2024-07-25 08:05:24 [35,306ms] [Error] [omni.ext._impl._internal] Failed to import python module omni.isaac.examples.user_examples from /home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/exts/omni.isaac.examples. Error: source code string cannot contain null bytes. Traceback:
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/omni/ext/_impl/_internal.py", line 187, in _custom_importer
return _import_public(ext_module.path, ext_module.name, reload_enabled)
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/carb/profiler/__init__.py", line 84, in wrapper
r = f(*args, **kwds)
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/omni/ext/_impl/_internal.py", line 94, in _import_public
module = import_module(module_name)
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
return importlib.import_module(name)
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/python/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 879, in exec_module
File "<frozen importlib._bootstrap_external>", line 1017, in get_code
File "<frozen importlib._bootstrap_external>", line 947, in source_to_code
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
ValueError: source code string cannot contain null bytes
2024-07-25 08:05:24 [35,306ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.examples.user_examples' in '/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/exts/omni.isaac.examples' failed to load.
At:
/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/omni/ext/_impl/_internal.py(213): startup
/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/kit/kernel/py/omni/ext/_impl/_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2): <module>
2024-07-25 08:05:24 [35,306ms] [Error] [omni.ext.plugin] [ext: omni.isaac.examples-2.0.0] Failed to startup python extension.
2024-07-25 08:05:24 [35,512ms] [Error] [omni.graph.core._impl.extension] OGN node registration completed with errors: source code string cannot contain null bytes
2024-07-25 08:05:27 [38,231ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
2024-07-25 08:05:27 [38,246ms] [Error] [omni.ext._impl._internal] Failed to import python module snakeviz from /home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/extscache/omni.kit.profiler.window-2.2.1/pip_prebundle_snakeviz. Error: source code string cannot contain null bytes. Traceback:
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/extscache/omni.kit.profiler.window-2.2.1/pip_prebundle_snakeviz/snakeviz/__init__.py", line 2, in <module>
from .ipymagic import *
File "/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/extscache/omni.kit.profiler.window-2.2.1/pip_prebundle_snakeviz/snakeviz/ipymagic.py", line 28, in <module>
from IPython.core.magic import Magics, magics_class, line_cell_magic
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/IPython/__init__.py", line 54, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/IPython/core/application.py", line 26, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/IPython/core/crashhandler.py", line 27, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/IPython/core/ultratb.py", line 104, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/stack_data/__init__.py", line 1, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/stack_data/core.py", line 18, in <module>
File "/home/xiaolinli/.local/share/ov/data/Kit/Isaac-Sim/4.0/pip3-envs/default/pure_eval/__init__.py", line 5, in <module>
2024-07-25 08:05:27 [38,247ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'snakeviz' in '/home/xiaolinli/.local/share/ov/pkg/isaac-sim-4.0.0/extscache/omni.kit.profiler.window-2.2.1/pip_prebundle_snakeviz' failed to load.
At:
2024-07-25 08:05:27 [38,247ms] [Error] [omni.ext.plugin] [ext: omni.kit.profiler.window-2.2.1] Failed to startup python extension.
2024-07-25 08:05:29 [39,705ms] [Error] [omni.isaac.vscode.extension] [Errno 98] error while attempting to bind on address ('0.0.0.0', 8226): address already in use
I have the same problem, and I have tried to only import os in user_examples init.py, the same error occurs. Can anyone help?
I have solved this problem, it’s because my server has encrypt software which will convert .py file to binary which will lead to isaac sim recompile failed, without encrypt it can work well with .py encoded as ascii.
