I am trying to interface a MIPI camera (IMX477) with my custom carrier board for Jetson Nano. Initially the camera worked for a good amount of time but now the Jetson hangs/reboots while streaming the camera.
Here is the error thrown on the terminal-
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: TIMEOUT
I have captured the nvargus-daemon logs and found some reading about bad parameter… nvargus-daemon.txt (6.7 KB)
Setup: MIPI CSI camera (IMX477) → Jetson Nano on custom carrier board → Stream over Ethernet using GStreamer
@JerryChang , the connections are direct pin-to-pin from MIPI-CSI pinout on the camera to the SOM with ESD protection. I have also tested this without ESD protection diodes as well.
One unorthodox method I used here is that the camera is powered from external 3V3 supply. with common ground.
is it possible to probe the MIPI signaling while you’re enabling camera stream from software side.
it should be software issue if there’s high-speed sending to CSI brick.
Hi @JerryChang, Currently probing MIPI signal is difficult my my set of equipment will check with my contacts if any one has the apt tools. I have standard DSO which can measure up-to 100MHz, any other options with which I could debug?
