAK bailout.
[ 441.616866] i2c i2c-8: sendbytes: NAK bailout.
[ 441.617401] i2c i2c-8: sendbytes: NAK bailout.
[ 441.617956] i2c i2c-8: sendbytes: NAK bailout.
[ 441.618492] i2c i2c-8: sendbytes: NAK bailout.
[ 441.619027] i2c i2c-8: sendbytes: NAK bailout.
[ 441.619562] i2c i2c-8: sendbytes: NAK bailout.
[ 441.620098] i2c i2c-8: sendbytes: NAK bailout.
[ 441.620633] i2c i2c-8: sendbytes: NAK bailout.
[ 441.621169] i2c i2c-8: sendbytes: NAK bailout.
[ 441.621750] i2c i2c-8: sendbytes: NAK bailout.
[ 441.622297] i2c i2c-8: sendbytes: NAK bailout.
[ 441.622837] i2c i2c-8: sendbytes: NAK bailout.
[ 441.623375] i2c i2c-8: sendbytes: NAK bailout.
[ 441.623911] i2c i2c-8: sendbytes: NAK bailout.
[ 441.624446] i2c i2c-8: sendbytes: NAK bailout.
[ 441.624981] i2c i2c-8: sendbytes: NAK bailout.
[ 441.625516] i2c i2c-8: sendbytes: NAK bailout.
[ 441.626086] i2c i2c-8: sendbytes: NAK bailout.
[ 441.626622] i2c i2c-8: sendbytes: NAK bailout.
[ 441.627161] i2c i2c-8: sendbytes: NAK bailout.
[ 441.627697] i2c i2c-8: sendbytes: NAK bailout.
[ 441.628232] i2c i2c-8: sendbytes: NAK bailout.
[ 441.628767] i2c i2c-8: sendbytes: NAK bailout.
[ 441.629302] i2c i2c-8: sendbytes: NAK bailout.
[ 441.629870] i2c i2c-8: sendbytes: NAK bailout.
[ 441.630405] i2c i2c-8: sendbytes: NAK bailout.
[ 441.630940] i2c i2c-8: sendbytes: NAK bailout.
[ 441.631475] i2c i2c-8: sendbytes: NAK bailout.
[ 441.632010] i2c i2c-8: sendbytes: NAK bailout.
[ 441.632546] i2c i2c-8: sendbytes: NAK bailout.
[ 441.633081] i2c i2c-8: sendbytes: NAK bailout.
[ 441.633616] i2c i2c-8: sendbytes: NAK bailout.
[ 441.634173] i2c i2c-8: sendbytes: NAK bailout.
[ 441.634709] i2c i2c-8: sendbytes: NAK bailout.
[ 441.635244] i2c i2c-8: sendbytes: NAK bailout.
[ 441.635779] i2c i2c-8: sendbytes: NAK bailout.
[ 441.636314] i2c i2c-8: sendbytes: NAK bailout.
[ 441.636849] i2c i2c-8: sendbytes: NAK bailout.
[ 441.637384] i2c i2c-8: sendbytes: NAK bailout.
[ 441.637936] i2c i2c-8: sendbytes: NAK bailout.
[ 441.638471] i2c i2c-8: sendbytes: NAK bailout.
[ 441.639007] i2c i2c-8: sendbytes: NAK bailout.
[ 441.639542] i2c i2c-8: sendbytes: NAK bailout.
[ 441.640077] i2c i2c-8: sendbytes: NAK bailout.
[ 441.640612] i2c i2c-8: sendbytes: NAK bailout.
[ 441.641147] i2c i2c-8: sendbytes: NAK bailout.
[ 441.641682] i2c i2c-8: sendbytes: NAK bailout.
[ 441.642238] i2c i2c-8: sendbytes: NAK bailout.
[ 441.642773] i2c i2c-8: sendbytes: NAK bailout.
[ 450.906568] i2c i2c-8: sendbytes: NAK bailout.
[ 450.907105] i2c i2c-8: sendbytes: NAK bailout.
[ 450.907641] i2c i2c-8: sendbytes: NAK bailout.
[ 450.908176] i2c i2c-8: sendbytes: NAK bailout.
[ 450.908711] i2c i2c-8: sendbytes: NAK bailout.
[ 450.909246] i2c i2c-8: sendbytes: NAK bailout.
[ 450.909781] i2c i2c-8: sendbytes: NAK bailout.
[ 450.910359] i2c i2c-8: sendbytes: NAK bailout.
[ 450.910895] i2c i2c-8: sendbytes: NAK bailout.
[ 450.911432] i2c i2c-8: sendbytes: NAK bailout.
[ 450.911968] i2c i2c-8: sendbytes: NAK bailout.
[ 450.912503] i2c i2c-8: sendbytes: NAK bailout.
[ 450.913038] i2c i2c-8: sendbytes: NAK bailout.
[ 450.913573] i2c i2c-8: sendbytes: NAK bailout.
[ 450.914129] i2c i2c-8: sendbytes: NAK bailout.
[ 450.914664] i2c i2c-8: sendbytes: NAK bailout.
[ 450.915199] i2c i2c-8: sendbytes: NAK bailout.
[ 450.915734] i2c i2c-8: sendbytes: NAK bailout.
[ 450.916269] i2c i2c-8: sendbytes: NAK bailout.
[ 450.916804] i2c i2c-8: sendbytes: NAK bailout.
[ 450.917339] i2c i2c-8: sendbytes: NAK bailout.
[ 450.917875] i2c i2c-8: sendbytes: NAK bailout.
[ 450.918433] i2c i2c-8: sendbytes: NAK bailout.
[ 450.918969] i2c i2c-8: sendbytes: NAK bailout.
[ 450.919504] i2c i2c-8: sendbytes: NAK bailout.
[ 450.920039] i2c i2c-8: sendbytes: NAK bailout.
[ 450.920575] i2c i2c-8: sendbytes: NAK bailout.
[ 450.921110] i2c i2c-8: sendbytes: NAK bailout.
[ 450.921645] i2c i2c-8: sendbytes: NAK bailout.
[ 450.922207] i2c i2c-8: sendbytes: NAK bailout.
[ 450.922743] i2c i2c-8: sendbytes: NAK bailout.
[ 450.923278] i2c i2c-8: sendbytes: NAK bailout.
[ 450.923813] i2c i2c-8: sendbytes: NAK bailout.
[ 450.924349] i2c i2c-8: sendbytes: NAK bailout.
[ 450.924884] i2c i2c-8: sendbytes: NAK bailout.
[ 450.925419] i2c i2c-8: sendbytes: NAK bailout.
[ 450.925954] i2c i2c-8: sendbytes: NAK bailout.
[ 450.926512] i2c i2c-8: sendbytes: NAK bailout.
[ 450.927048] i2c i2c-8: sendbytes: NAK bailout.
[ 450.927583] i2c i2c-8: sendbytes: NAK bailout.
[ 450.928125] i2c i2c-8: sendbytes: NAK bailout.
[ 450.928660] i2c i2c-8: sendbytes: NAK bailout.
[ 450.929196] i2c i2c-8: sendbytes: NAK bailout.
[ 450.929731] i2c i2c-8: sendbytes: NAK bailout.
[ 450.930294] i2c i2c-8: sendbytes: NAK bailout.
[ 450.930829] i2c i2c-8: sendbytes: NAK bailout.
[ 450.931364] i2c i2c-8: sendbytes: NAK bailout.
[ 450.931899] i2c i2c-8: sendbytes: NAK bailout.
[ 450.932435] i2c i2c-8: sendbytes: NAK bailout.
[ 450.932970] i2c i2c-8: sendbytes: NAK bailout.
[ 450.933505] i2c i2c-8: sendbytes: NAK bailout.
[ 450.934059] i2c i2c-8: sendbytes: NAK bailout.
[ 450.934598] i2c i2c-8: sendbytes: NAK bailout.
[ 450.935133] i2c i2c-8: sendbytes: NAK bailout.
[ 450.935669] i2c i2c-8: sendbytes: NAK bailout.
[ 450.936204] i2c i2c-8: sendbytes: NAK bailout.
[ 450.936739] i2c i2c-8: sendbytes: NAK bailout.
[ 450.937274] i2c i2c-8: sendbytes: NAK bailout.
[ 450.937809] i2c i2c-8: sendbytes: NAK bailout.
[ 450.938378] i2c i2c-8: sendbytes: NAK bailout.
[ 450.938914] i2c i2c-8: sendbytes: NAK bailout.
[ 450.939449] i2c i2c-8: sendbytes: NAK bailout.
[ 450.939984] i2c i2c-8: sendbytes: NAK bailout.
[ 450.940519] i2c i2c-8: sendbytes: NAK bailout.
[ 450.941054] i2c i2c-8: sendbytes: NAK bailout.
[ 450.941590] i2c i2c-8: sendbytes: NAK bailout.
[ 450.942148] i2c i2c-8: sendbytes: NAK bailout.
[ 450.942683] i2c i2c-8: sendbytes: NAK bailout.
[ 450.943218] i2c i2c-8: sendbytes: NAK bailout.
[ 450.943754] i2c i2c-8: sendbytes: NAK bailout.
[ 450.944289] i2c i2c-8: sendbytes: NAK bailout.
[ 450.944831] i2c i2c-8: sendbytes: NAK bailout.
[ 450.945366] i2c i2c-8: sendbytes: NAK bailout.
[ 450.945902] i2c i2c-8: sendbytes: NAK bailout.
[ 450.946463] i2c i2c-8: sendbytes: NAK bailout.
[ 450.946998] i2c i2c-8: sendbytes: NAK bailout.
[ 450.947534] i2c i2c-8: sendbytes: NAK bailout.
[ 450.948069] i2c i2c-8: sendbytes: NAK bailout.
[ 450.948604] i2c i2c-8: sendbytes: NAK bailout.
[ 450.949139] i2c i2c-8: sendbytes: NAK bailout.
[ 450.949674] i2c i2c-8: sendbytes: NAK bailout.
[ 450.950234] i2c i2c-8: sendbytes: NAK bailout.
[ 450.950769] i2c i2c-8: sendbytes: NAK bailout.
[ 450.951304] i2c i2c-8: sendbytes: NAK bailout.
[ 450.951840] i2c i2c-8: sendbytes: NAK bailout.
[ 450.952375] i2c i2c-8: sendbytes: NAK bailout.
[ 450.952938] i2c i2c-8: sendbytes: NAK bailout.
[ 450.953474] i2c i2c-8: sendbytes: NAK bailout.
[ 450.954028] i2c i2c-8: sendbytes: NAK bailout.
[ 450.954592] i2c i2c-8: sendbytes: NAK bailout.
[ 450.955129] i2c i2c-8: sendbytes: NAK bailout.
[ 450.955665] i2c i2c-8: sendbytes: NAK bailout.
[ 450.956200] i2c i2c-8: sendbytes: NAK bailout.
[ 450.956735] i2c i2c-8: sendbytes: NAK bailout.
[ 450.957270] i2c i2c-8: sendbytes: NAK bailout.
[ 450.957806] i2c i2c-8: sendbytes: NAK bailout.
[ 450.958350] i2c i2c-8: sendbytes: NAK bailout.
[ 450.958886] i2c i2c-8: sendbytes: NAK bailout.
[ 450.959421] i2c i2c-8: sendbytes: NAK bailout.
[ 450.959956] i2c i2c-8: sendbytes: NAK bailout.
[ 450.960491] i2c i2c-8: sendbytes: NAK bailout.
[ 450.961026] i2c i2c-8: sendbytes: NAK bailout.
[ 450.961566] i2c i2c-8: sendbytes: NAK bailout.
[ 450.962124] i2c i2c-8: sendbytes: NAK bailout.
[ 450.962660] i2c i2c-8: sendbytes: NAK bailout.
[ 450.963195] i2c i2c-8: sendbytes: NAK bailout.
[ 450.963730] i2c i2c-8: sendbytes: NAK bailout.
[ 450.964265] i2c i2c-8: sendbytes: NAK bailout.
[ 450.964800] i2c i2c-8: sendbytes: NAK bailout.
[ 450.965336] i2c i2c-8: sendbytes: NAK bailout.
[ 450.965871] i2c i2c-8: sendbytes: NAK bailout.
[ 450.966431] i2c i2c-8: sendbytes: NAK bailout.
[ 450.966967] i2c i2c-8: sendbytes: NAK bailout.
[ 450.967502] i2c i2c-8: sendbytes: NAK bailout.
[ 450.968037] i2c i2c-8: sendbytes: NAK bailout.
[ 450.968572] i2c i2c-8: sendbytes: NAK bailout.
[ 450.969107] i2c i2c-8: sendbytes: NAK bailout.
[ 450.969643] i2c i2c-8: sendbytes: NAK bailout.
[ 450.970202] i2c i2c-8: sendbytes: NAK bailout.
[ 450.970737] i2c i2c-8: sendbytes: NAK bailout.
[ 450.971272] i2c i2c-8: sendbytes: NAK bailout.
[ 450.971808] i2c i2c-8: sendbytes: NAK bailout.
[ 450.972343] i2c i2c-8: sendbytes: NAK bailout.
[ 450.972878] i2c i2c-8: sendbytes: NAK bailout.
[ 450.973414] i2c i2c-8: sendbytes: NAK bailout.
[ 450.973949] i2c i2c-8: sendbytes: NAK bailout.
[ 450.974508] i2c i2c-8: sendbytes: NAK bailout.
[ 450.975044] i2c i2c-8: sendbytes: NAK bailout.
[ 537.398338] i2c i2c-8: sendbytes: NAK bailout.
[ 537.398875] i2c i2c-8: sendbytes: NAK bailout.
[ 537.399410] i2c i2c-8: sendbytes: NAK bailout.
[ 537.399945] i2c i2c-8: sendbytes: NAK bailout.
[ 537.400480] i2c i2c-8: sendbytes: NAK bailout.
[ 537.401015] i2c i2c-8: sendbytes: NAK bailout.
[ 537.401551] i2c i2c-8: sendbytes: NAK bailout.
[ 537.402118] i2c i2c-8: sendbytes: NAK bailout.
[ 537.402654] i2c i2c-8: sendbytes: NAK bailout.
[ 537.403188] i2c i2c-8: sendbytes: NAK bailout.
[ 537.403724] i2c i2c-8: sendbytes: NAK bailout.
[ 537.404259] i2c i2c-8: sendbytes: NAK bailout.
[ 537.404794] i2c i2c-8: sendbytes: NAK bailout.
[ 537.405329] i2c i2c-8: sendbytes: NAK bailout.
[ 537.405867] i2c i2c-8: sendbytes: NAK bailout.
[ 537.406421] i2c i2c-8: sendbytes: NAK bailout.
[ 537.406957] i2c i2c-8: sendbytes: NAK bailout.
[ 537.407492] i2c i2c-8: sendbytes: NAK bailout.
[ 537.408027] i2c i2c-8: sendbytes: NAK bailout.
[ 537.408562] i2c i2c-8: sendbytes: NAK bailout.
[ 537.409097] i2c i2c-8: sendbytes: NAK bailout.
[ 537.409633] i2c i2c-8: sendbytes: NAK bailout.
[ 537.410189] i2c i2c-8: sendbytes: NAK bailout.
[ 537.410724] i2c i2c-8: sendbytes: NAK bailout.
[ 537.411260] i2c i2c-8: sendbytes: NAK bailout.
[ 537.411795] i2c i2c-8: sendbytes: NAK bailout.
[ 537.412330] i2c i2c-8: sendbytes: NAK bailout.
[ 537.412865] i2c i2c-8: sendbytes: NAK bailout.
[ 537.413400] i2c i2c-8: sendbytes: NAK bailout.
[ 537.413955] i2c i2c-8: sendbytes: NAK bailout.
[ 537.414495] i2c i2c-8: sendbytes: NAK bailout.
[ 537.415030] i2c i2c-8: sendbytes: NAK bailout.
[ 537.415588] i2c i2c-8: sendbytes: NAK bailout.
[ 537.416125] i2c i2c-8: sendbytes: NAK bailout.
[ 537.416661] i2c i2c-8: sendbytes: NAK bailout.
[ 537.417198] i2c i2c-8: sendbytes: NAK bailout.
[ 537.417734] i2c i2c-8: sendbytes: NAK bailout.
[ 537.418292] i2c i2c-8: sendbytes: NAK bailout.
[ 537.418828] i2c i2c-8: sendbytes: NAK bailout.
[ 537.419363] i2c i2c-8: sendbytes: NAK bailout.
[ 537.419898] i2c i2c-8: sendbytes: NAK bailout.
[ 537.420434] i2c i2c-8: sendbytes: NAK bailout.
[ 537.420969] i2c i2c-8: sendbytes: NAK bailout.
[ 537.421504] i2c i2c-8: sendbytes: NAK bailout.
[ 537.422063] i2c i2c-8: sendbytes: NAK bailout.
[ 537.422600] i2c i2c-8: sendbytes: NAK bailout.
[ 537.423136] i2c i2c-8: sendbytes: NAK bailout.
[ 537.423672] i2c i2c-8: sendbytes: NAK bailout.
[ 537.424207] i2c i2c-8: sendbytes: NAK bailout.
[ 537.424742] i2c i2c-8: sendbytes: NAK bailout.
[ 537.425277] i2c i2c-8: sendbytes: NAK bailout.
[ 537.425812] i2c i2c-8: sendbytes: NAK bailout.
[ 537.426383] i2c i2c-8: sendbytes: NAK bailout.
[ 537.426918] i2c i2c-8: sendbytes: NAK bailout.
[ 537.427454] i2c i2c-8: sendbytes: NAK bailout.
[ 537.427989] i2c i2c-8: sendbytes: NAK bailout.
[ 537.428524] i2c i2c-8: sendbytes: NAK bailout.
[ 537.429059] i2c i2c-8: sendbytes: NAK bailout.
[ 537.429594] i2c i2c-8: sendbytes: NAK bailout.
[ 537.430158] i2c i2c-8: sendbytes: NAK bailout.
[ 537.430693] i2c i2c-8: sendbytes: NAK bailout.
[ 537.431228] i2c i2c-8: sendbytes: NAK bailout.
[ 537.431764] i2c i2c-8: sendbytes: NAK bailout.
[ 537.432299] i2c i2c-8: sendbytes: NAK bailout.
[ 537.432834] i2c i2c-8: sendbytes: NAK bailout.
[ 537.433369] i2c i2c-8: sendbytes: NAK bailout.
[ 537.433908] i2c i2c-8: sendbytes: NAK bailout.
[ 537.434454] i2c i2c-8: sendbytes: NAK bailout.
[ 537.434989] i2c i2c-8: sendbytes: NAK bailout.
[ 537.435525] i2c i2c-8: sendbytes: NAK bailout.
[ 537.436060] i2c i2c-8: sendbytes: NAK bailout.
[ 537.436595] i2c i2c-8: sendbytes: NAK bailout.
[ 537.437130] i2c i2c-8: sendbytes: NAK bailout.
[ 537.437666] i2c i2c-8: sendbytes: NAK bailout.
[ 537.438227] i2c i2c-8: sendbytes: NAK bailout.
[ 537.438763] i2c i2c-8: sendbytes: NAK bailout.
[ 537.439299] i2c i2c-8: sendbytes: NAK bailout.
[ 537.439834] i2c i2c-8: sendbytes: NAK bailout.
[ 537.440369] i2c i2c-8: sendbytes: NAK bailout.
[ 537.440904] i2c i2c-8: sendbytes: NAK bailout.
[ 537.441439] i2c i2c-8: sendbytes: NAK bailout.
[ 537.442012] i2c i2c-8: sendbytes: NAK bailout.
[ 537.442548] i2c i2c-8: sendbytes: NAK bailout.
[ 537.443080] i2c i2c-8: sendbytes: NAK bailout.
[ 537.443615] i2c i2c-8: sendbytes: NAK bailout.
[ 537.444150] i2c i2c-8: sendbytes: NAK bailout.
[ 537.444685] i2c i2c-8: sendbytes: NAK bailout.
[ 537.445220] i2c i2c-8: sendbytes: NAK bailout.
[ 537.445755] i2c i2c-8: sendbytes: NAK bailout.
[ 537.446314] i2c i2c-8: sendbytes: NAK bailout.
[ 537.446850] i2c i2c-8: sendbytes: NAK bailout.
[ 537.447385] i2c i2c-8: sendbytes: NAK bailout.
[ 537.447920] i2c i2c-8: sendbytes: NAK bailout.
[ 537.448455] i2c i2c-8: sendbytes: NAK bailout.
[ 537.448990] i2c i2c-8: sendbytes: NAK bailout.
[ 537.449526] i2c i2c-8: sendbytes: NAK bailout.
[ 537.450095] i2c i2c-8: sendbytes: NAK bailout.
[ 537.450631] i2c i2c-8: sendbytes: NAK bailout.
[ 537.451166] i2c i2c-8: sendbytes: NAK bailout.
[ 537.451701] i2c i2c-8: sendbytes: NAK bailout.
[ 537.452237] i2c i2c-8: sendbytes: NAK bailout.
[ 537.452772] i2c i2c-8: sendbytes: NAK bailout.
[ 537.453307] i2c i2c-8: sendbytes: NAK bailout.
[ 537.453842] i2c i2c-8: sendbytes: NAK bailout.
[ 537.454400] i2c i2c-8: sendbytes: NAK bailout.
[ 537.454935] i2c i2c-8: sendbytes: NAK bailout.
[ 537.455470] i2c i2c-8: sendbytes: NAK bailout.
[ 537.456009] i2c i2c-8: sendbytes: NAK bailout.
[ 537.456544] i2c i2c-8: sendbytes: NAK bailout.
[ 537.457080] i2c i2c-8: sendbytes: NAK bailout.
[ 537.457615] i2c i2c-8: sendbytes: NAK bailout.
[ 537.458176] i2c i2c-8: sendbytes: NAK bailout.
[ 537.458711] i2c i2c-8: sendbytes: NAK bailout.
[ 537.459246] i2c i2c-8: sendbytes: NAK bailout.
[ 537.459782] i2c i2c-8: sendbytes: NAK bailout.
[ 537.460317] i2c i2c-8: sendbytes: NAK bailout.
[ 537.460852] i2c i2c-8: sendbytes: NAK bailout.
[ 537.461387] i2c i2c-8: sendbytes: NAK bailout.
[ 537.461932] i2c i2c-8: sendbytes: NAK bailout.
[ 537.462487] i2c i2c-8: sendbytes: NAK bailout.
[ 537.463022] i2c i2c-8: sendbytes: NAK bailout.
[ 537.463557] i2c i2c-8: sendbytes: NAK bailout.
[ 537.464092] i2c i2c-8: sendbytes: NAK bailout.
[ 537.464627] i2c i2c-8: sendbytes: NAK bailout.
[ 537.465162] i2c i2c-8: sendbytes: NAK bailout.
[ 537.465698] i2c i2c-8: sendbytes: NAK bailout.
[ 537.466257] i2c i2c-8: sendbytes: NAK bailout.
[ 537.466793] i2c i2c-8: sendbytes: NAK bailout.
[ 597.930226] i2c i2c-8: sendbytes: NAK bailout.
[ 597.930764] i2c i2c-8: sendbytes: NAK bailout.
[ 597.931299] i2c i2c-8: sendbytes: NAK bailout.
[ 597.931834] i2c i2c-8: sendbytes: NAK bailout.
[ 597.932369] i2c i2c-8: sendbytes: NAK bailout.
[ 597.932904] i2c i2c-8: sendbytes: NAK bailout.
[ 597.933440] i2c i2c-8: sendbytes: NAK bailout.
[ 597.934006] i2c i2c-8: sendbytes: NAK bailout.
[ 597.934542] i2c i2c-8: sendbytes: NAK bailout.
[ 597.935077] i2c i2c-8: sendbytes: NAK bailout.
[ 597.935613] i2c i2c-8: sendbytes: NAK bailout.
[ 597.936148] i2c i2c-8: sendbytes: NAK bailout.
[ 597.936683] i2c i2c-8: sendbytes: NAK bailout.
[ 597.937218] i2c i2c-8: sendbytes: NAK bailout.
[ 597.937754] i2c i2c-8: sendbytes: NAK bailout.
[ 597.938314] i2c i2c-8: sendbytes: NAK bailout.
[ 597.938849] i2c i2c-8: sendbytes: NAK bailout.
[ 597.939384] i2c i2c-8: sendbytes: NAK bailout.
[ 597.939919] i2c i2c-8: sendbytes: NAK bailout.
[ 597.940456] i2c i2c-8: sendbytes: NAK bailout.
[ 597.940992] i2c i2c-8: sendbytes: NAK bailout.
[ 597.941527] i2c i2c-8: sendbytes: NAK bailout.
[ 597.942092] i2c i2c-8: sendbytes: NAK bailout.
[ 597.942628] i2c i2c-8: sendbytes: NAK bailout.
[ 597.943163] i2c i2c-8: sendbytes: NAK bailout.
[ 597.943698] i2c i2c-8: sendbytes: NAK bailout.
[ 597.944233] i2c i2c-8: sendbytes: NAK bailout.
[ 597.944768] i2c i2c-8: sendbytes: NAK bailout.
[ 597.945303] i2c i2c-8: sendbytes: NAK bailout.
[ 597.945849] i2c i2c-8: sendbytes: NAK bailout.
[ 597.946388] i2c i2c-8: sendbytes: NAK bailout.
[ 597.946923] i2c i2c-8: sendbytes: NAK bailout.
[ 597.947459] i2c i2c-8: sendbytes: NAK bailout.
[ 597.947994] i2c i2c-8: sendbytes: NAK bailout.
[ 597.948529] i2c i2c-8: sendbytes: NAK bailout.
[ 597.949064] i2c i2c-8: sendbytes: NAK bailout.
[ 597.949599] i2c i2c-8: sendbytes: NAK bailout.
[ 597.950157] i2c i2c-8: sendbytes: NAK bailout.
[ 597.950693] i2c i2c-8: sendbytes: NAK bailout.
[ 597.951228] i2c i2c-8: sendbytes: NAK bailout.
[ 597.951763] i2c i2c-8: sendbytes: NAK bailout.
[ 597.952298] i2c i2c-8: sendbytes: NAK bailout.
[ 597.952833] i2c i2c-8: sendbytes: NAK bailout.
[ 597.953368] i2c i2c-8: sendbytes: NAK bailout.
[ 597.953936] i2c i2c-8: sendbytes: NAK bailout.
[ 597.954471] i2c i2c-8: sendbytes: NAK bailout.
[ 597.955006] i2c i2c-8: sendbytes: NAK bailout.
[ 597.955541] i2c i2c-8: sendbytes: NAK bailout.
[ 597.956077] i2c i2c-8: sendbytes: NAK bailout.
[ 597.956612] i2c i2c-8: sendbytes: NAK bailout.
[ 597.957147] i2c i2c-8: sendbytes: NAK bailout.
[ 597.957682] i2c i2c-8: sendbytes: NAK bailout.
[ 597.958258] i2c i2c-8: sendbytes: NAK bailout.
[ 597.958799] i2c i2c-8: sendbytes: NAK bailout.
[ 597.959335] i2c i2c-8: sendbytes: NAK bailout.
[ 597.959870] i2c i2c-8: sendbytes: NAK bailout.
[ 597.960406] i2c i2c-8: sendbytes: NAK bailout.
[ 597.960941] i2c i2c-8: sendbytes: NAK bailout.
[ 597.961476] i2c i2c-8: sendbytes: NAK bailout.
[ 597.962036] i2c i2c-8: sendbytes: NAK bailout.
[ 597.962571] i2c i2c-8: sendbytes: NAK bailout.
[ 597.963107] i2c i2c-8: sendbytes: NAK bailout.
[ 597.963642] i2c i2c-8: sendbytes: NAK bailout.
[ 597.964180] i2c i2c-8: sendbytes: NAK bailout.
[ 597.964716] i2c i2c-8: sendbytes: NAK bailout.
[ 597.965251] i2c i2c-8: sendbytes: NAK bailout.
[ 597.965786] i2c i2c-8: sendbytes: NAK bailout.
[ 597.966348] i2c i2c-8: sendbytes: NAK bailout.
[ 597.966888] i2c i2c-8: sendbytes: NAK bailout.
[ 597.967424] i2c i2c-8: sendbytes: NAK bailout.
[ 597.967958] i2c i2c-8: sendbytes: NAK bailout.
[ 597.968493] i2c i2c-8: sendbytes: NAK bailout.
[ 597.969028] i2c i2c-8: sendbytes: NAK bailout.
[ 597.969563] i2c i2c-8: sendbytes: NAK bailout.
[ 597.970119] i2c i2c-8: sendbytes: NAK bailout.
[ 597.970655] i2c i2c-8: sendbytes: NAK bailout.
[ 597.971190] i2c i2c-8: sendbytes: NAK bailout.
[ 597.971725] i2c i2c-8: sendbytes: NAK bailout.
[ 597.972260] i2c i2c-8: sendbytes: NAK bailout.
[ 597.972795] i2c i2c-8: sendbytes: NAK bailout.
[ 597.973331] i2c i2c-8: sendbytes: NAK bailout.
[ 597.973886] i2c i2c-8: sendbytes: NAK bailout.
[ 597.974427] i2c i2c-8: sendbytes: NAK bailout.
[ 597.974962] i2c i2c-8: sendbytes: NAK bailout.
[ 597.975497] i2c i2c-8: sendbytes: NAK bailout.
[ 597.976032] i2c i2c-8: sendbytes: NAK bailout.
[ 597.976567] i2c i2c-8: sendbytes: NAK bailout.
[ 597.977102] i2c i2c-8: sendbytes: NAK bailout.
[ 597.977638] i2c i2c-8: sendbytes: NAK bailout.
[ 597.978235] i2c i2c-8: sendbytes: NAK bailout.
[ 597.978772] i2c i2c-8: sendbytes: NAK bailout.
[ 597.979308] i2c i2c-8: sendbytes: NAK bailout.
[ 597.979854] i2c i2c-8: sendbytes: NAK bailout.
[ 597.980391] i2c i2c-8: sendbytes: NAK bailout.
[ 597.980927] i2c i2c-8: sendbytes: NAK bailout.
[ 597.981462] i2c i2c-8: sendbytes: NAK bailout.
[ 597.982029] i2c i2c-8: sendbytes: NAK bailout.
[ 597.982565] i2c i2c-8: sendbytes: NAK bailout.
[ 597.983100] i2c i2c-8: sendbytes: NAK bailout.
[ 597.983635] i2c i2c-8: sendbytes: NAK bailout.
[ 597.984171] i2c i2c-8: sendbytes: NAK bailout.
[ 597.984706] i2c i2c-8: sendbytes: NAK bailout.
[ 597.985241] i2c i2c-8: sendbytes: NAK bailout.
[ 597.985777] i2c i2c-8: sendbytes: NAK bailout.
[ 597.986329] i2c i2c-8: sendbytes: NAK bailout.
[ 597.986865] i2c i2c-8: sendbytes: NAK bailout.
[ 597.987400] i2c i2c-8: sendbytes: NAK bailout.
[ 597.987935] i2c i2c-8: sendbytes: NAK bailout.
[ 597.988471] i2c i2c-8: sendbytes: NAK bailout.
[ 597.989006] i2c i2c-8: sendbytes: NAK bailout.
[ 597.989541] i2c i2c-8: sendbytes: NAK bailout.
[ 597.990090] i2c i2c-8: sendbytes: NAK bailout.
[ 597.990625] i2c i2c-8: sendbytes: NAK bailout.
[ 597.991160] i2c i2c-8: sendbytes: NAK bailout.
[ 597.991695] i2c i2c-8: sendbytes: NAK bailout.
[ 597.992231] i2c i2c-8: sendbytes: NAK bailout.
[ 597.992766] i2c i2c-8: sendbytes: NAK bailout.
[ 597.993301] i2c i2c-8: sendbytes: NAK bailout.
[ 597.993849] i2c i2c-8: sendbytes: NAK bailout.
[ 597.994387] i2c i2c-8: sendbytes: NAK bailout.
[ 597.994923] i2c i2c-8: sendbytes: NAK bailout.
[ 597.995458] i2c i2c-8: sendbytes: NAK bailout.
[ 597.995993] i2c i2c-8: sendbytes: NAK bailout.
[ 597.996528] i2c i2c-8: sendbytes: NAK bailout.
[ 597.997063] i2c i2c-8: sendbytes: NAK bailout.
[ 597.997598] i2c i2c-8: sendbytes: NAK bailout.
[ 597.998152] i2c i2c-8: sendbytes: NAK bailout.
[ 597.998688] i2c i2c-8: sendbytes: NAK bailout.
It seems like the problem is with the i2c communicatin of tegra.
So I checked the “dmesg” of Jetson TX1 again, and found these suspicious lines I overlooked before:
[ 0.277292] I2C first dynamic bus number based on alias = 7
[ 2.077051] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/icm20628@68
[ 2.083234] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/ak8963@0d
[ 2.090058] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/bmp280@77
[ 2.096918] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/cm32180@48
[ 2.103852] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/iqs263@44
[ 2.161932] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 6.585113] i2c /dev entries driver
[ 6.594720] i2c i2c-6: of_i2c: modalias failure on /i2c@546c0000/tca6408@21
So obviously at least one other Ubuntu system on a desktop motherboard was able to successfully read and parse the EDID.
To clarify, which machine had this dmesg log? Was it the desktop Ubuntu? If the desktop was seeing this, then it means the desktop is more gracefully handling an error…if it is the JTX1, then there are a number of possibilities.
The later dmesg from JTX1 with the format of “i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/icm20628@68” looks like a firmware file issue. Basically it is referring to i2c controller physical address and a kernel feature not liking what it found. Has there been any kind of kernel change at all on the JTX1, or is it running with all of the default kernel configuration?
