I tried to install Isaac REPL while following the tutorials, but it fails to start. It seems to be related to this:
ImportError: cannot import name ‘AnyFormattedText’ from ‘prompt_toolkit.formatted_text’
Sure, although unfortunately it’s not particularly interesting. I was following the tutorials, and got to the point where it tells you to go to Window > Extensions, search for Isaac REPL, and toggle it on. When I do that, I get the error.
2023-03-25 09:21:14 [5,503ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.repl. Error: cannot import name ‘get_event_loop’ from ‘prompt_toolkit.eventloop.utils’ (/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/prompt_toolkit/eventloop/utils.py). Traceback:
File “/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py/omni/ext/_impl/custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.repl/omni/isaac/repl/init.py”, line 10, in
from .extension import *
File “/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.repl/omni/isaac/repl/extension.py”, line 16, in
from prompt_toolkit.eventloop.utils import get_event_loop
ImportError: cannot import name ‘get_event_loop’ from ‘prompt_toolkit.eventloop.utils’ (/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/prompt_toolkit/eventloop/utils.py)
2023-03-25 09:21:14 [5,503ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.repl’ in ‘/home/anson/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.repl’ failed to load.
I tried something similar but that seemed to break other parts of the plugin. I was hoping that Nvidia would update the plugin to either use the new function, or require that it use prompt_toolkit <= 3.0.36 and figure out what other issues my result from that.
By default in 2022.2.1 the repl extension should package all of its dependencies in the pip_prebundle folder:
/exts/omni.isaac.repl/pip_prebundle
and use prompt_toolkit-3.0.20
its possible that if a newer prompt_toolkit was installed in the local python env that it might cause issues. if you run ./python.sh -m pip list is there another prompt-toolkit package installed and if so, does uninstalling fix the issue?
