Can not open isaac sim by python.sh
Hi:
I try to run my python code by typing
./python.sh test.py
but it stuck on
[6.241s] Simulation App Starting
[7.398s] app ready
and not show the all isaac sim, it show up like this
when I use the omniverse launcher to launch isaac sim, it can work perfectly.
I tried both on Linux 20.04 and windows, both of them have the same problem, does anyone knows how to fix it?
this is my log
Starting kit application with the fillowing args: [‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py’, ‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/apps/omni.isaac.sim.python.kit’, ‘–/app/tokens/exe-path=/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/kit’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–ext-folder’, ‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/exts’, ‘–ext-folder’, ‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/apps’, ‘–/physics/cudaDevice=0’, ‘–portable’]
Passing the following args to the base kit application:
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[Info] [carb] Logging to file: /home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/kit/logs/Kit/Isaac-Sim/2022.1/kit_20221201_105943.log
2022-12-01 02:59:43 [4ms] [Warning] [omni.ext.plugin] [ext: omni.drivesim.sensors.nv.lidar] Extensions config ‘extension.toml’ doesn’t exist ‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.drivesim.sensors.nv.lidar’ or ‘/home/oem/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.drivesim.sensors.nv.lidar/config’
[0.077s] [ext: omni.stats-0.0.0] startup
[0.113s] [ext: omni.gpu_foundation-0.0.0] startup
2022-12-01 02:59:44 [117ms] [Warning] [carb] FrameworkImpl::setDefaultPlugin(client: omni.gpu_foundation_factory.plugin, desc : [carb::graphics::Graphics v2.5], plugin : carb.graphics-vulkan.plugin) failed. Plugin selection is locked, because the interface was previously acquired by:
[0.131s] [ext: carb.windowing.plugins-1.0.0] startup
[0.143s] [ext: omni.assets.plugins-0.0.0] startup
[0.145s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 515.65.1 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2060 | Yes: 0 | | 6390 MB | 10de | 0 |
| | | | | | 1f08 | d3bf12bf… |
| OS: Linux oem-System-Product-Name, Version: 5.15.0-53-generic
| Processor: Intel(R) Core™ i7-7700 CPU @ 3.60GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 7880 | Free Memory: 5010
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.992s] [ext: omni.kit.pipapi-0.0.0] startup
[1.010s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.028s] [ext: omni.isaac.core_archive-1.2.0] startup
[1.273s] [ext: omni.usd.config-1.0.0] startup
[1.276s] [ext: omni.usd.libs-1.0.0] startup
[1.462s] [ext: omni.kit.pip_torch-1_11_0-0.1.3] startup
[1.527s] [ext: omni.isaac.ml_archive-1.1.0] startup
[1.609s] [ext: omni.kit.loop-isaac-0.1.0] startup
[1.610s] [ext: omni.kit.async_engine-0.0.0] startup
[1.612s] [ext: omni.appwindow-1.0.0] startup
[1.623s] [ext: omni.client-0.1.0] startup
[1.639s] [ext: omni.kit.test-0.0.0] startup
[1.641s] [ext: omni.kit.renderer.core-0.0.0] startup
[1.844s] [ext: omni.ui-2.10.3] startup
[1.869s] [ext: carb.audio-0.1.0] startup
[1.891s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.894s] [ext: omni.uiaudio-1.0.0] startup
[1.896s] [ext: omni.kit.uiapp-0.0.0] startup
[1.896s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.946s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.955s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.968s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.979s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.032s] [ext: omni.kit.commands-1.2.2] startup
[2.039s] [ext: omni.timeline-1.0.2] startup
[2.042s] [ext: omni.hydra.scene_delegate-0.2.0] startup
[2.053s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[2.055s] [ext: omni.usd-1.5.3] startup
[2.339s] [ext: omni.kit.asset_converter-1.2.31] startup
[2.384s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.416s] [ext: omni.usd.schema.isaac-0.2.0] startup
[2.465s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[2.474s] [ext: omni.kvdb-0.0.0] startup
[2.478s] [ext: omni.usdphysics-1.4.15] startup
[2.481s] [ext: omni.graph.tools-1.4.0] startup
[2.519s] [ext: omni.localcache-0.0.0] startup
[2.527s] [ext: omni.kit.stage_templates-1.1.2] startup
[2.530s] [ext: omni.convexdecomposition-1.4.15] startup
[2.539s] [ext: omni.physics.tensors-0.1.0] startup
[2.549s] [ext: omni.physx-1.4.15-5.1] startup
[2.575s] [ext: omni.graph.core-2.29.1] startup
[2.582s] [ext: omni.kit.menu.utils-1.2.11] startup
[2.606s] [ext: omni.physx.tensors-0.1.0] startup
[2.615s] [ext: omni.graph-1.23.0] startup
[2.745s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.749s] [ext: omni.kit.window.script_editor-1.6.2] startup
[2.764s] [ext: omni.kit.search_core-1.0.2] startup
[2.767s] [ext: omni.isaac.dynamic_control-1.1.0] startup
[2.779s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.785s] [ext: omni.kit.widget.filebrowser-2.2.27] startup
[2.797s] [ext: omni.kit.widget.path_field-2.0.3] startup
[2.800s] [ext: omni.kit.notification_manager-1.0.5] startup
[2.809s] [ext: omni.kit.widget.versioning-1.3.8] startup
[2.813s] [ext: omni.kit.widget.browser_bar-2.0.3] startup
[2.816s] [ext: omni.kit.window.popup_dialog-2.0.8] startup
[2.820s] [ext: omni.mdl.neuraylib-0.1.0] startup
[2.824s] [ext: omni.kit.window.filepicker-2.4.30] startup
OmniAssetFileFormat
[2.890s] [ext: omni.kit.menu.create-1.0.2] startup
[2.892s] [ext: omni.mdl-0.1.0] startup
[2.922s] [ext: omni.kit.window.file_importer-1.0.4] startup
[2.924s] [ext: omni.kit.window.file_exporter-1.0.4] startup
[2.925s] [ext: omni.kit.material.library-1.3.10] startup
[2.930s] [ext: omni.kit.window.drop_support-1.0.0] startup
[2.931s] [ext: omni.kit.window.file-1.3.16] startup
[2.936s] [ext: omni.kit.context_menu-1.3.9] startup
[2.941s] [ext: omni.kit.window.property-1.6.3] startup
[2.944s] [ext: omni.kit.window.content_browser-2.4.28] startup
[2.968s] [ext: omni.kit.widget.stage-2.6.15] startup
[2.976s] [ext: omni.isaac.version-1.0.0] startup
[2.977s] [ext: omni.kit.property.usd-3.14.9] startup
[3.018s] [ext: omni.kit.viewport.legacy_gizmos-1.0.0] startup
[3.023s] [ext: omni.hydra.rtx-0.1.0] startup
[3.038s] [ext: omni.renderer-rtx-0.0.0] startup
[3.041s] [ext: omni.hydra.engine.stats-1.0.0] startup
[3.048s] [ext: omni.debugdraw-0.1.0] startup
[3.056s] [ext: omni.kit.widget.settings-1.0.0] startup
[3.062s] [ext: omni.kit.window.viewport-0.0.0] startup
[3.955s] [ext: omni.kit.widget.prompt-1.0.1] startup
[3.957s] [ext: omni.kit.widget.graph-1.4.3] startup
[3.967s] [ext: omni.kit.window.preferences-1.2.1] startup
[4.011s] [ext: omni.ui_query-1.1.1] startup
[4.013s] [ext: omni.graph.ui-1.6.1] startup
[4.039s] [ext: omni.kit.ui_test-1.2.2] startup
[4.042s] [ext: omni.graph.action-1.18.0] startup
[4.096s] [ext: omni.kit.widget.searchfield-1.0.6] startup
[4.098s] [ext: omni.kit.usd_undo-0.1.0] startup
[4.102s] [ext: omni.graph.scriptnode-0.5.0] startup
[4.105s] [ext: omni.physx.commands-1.4.15-5.1] startup
[4.110s] [ext: omni.graph.nodes-1.26.0] startup
[4.128s] [ext: omni.command.usd-1.0.1] startup
[4.131s] [ext: omni.kit.window.extensions-1.1.0] startup
[4.138s] [ext: omni.syntheticdata-0.2.1] startup
[4.177s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[4.183s] [ext: omni.warp-0.2.2] startup
Warp initialized:
Version: 0.2.2
CUDA device: NVIDIA GeForce RTX 2060
Kernel cache: /home/oem/.cache/warp/0.2.2
[4.937s] [ext: omni.isaac.ui-0.2.1] startup
[4.939s] [ext: omni.replicator.core-1.4.3] startup
[5.117s] [ext: omni.isaac.core-1.24.3] startup
[5.241s] [ext: omni.physx.ui-1.4.15-5.1] startup
[5.337s] [ext: omni.kit.property.material-1.8.5] startup
[5.339s] [ext: omni.kit.window.toolbar-1.2.4] startup
[5.346s] [ext: omni.isaac.core_nodes-0.13.0] startup
[5.362s] [ext: omni.physx.demos-1.4.15-5.1] startup
[5.366s] [ext: omni.kit.property.physx-0.1.0] startup
2022-12-01 02:59:49 [5,485ms] [Warning] [omni.physx.plugin] Deprecated: getSimulationEventStream is deprecated, please use getSimulationEventStreamV2
[5.498s] [ext: omni.physx.tests-1.4.15-5.1] startup
[5.711s] [ext: omni.isaac.wheeled_robots-0.5.8] startup
[5.723s] [ext: omni.kit.menu.common-1.0.0] startup
[5.724s] [ext: omni.physx.vehicle-1.4.15-5.1] startup
[5.737s] [ext: omni.physx.cct-1.4.15-5.1] startup
[5.801s] [ext: omni.physx.camera-1.4.15-5.1] startup
[5.808s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[5.811s] [ext: omni.ui.scene-1.5.0] startup
[5.818s] [ext: omni.physx.bundle-1.4.15-5.1] startup
[5.818s] [ext: omni.kit.window.stage-2.3.7] startup
[5.821s] [ext: omni.replicator.composer-1.1.3] startup
[5.838s] [ext: omni.isaac.lula-1.1.0] startup
[5.849s] [ext: omni.rtx.window.settings-0.6.1] startup
[5.855s] [ext: omni.isaac.surface_gripper-0.1.2] startup
[5.860s] [ext: omni.isaac.motion_planning-0.2.0] startup
[5.869s] [ext: omni.rtx.settings.core-0.5.5] startup
[5.876s] [ext: omni.isaac.manipulators-1.0.1] startup
[5.878s] [ext: omni.isaac.motion_generation-3.6.1] startup
[5.883s] [ext: omni.kit.widget.zoombar-1.0.3] startup
[5.884s] [ext: omni.kit.graph.delegate.default-1.0.15] startup
[5.886s] [ext: omni.isaac.franka-0.3.0] startup
[5.887s] [ext: omni.kit.browser.core-2.0.12] startup
[5.893s] [ext: omni.kit.graph.editor.core-1.3.3] startup
[5.896s] [ext: omni.kit.graph.usd.commands-1.1.0] startup
[5.897s] [ext: omni.kit.browser.folder.core-1.1.13] startup
[5.900s] [ext: omni.kit.graph.widget.variables-2.0.2] startup
[5.901s] [ext: omni.kit.graph.delegate.modern-1.6.0] startup
[5.903s] [ext: omni.kit.selection-0.1.0] startup
[5.904s] [ext: omni.isaac.debug_draw-0.1.2] startup
[5.911s] [ext: omni.graph.window.core-1.23.4] startup
[5.917s] [ext: omni.graph.instancing-1.1.4] startup
[5.925s] [ext: omni.kit.menu.edit-1.0.6] startup
[5.928s] [ext: omni.isaac.isaac_sensor-1.0.2] startup
2022-12-01 02:59:49 [5,926ms] [Warning] [omni.physx.plugin] Deprecated: getSimulationEventStream is deprecated, please use getSimulationEventStreamV2
[5.940s] [ext: omni.graph.tutorials-1.1.2] startup
[5.956s] [ext: omni.graph.window.action-1.3.8] startup
[5.958s] [ext: omni.kit.widget.live-0.1.0] startup
[5.963s] [ext: omni.kit.widget.layers-1.5.17] startup
[5.977s] [ext: omni.graph.bundle.action-1.0.0] startup
[5.977s] [ext: omni.isaac.range_sensor-0.4.3] startup
[6.009s] [ext: omni.kit.property.layer-1.1.2] startup
[6.012s] [ext: omni.replicator.isaac-1.3.2] startup
[6.126s] [ext: omni.isaac.kit-0.2.1] startup
[6.127s] [ext: omni.graph.window.generic-1.3.8] startup
[6.129s] [ext: omni.isaac.utils-0.1.11] startup
[6.132s] [ext: omni.kit.property.audio-1.0.5] startup
[6.134s] [ext: omni.kit.property.skel-1.0.1] startup
[6.135s] [ext: omni.kit.property.render-1.1.0] startup
[6.136s] [ext: omni.kit.property.camera-1.0.3] startup
[6.137s] [ext: omni.kit.property.geometry-1.2.0] startup
[6.141s] [ext: omni.kit.property.light-1.0.5] startup
[6.143s] [ext: omni.kit.property.transform-1.0.2] startup
[6.146s] [ext: omni.isaac.universal_robots-0.3.0] startup
[6.147s] [ext: omni.isaac.occupancy_map-0.2.4] startup
[6.160s] [ext: omni.kit.window.console-0.2.0] startup
[6.168s] [ext: omni.kit.window.status_bar-0.1.1] startup
[6.174s] [ext: omni.kit.property.bundle-1.2.4] startup
[6.175s] [ext: omni.kit.menu.file-1.0.8] startup
[6.177s] [ext: omni.kit.manipulator.viewport-1.0.6] startup
[6.181s] [ext: omni.isaac.urdf-0.4.0] startup
[6.216s] [ext: omni.isaac.dofbot-0.3.0] startup
[6.216s] [ext: omni.kit.window.title-1.1.2] startup
[6.218s] [ext: omni.kit.profiler.window-1.4.4] startup
[6.223s] [ext: omni.graph.visualization.nodes-1.1.1] startup
[6.229s] [ext: omni.isaac.synthetic_utils-0.3.5] startup
[6.232s] [ext: semantics.schema.editor-0.2.3] startup
[6.240s] [ext: omni.isaac.sim.python-2022.1.1] startup
[7.398s] app ready
Hi @leo.wu2. Welcome to the forums! I’ve gone ahead and moved this to the Isaac Sim forum for you.
Hi - Sorry for the delay in the response. Let us know if you still having this issue/question with the latest Isaac Sim 2022.2.1 release.
