I am trying to run Isaac Sim standalone using Python on Windows 11 (C:\Users\usr\AppData\Local\ov\pkg\isaac-sim-4.2.0\standalone_examples\api\omni.isaac.core\add_cubes.py). However, when I try to run this program on the command prompt, I get the following error (as shown in the attached image), and the program doesn’t work. I would appreciate it if someone could provide a solution. Thank you in advance.
@k.akamine.0310 i am just another user, but perhaps disclose your system/hardware spec first might help provide more context in order to navigate this issue.
out of curiosity - if you were to go into Window’s device manager and disable the display driver listed as Microsoft Direct3D12, would that change the launch behavior?
I had an issue a while back that was to do with multiple GPUs as far as i know its been resolved. One thing to try is disable your second GPU in device manager and try to run it again. Also I see its a vulcan error. You could download the latest SDK for vulcan, I tried this for a separate problem and it didnt fix it. I know there is some strange bugs in this version related to vulcan… I’m not 100% on your issue but it seems a few people inculding myself have issues related to vulcan on the latest build…
I selected NVIDIA GeForce RTX 4090 from the Device Manager and checked the driver from its properties, but I couldn’t find anything named Microsoft Direct3D12.
If I am checking the wrong location, I would appreciate it if you could let me know.
We recommend installing the Latest Production Branch Version drivers from the Unix Driver Archive using the .run installer on Linux, if you are on a new GPU or experiencing issues with the current drivers.
@k.akamine.0310 Have you resolved this issue? Could you try the latest Windows Drivers and see if the same error persists?
If the issue continues, it might be related to a multi-GPU problem that has been mentioned. You could try disabling the other GPUs or running Isaac Sim with the following flag:
