Can not launch any python file
Hello, so I have few problem with isaac sim installation related here
But i thing it’s ok, I can launch Isaac sim websocket. but now, I am pursuing with the tutorial of isaac sim.
(https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_required_workflows.html)
So, I can manually launch the simulation of follow target robot, by selecting it, in the menu at upper left of the screen in the Isaac examples menu.
But when I tape this command in the isaac folder: ./python.sh standalone_examples/api/omni.isaac.franka/follow_target.py
I have this error :
CLI follow_target (11.2 KB)
I don’t understand why. i can launch manually the simulation but not with command line and python file.
Virtual machine Ubuntu 18.04 os
Quadro RTX 6000
driver : nvidia 470.94
cuda : 11.4
Thank you for your help.
I found this but i don’t know what to do with this information.
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/known_issues.html
  1. When running samples from the standalone_examples via ./python.sh they might not exit/shutdown cleanly:
    [Warning] [carb.tasking.plugin] Leaking 1 carb::tasking::Counter instances!
    Shutting Down Complete
    ./python.sh: line 27: 8164 Segmentation fault (core dumped) $python_exe $@
    There was an error running python
The standalone python samples cannot run headless by default.
You will need to modify the example to set
"headless": False
to True
and then see Python Environment — Omniverse Robotics documentation
standalone_examples/api/omni.isaac.kit/livestream.py
on how to enable the livestream client for a standalone python sample
I also have the same issue, I can not even load the robot from the app itself!
I did change the
“Headless”: True
still encountering the same error in CLI!
why is this example still not loading even in the application?
Hi @ahn.paf - Have you gone through the latest documentation?
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/manual_standalone_python.html#livestream
Hi, I actually still cannot load the example through the code, I should only import it from examples in the toolbar, in this way, it is not tracking my curser as it should be.
