I’m using isaac-sim-2022.1.0.
source ~/.local/share/ov/pkg/isaac_sim-2022.1.0/setup_conda_env.sh
I failed to start isaac-sim from python.
2024-05-23 08:10:56 [1,752ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.kit.asset_converter from /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37. Error: /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/asset_converter_native_bindings/libs/libomniverse_asset_converter.so: undefined symbol: _ZNK10aiMaterial7GetNameEv. Traceback:
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py”, line 151, in _custom_importer
return _import_public(ext_module.path, ext_module.name)
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py”, line 78, in _import_public
module = import_module(module_name)
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/omni/kit/asset_converter/init.py”, line 1, in
from .impl import *
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/omni/kit/asset_converter/impl/init.py”, line 1, in
from .extension import AssetImporterExtension, get_instance
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/omni/kit/asset_converter/impl/extension.py”, line 18, in
from .task_manager import AssetConverterTaskManager, AssetConverterFutureWrapper
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/omni/kit/asset_converter/impl/task_manager.py”, line 6, in
from …native_bindings import *
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/omni/kit/asset_converter/native_bindings/init.py”, line 9, in
from asset_converter_native_bindings._assetconverter import *
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/asset_converter_native_bindings/init.py”, line 40, in
ctypes.CDLL(os.path.join(os.path.dirname(file), “libs/libomniverse_asset_converter.so”))
File “/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/ctypes/init.py”, line 364, in init
self._handle = _dlopen(self._name, mode)
OSError: /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/asset_converter_native_bindings/libs/libomniverse_asset_converter.so: undefined symbol: _ZNK10aiMaterial7GetNameEv
2024-05-23 08:10:56 [1,752ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.asset_converter’ in ‘/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37’ failed to load.
At:
/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(177): startup
/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(268): startup_extension
PythonExtension.cpp::startup()(2):
/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py(284): _start_app
/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py(164): init
/home/zx/rlmmbp/learned_robot_placement/envs/isaac_env_mushroom.py(76): init
learned_robot_placement/scripts/train_task.py(194): experiment
learned_robot_placement/scripts/train_task.py(419): parse_hydra_configs_and_run_exp
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/core/utils.py(160): run_job
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/_internal/hydra.py(106): run
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/_internal/utils.py(381):
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/_internal/utils.py(211): run_and_report
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/_internal/utils.py(378): _run_hydra
/home/zx/anaconda3/envs/isaac-sim-lrp/lib/python3.7/site-packages/hydra/main.py(52): decorated_main
learned_robot_placement/scripts/train_task.py(423):
2024-05-23 08:10:56 [1,752ms] [Error] [omni.ext.plugin] [ext: omni.kit.asset_converter-1.2.30] Failed to startup python extension.
[1.783s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.828s] [ext: omni.kit.search_core-1.0.2] startup
[1.841s] [ext: omni.renderer-rtx-0.0.0] startup
[1.846s] [ext: omni.kit.widget.graph-1.4.2] startup
[1.907s] [ext: omni.kit.widget.filebrowser-2.2.26] startup
[1.913s] [ext: omni.kit.window.popup_dialog-2.0.7] startup
[1.922s] [ext: omni.mdl.neuraylib-0.1.0] startup
[1.927s] [ext: omni.kit.widget.path_field-2.0.3] startup
[1.929s] [ext: omni.kit.widget.versioning-1.3.8] startup
[1.932s] [ext: omni.kit.notification_manager-1.0.5] startup
[1.935s] [ext: omni.kit.widget.browser_bar-2.0.3] startup
[1.937s] [ext: omni.kit.menu.utils-1.2.11] startup
[1.949s] [ext: omni.kit.window.filepicker-2.4.29] startup
2024-05-23 08:10:56 [1,998ms] [Error] [omni.ext.impl.internal] Failed to import python module omni.kit.window.filepicker from /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker. Error:
Error in 'pxrInternal_v0_20__pxrReserved_::PlugPlugin::Load’ at line 258 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/base/plug/plugin.cpp : 'Failed to load plugin ‘Omniverse USD Plugin’: /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/asset_converter_native_bindings/libs/libomniverse_asset_converter.so: undefined symbol: ZNK10aiMaterial7GetNameEv in ‘/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/carb_gfx/libomniclient.so’’
Error in 'pxrInternal_v0_20__pxrReserved::{anonymous}::_CreateResolver’ at line 175 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/ar/resolver.cpp : ‘Failed to load plugin Omniverse USD Plugin for OmniUsdResolver’. Traceback:
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/init.py”, line 35, in
from .dialog import FilePickerDialog
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/dialog.py”, line 14, in
from .widget import FilePickerWidget
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/widget.py”, line 19, in
from .api import FilePickerAPI
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/api.py”, line 21, in
from .model import FilePickerModel
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/model.py”, line 21, in
from . import asset_types
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/asset_types.py”, line 154, in
_init_asset_types()
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/asset_types.py”, line 144, in _init_asset_types
x for x in omni.usd.readable_usd_dotted_file_exts()
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extscore/omni.usd/omni/usd/_impl/utils.py”, line 97, in readable_usd_dotted_file_exts
_bake_readable_usd_file_info()
File “/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extscore/omni.usd/omni/usd/_impl/utils.py”, line 74, in bake_readable_usd_file_info
ext for ext in Sdf.FileFormat.FindAllFileFormatExtensions()
File "/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extscore/omni.usd/omni/usd/impl/utils.py", line 75, in
if Sdf.FileFormat.FindByExtension(ext, “usd”))
pxr.Tf.ErrorException:
Error in 'pxrInternal_v0_20__pxrReserved::PlugPlugin::Load’ at line 258 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/base/plug/plugin.cpp : 'Failed to load plugin ‘Omniverse USD Plugin’: /home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.asset_converter-1.2.30+lx64.r.cp37/asset_converter_native_bindings/libs/libomniverse_asset_converter.so: undefined symbol: ZNK10aiMaterial7GetNameEv in ‘/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/carb_gfx/libomniclient.so’’
2024-05-23 08:10:56 [1,998ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.window.filepicker’ in ‘/home/zx/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.kit.window.filepicker’ failed to load.
At:
2024-05-23 08:10:56 [1,998ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.filepicker-2.4.29] Failed to startup python extension.
