I meet the problem same as: https://forums.developer.nvidia.com/t/isaac-2022-2-1-vkcreateinstance-failed-vulkan-1-1-is-not-supported-or-your-driver-requires-an-update/247938
First error is [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
then is like: Failed to import python module omni.genproc.ui. Error: No module named 'omni.genproc.core'. Traceback:
And in my wsl, the file inside /etc/vulkan is as follows:
explicit_layer.d icd.d implicit_layer.d
there is no duplicated file. Please tell me how fix it. Thanks.
Full log is:
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230909_104620.log
2023-09-09 10:46:20 [41ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.lidar' or '/isaac-sim/exts/omni.sensors.nv.lidar/config'
2023-09-09 10:46:20 [41ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.radar' or '/isaac-sim/exts/omni.sensors.nv.radar/config'
[0.258s] [ext: omni.stats-0.0.0] startup
[0.289s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.305s] [ext: omni.assets.plugins-0.0.0] startup
[0.312s] [ext: omni.gpu_foundation-0.0.0] startup
[0.347s] [ext: carb.windowing.plugins-1.0.0] startup
[0.455s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-09-09 10:46:22 [1,861ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2023-09-09 10:46:22 [1,861ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2023-09-09 10:46:22 [1,861ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2023-09-09 10:46:23 [3,026ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2023-09-09 10:46:23 [3,026ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2023-09-09 10:46:23 [3,026ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2023-09-09 10:46:23 [3,026ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices for compatibilityMode!
[3.054s] [ext: omni.kit.pipapi-0.0.0] startup
[3.070s] [ext: omni.usd.config-1.0.0] startup
[3.075s] [ext: omni.usd.libs-1.0.0] startup
[3.330s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.337s] [ext: omni.kit.async_engine-0.0.0] startup
[3.339s] [ext: omni.kit.loop-default-0.1.1] startup
[3.340s] [ext: omni.kit.test-0.0.0] startup
[3.415s] [ext: omni.usd.schema.semantics-0.0.0] startup
[3.483s] [ext: omni.usd.schema.audio-0.0.0] startup
[3.495s] [ext: omni.client-0.1.1] startup
[3.519s] [ext: omni.iray.libs-0.0.0] startup
[3.571s] [ext: omni.volume-0.1.0] startup
[3.576s] [ext: omni.usd.core-1.0.4] startup
[3.583s] [ext: omni.mdl.neuraylib-0.1.0] startup
[3.590s] [ext: omni.hydra.rtx-0.1.0] startup
[3.616s] [ext: omni.hydra.iray-0.1.0] startup
[3.621s] [ext: omni.isaac.core_archive-2.0.1] startup
[3.795s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[3.799s] [ext: omni.isaac.ml_archive-1.1.0] startup
[3.862s] [ext: omni.services.pip_archive-0.4.2] startup
[3.866s] [ext: omni.appwindow-1.0.1] startup
[3.870s] [ext: omni.kit.renderer.core-0.0.0] startup
2023-09-09 10:46:24 [3,845ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
[3.879s] [ext: omni.kit.renderer.capture-0.0.0] startup
[3.885s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2023-09-09 10:46:24 [3,864ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
[3.893s] [ext: omni.ui-2.14.4] startup
[3.912s] [ext: carb.audio-0.1.0] startup
[3.917s] [ext: omni.uiaudio-1.0.0] startup
[3.920s] [ext: omni.kit.mainwindow-1.0.0] startup
[3.923s] [ext: omni.kit.uiapp-0.0.0] startup
[3.923s] [ext: omni.usd.schema.physics-1.0.0] startup
[3.939s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[3.941s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[3.957s] [ext: omni.usd.schema.physx-0.0.0] startup
[4.004s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[4.018s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[4.032s] [ext: omni.usd.schema.anim-0.0.0] startup
[4.136s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[4.145s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[4.148s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[4.154s] [ext: omni.kit.actions.core-1.0.0] startup
[4.160s] [ext: omni.gpucompute.plugins-0.0.0] startup
[4.161s] [ext: omni.kit.commands-1.4.5] startup
[4.169s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[4.185s] [ext: omni.timeline-1.0.5] startup
[4.188s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[4.195s] [ext: omni.usd-1.6.30] startup
[4.252s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[4.254s] [ext: omni.usd.schema.flow-104.1.6] startup
[4.255s] [ext: omni.usd.schema.destruction-0.4.0] startup
[4.267s] [ext: omni.usd.schema.sequence-2.2.1] startup
[4.282s] [ext: omni.usd.schema.isaac-1.1.0] startup
[4.313s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[4.366s] [ext: omni.kit.asset_converter-1.3.4] startup
[4.394s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[4.408s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[4.411s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[4.415s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[4.421s] [ext: omni.hydra.engine.stats-1.0.0] startup
[4.428s] [ext: omni.kit.usd.layers-2.0.11] startup
[4.443s] [ext: omni.kit.menu.utils-1.4.7] startup
[4.459s] [ext: omni.ui_query-1.1.1] startup
[4.461s] [ext: omni.kvdb-0.0.0] startup
[4.464s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[4.474s] [ext: omni.kit.ui_test-1.2.9] startup
[4.478s] [ext: omni.kit.notification_manager-1.0.5] startup
[4.487s] [ext: omni.activity.core-1.0.1] startup
[4.493s] [ext: omni.kit.stage_templates-1.1.13] startup
[4.497s] [ext: omni.kit.widget.path_field-2.0.4] startup
[4.499s] [ext: omni.kit.widget.versioning-1.3.8] startup
[4.504s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[4.530s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[4.532s] [ext: omni.kit.search_core-1.0.2] startup
[4.535s] [ext: omni.kit.window.drop_support-1.0.1] startup
[4.536s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[4.625s] [ext: omni.mdl-0.1.0] startup
[4.653s] [ext: omni.kit.window.file_importer-1.0.10] startup
[4.655s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[4.656s] [ext: omni.kit.material.library-1.3.21] startup
[4.661s] [ext: omni.kit.clipboard-1.0.0] startup
[4.662s] [ext: omni.kit.menu.create-1.0.8] startup
[4.665s] [ext: omni.hydra.pxr-1.1.2] startup
[4.670s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[4.672s] [ext: omni.kit.context_menu-1.5.12] startup
[4.677s] [ext: omni.kit.hydra_texture-1.0.11] startup
2023-09-09 10:46:26 [5,863ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_EXTENSION_NOT_PRESENT
2023-09-09 10:46:26 [5,863ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2023-09-09 10:46:26 [5,863ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2023-09-09 10:46:26 [5,863ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
[5.891s] [ext: omni.kit.widget.stage-2.7.24] startup
[5.900s] [ext: omni.kit.window.file-1.3.32] startup
[5.905s] [ext: omni.kit.window.property-1.8.2] startup
[5.910s] [ext: omni.kit.window.content_browser-2.6.8] startup
2023-09-09 10:46:26 [5,890ms] [Error] [omni.ui.python] TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
At:
/isaac-sim/kit/exts/omni.kit.widget.browser_bar/omni/kit/widget/browser_bar/widget.py(121): _build_ui
/isaac-sim/kit/exts/omni.kit.widget.browser_bar/omni/kit/widget/browser_bar/widget.py(58): __init__
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/tool_bar.py(86): _build_ui
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/tool_bar.py(81): _build_ui
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/tool_bar.py(38): __init__
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/tool_bar.py(47): __init__
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/widget.py(217): _build_ui
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/widget.py(120): __init__
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/window.py(52): _build_ui
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/window.py(24): __init__
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/extension.py(100): show_window
/isaac-sim/kit/exts/omni.kit.window.content_browser/omni/kit/window/content_browser/extension.py(57): on_startup
/isaac-sim/kit/kernel/py/omni/ext/_impl/_internal.py(147): _startup_ext
/isaac-sim/kit/kernel/py/carb/profiler/__init__.py(79): wrapper
/isaac-sim/kit/kernel/py/omni/ext/_impl/_internal.py(198): startup
/isaac-sim/kit/kernel/py/omni/ext/_impl/_internal.py(285): startup_extension
PythonExtension.cpp::startup()(2): <module>
[5.918s] [ext: omni.kit.widget.viewport-104.1.16] startup
[5.924s] [ext: omni.ui.scene-1.5.18] startup
[5.934s] [ext: omni.kit.viewport.registry-104.0.2] startup
[5.935s] [ext: omni.kit.property.usd-3.18.17] startup
[5.950s] [ext: omni.physics.tensors-0.1.0] startup
[5.961s] [ext: omni.kit.viewport.window-104.1.23] startup
[5.996s] [ext: omni.localcache-0.0.0] startup
[6.000s] [ext: omni.ramp-104.1.3] startup
[6.007s] [ext: omni.usdphysics-104.2.4-5.1] startup
[6.009s] [ext: omni.kit.viewport.utility-1.0.14] startup
[6.010s] [ext: omni.kit.widget.prompt-1.0.5] startup
[6.012s] [ext: omni.physx-104.2.4-5.1] startup
[6.058s] [ext: omni.kit.numpy.common-0.1.0] startup
[6.063s] [ext: omni.inspect-1.0.1] startup
[6.067s] [ext: omni.kit.usd_undo-0.1.2] startup
[6.068s] [ext: omni.graph.tools-1.17.2] startup
[6.097s] [ext: omni.graph.core-2.65.4] startup
[6.105s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[6.149s] [ext: omni.debugdraw-0.1.1] startup
[6.155s] [ext: omni.graph-1.50.2] startup
[6.222s] [ext: omni.kit.window.extensions-1.1.1] startup
[6.231s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[6.237s] [ext: omni.kit.widget.settings-1.0.1] startup
[6.240s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[6.243s] [ext: omni.kit.window.preferences-1.3.8] startup
2023-09-09 10:46:26 [6,224ms] [Error] [carb.scripting-python.plugin] TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
At:
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/widget.py(283): _build_ui
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/widget.py(137): __init__
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/dialog.py(72): _build_ui
/isaac-sim/kit/exts/omni.kit.window.filepicker/omni/kit/window/filepicker/dialog.py(55): __init__
/isaac-sim/kit/exts/omni.kit.window.preferences/omni/kit/window/preferences/scripts/preferences_window.py(261): create_filepicker
/isaac-sim/kit/exts/omni.kit.window.preferences/omni/kit/window/preferences/scripts/pages/screenshot_page.py(42): __init__
/isaac-sim/kit/exts/omni.kit.window.preferences/omni/kit/window/preferences/scripts/preferences_window.py(93): _register_pages
/isaac-sim/kit/exts/omni.kit.window.preferences/omni/kit/window/preferences/scripts/preferences_window.py(45): on_startup
/isaac-sim/kit/kernel/py/carb/profiler/__init__.py(81): wrapper
2023-09-09 10:46:26 [6,224ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.preferences-1.3.8] Failed to startup python extension.
2023-09-09 10:46:26 [6,292ms] [Error] [omni.ext.python] ModuleNotFoundError: No module named 'omni.kit.window.preferences'
At:
/isaac-sim/kit/exts/omni.kit.property.usd/omni/kit/property/usd/widgets.py(94): _register_preferences
/isaac-sim/kit/exts/omni.kit.property.usd/omni/kit/property/usd/widgets.py(65): <lambda>
[6.320s] [ext: omni.scene.visualization.core-104.4.0] startup
[6.382s] [ext: omni.graph.ui-1.24.2] startup
2023-09-09 10:46:26 [6,370ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.graph.ui. Error: No module named 'omni.kit.window.preferences'. Traceback:
File "/isaac-sim/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
return importlib.import_module(name)
File "/isaac-sim/kit/python/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/isaac-sim/kit/exts/omni.graph.ui/omni/graph/ui/__init__.py", line 6, in <module>
from ._impl.extension import _PublicExtension
File "/isaac-sim/kit/exts/omni.graph.ui/omni/graph/ui/_impl/extension.py", line 12, in <module>
from .menu import Menu # noqa: PLE0402
File "/isaac-sim/kit/exts/omni.graph.ui/omni/graph/ui/_impl/menu.py", line 17, in <module>
from omni.kit.window.preferences import register_page, unregister_page
2023-09-09 10:46:26 [6,370ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.graph.ui' in '/isaac-sim/kit/exts/omni.graph.ui' failed to load.
At:
/isaac-sim/kit/kernel/py/omni/ext/_impl/_internal.py(189): startup
2023-09-09 10:46:26 [6,370ms] [Error] [omni.ext.plugin] [ext: omni.graph.ui-1.24.2] Failed to startup python extension.
[6.466s] [ext: omni.physx.tensors-0.1.0] startup
[6.918s] [ext: omni.genproc.core-104.5.14] startup
2023-09-09 10:46:27 [6,911ms] [Error] [carb.scripting-python.plugin] AttributeError: module 'omni.graph' has no attribute 'ui'
At:
/isaac-sim/extscache/omni.genproc.core-104.5.14+104.2.lx64.r.cp37/omni/genproc/core/scripts/extension.py(7): __init__
/isaac-sim/kit/kernel/py/omni/ext/_impl/_internal.py(141): _startup_ext
2023-09-09 10:46:27 [6,911ms] [Error] [omni.ext.plugin] [ext: omni.genproc.core-104.5.14] Failed to startup python extension.
[6.995s] [ext: omni.isaac.version-1.0.0] startup
[7.009s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[7.027s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[7.041s] [ext: omni.isaac.core-1.46.3] startup
[8.274s] [ext: omni.graph.action-1.31.1] startup
[8.290s] [ext: omni.graph.io-1.2.5] startup
[8.311s] [ext: omni.isaac.ui-0.8.0] startup
[8.317s] [ext: omni.genproc.ui-104.1.6] startup
2023-09-09 10:46:28 [8,295ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.genproc.ui. Error: No module named 'omni.genproc.core'. Traceback:
File "/isaac-sim/extscache/omni.genproc.ui-104.1.6+104.2/omni/genproc/ui/__init__.py", line 1, in <module>
from .extension import *
File "/isaac-sim/extscache/omni.genproc.ui-104.1.6+104.2/omni/genproc/ui/extension.py", line 2, in <module>
from omni.genproc.core import *
ModuleNotFoundError: No module named 'omni.genproc.core'
2023-09-09 10:46:28 [8,295ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.genproc.ui' in '/isaac-sim/extscache/omni.genproc.ui-104.1.6+104.2' failed to load.
At:
2023-09-09 10:46:28 [8,295ms] [Error] [omni.ext.plugin] [ext: omni.genproc.ui-104.1.6] Failed to startup python extension.
[8.413s] [ext: usdrt.scenegraph-4.3.2] startup
[8.446s] [ext: omni.genproc.bundle-104.0.1] startup
[8.446s] [ext: omni.graph.examples.cpp-1.4.2] startup
[8.457s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[8.467s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[8.470s] [ext: omni.command.usd-1.0.2] startup
[8.475s] [ext: omni.kit.browser.core-2.2.2] startup
[8.483s] [ext: omni.kit.widget.spinner-1.0.4] startup
[8.485s] [ext: omni.kit.window.cursor-1.1.1] startup
[8.487s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[8.494s] [ext: omni.graph.nodes-1.48.3] startup
[8.519s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
2023-09-09 10:46:29 [8,501ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.kit.viewport.menubar.core. Error: No module named 'omni.kit.window.preferences'. Traceback:
File "/isaac-sim/kit/extscore/omni.kit.viewport.menubar.core/omni/kit/viewport/menubar/core/__init__.py", line 117, in <module>
from .extension import ViewportMenuBarExtension, get_instance
File "/isaac-sim/kit/extscore/omni.kit.viewport.menubar.core/omni/kit/viewport/menubar/core/extension.py", line 17, in <module>
from .preference.menubar_page import ViewportMenubarPage
File "/isaac-sim/kit/extscore/omni.kit.viewport.menubar.core/omni/kit/viewport/menubar/core/preference/menubar_page.py", line 1, in <module>
from omni.kit.window.preferences import PreferenceBuilder
2023-09-09 10:46:29 [8,501ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.kit.viewport.menubar.core' in '/isaac-sim/kit/extscore/omni.kit.viewport.menubar.core' failed to load.
At:
2023-09-09 10:46:29 [8,501ms] [Error] [omni.ext.plugin] [ext: omni.kit.viewport.menubar.core-104.4.3] Failed to startup python extension.
[8.631s] [ext: omni.kit.browser.sample-1.2.5] startup
[8.636s] [ext: omni.graph.scriptnode-0.10.0] startup
[8.644s] [ext: omni.syntheticdata-0.2.4] startup
2023-09-09 10:46:29 [8,634ms] [Error] [omni.ext.python] ModuleNotFoundError: No module named 'omni.kit.viewport.menubar.core'
At:
/isaac-sim/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/menu.py(13): <module>
<frozen importlib._bootstrap>(219): _call_with_frames_removed
<frozen importlib._bootstrap_external>(728): exec_module
<frozen importlib._bootstrap>(677): _load_unlocked
<frozen importlib._bootstrap>(967): _find_and_load_unlocked
<frozen importlib._bootstrap>(983): _find_and_load
/isaac-sim/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/extension.py(26): __menubar_core_loaded
/isaac-sim/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/extension.py(54): <lambda>
/isaac-sim/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/extension.py(57): on_startup
[8.667s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.2
Devices:
"cpu" | x86_64
"cuda:0" | NVIDIA GeForce RTX 2080 Ti (sm_75)
Kernel cache: /root/.cache/warp/0.6.3
[8.980s] [ext: omni.anim.curve-104.16.6] startup
[9.000s] [ext: omni.isaac.debug_draw-0.2.3] startup
[9.010s] [ext: omni.replicator.core-1.7.8] startup
2023-09-09 10:46:29 [9,117ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[9.220s] [ext: omni.kit.widget.timeline-104.0.3] startup
[9.226s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[9.228s] [ext: omni.isaac.range_sensor-0.8.1] startup
[9.270s] [ext: omni.isaac.core_nodes-0.23.2] startup
[9.291s] [ext: omni.anim.curve_editor-104.12.7] startup
[9.308s] [ext: omni.isaac.sensor-5.6.3] startup
2023-09-09 10:46:29 [9,281ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /isaac-sim/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[9.393s] [ext: omni.isaac.lula-1.2.1] startup
[9.420s] [ext: omni.isaac.motion_planning-0.2.2] startup
[9.445s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[9.452s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[9.456s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[9.472s] [ext: omni.isaac.motion_generation-4.5.6] startup
[9.483s] [ext: omni.isaac.manipulators-1.1.0] startup
[9.486s] [ext: omni.kit.widget.layers-1.6.11] startup
[9.504s] [ext: omni.isaac.franka-0.4.0] startup
[9.506s] [ext: omni.isaac.utils-0.2.4] startup
[9.512s] [ext: omni.isaac.cortex-0.3.2] startup
[9.513s] [ext: omni.isaac.demos-0.3.3] startup
[9.533s] [ext: omni.isaac.dofbot-0.3.0] startup
[9.535s] [ext: omni.isaac.quadruped-1.3.0] startup
[9.931s] [ext: omni.kit.property.layer-1.1.4] startup
[9.946s] [ext: omni.isaac.universal_robots-0.3.2] startup
[9.947s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[9.951s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[9.955s] [ext: omni.kit.widget.imageview-1.0.3] startup
[9.957s] [ext: omni.kit.property.camera-1.0.3] startup
[9.958s] [ext: omni.kit.property.audio-1.0.6] startup
[9.960s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[9.973s] [ext: omni.isaac.diff_usd-1.0.1] startup
[9.976s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[9.982s] [ext: omni.kit.property.render-1.1.0] startup
[9.984s] [ext: omni.kit.property.material-1.8.19] startup
[9.988s] [ext: omni.kit.property.light-1.0.6] startup
[9.991s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[9.994s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[10.004s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[10.009s] [ext: omni.kit.widgets.custom-1.0.4] startup
2023-09-09 10:46:30 [9,996ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.kit.widgets.custom. Error: No module named 'omni.kit.window.preferences'. Traceback:
File "/isaac-sim/extscache/omni.kit.widgets.custom-1.0.4/omni/kit/widgets/custom/__init__.py", line 21, in <module>
from .preferences_helper import *
File "/isaac-sim/extscache/omni.kit.widgets.custom-1.0.4/omni/kit/widgets/custom/preferences_helper.py", line 4, in <module>
from omni.kit.window.preferences import (
2023-09-09 10:46:30 [9,996ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.kit.widgets.custom' in '/isaac-sim/extscache/omni.kit.widgets.custom-1.0.4' failed to load.
At:
2023-09-09 10:46:30 [9,996ms] [Error] [omni.ext.plugin] [ext: omni.kit.widgets.custom-1.0.4] Failed to startup python extension.
[10.172s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[10.175s] [ext: omni.kit.window.stage-2.3.12] startup
[10.180s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[10.192s] [ext: omni.curve.creator-104.1.2] startup
[10.199s] [ext: omni.anim.retarget.core-104.2.1] startup
2023-09-09 10:46:30 [10,185ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.anim.retarget.core. Error: No module named 'omni.kit.window.preferences'. Traceback:
File "/isaac-sim/extscache/omni.anim.retarget.core-104.2.1+104.2.lx64.r.cp37/omni/anim/retarget/core/__init__.py", line 2, in <module>
from .scripts.extension import *
File "/isaac-sim/extscache/omni.anim.retarget.core-104.2.1+104.2.lx64.r.cp37/omni/anim/retarget/core/scripts/extension.py", line 15, in <module>
from .rig_automap_manager import RigAutoMapManager
File "/isaac-sim/extscache/omni.anim.retarget.core-104.2.1+104.2.lx64.r.cp37/omni/anim/retarget/core/scripts/rig_automap_manager.py", line 14, in <module>
from omni.kit.widgets.custom import uniform_absolute_path
2023-09-09 10:46:30 [10,185ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.anim.retarget.core' in '/isaac-sim/extscache/omni.anim.retarget.core-104.2.1+104.2.lx64.r.cp37' failed to load.
At:
2023-09-09 10:46:30 [10,185ms] [Error] [omni.ext.plugin] [ext: omni.anim.retarget.core-104.2.1] Failed to startup python extension.
[10.350s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[10.360s] [ext: omni.hydra.scene_api-0.1.1] startup
[10.370s] [ext: omni.curve.manipulator-104.7.3] startup
[10.394s] [ext: omni.graph.bundle.action-1.3.0] startup
[10.394s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[10.398s] [ext: omni.anim.graph.core-104.2.1] startup
2023-09-09 10:46:30 [10,381ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.anim.graph.core. Error: No module named 'omni.kit.window.preferences'. Traceback:
File "/isaac-sim/extscache/omni.anim.graph.core-104.2.1+104.2.lx64.r.cp37/omni/anim/graph/core/__init__.py", line 5, in <module>
from .scripts import *
File "/isaac-sim/extscache/omni.anim.graph.core-104.2.1+104.2.lx64.r.cp37/omni/anim/graph/core/scripts/__init__.py", line 1, in <module>
File "/isaac-sim/extscache/omni.anim.graph.core-104.2.1+104.2.lx64.r.cp37/omni/anim/graph/core/scripts/extension.py", line 3, in <module>
from .command import *
File "/isaac-sim/extscache/omni.anim.graph.core-104.2.1+104.2.lx64.r.cp37/omni/anim/graph/core/scripts/command.py", line 10, in <module>
2023-09-09 10:46:30 [10,381ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.anim.graph.core' in '/isaac-sim/extscache/omni.anim.graph.core-104.2.1+104.2.lx64.r.cp37' failed to load.
At:
2023-09-09 10:46:30 [10,381ms] [Error] [omni.ext.plugin] [ext: omni.anim.graph.core-104.2.1] Failed to startup python extension.
[10.543s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[10.561s] [ext: omni.kit.property.transform-1.3.5] startup
[10.568s] [ext: omni.kit.property.skel-1.0.1] startup
[10.570s] [ext: omni.kit.property.geometry-1.2.2] startup
[10.574s] [ext: omni.anim.graph.ui-104.2.0] startup
2023-09-09 10:46:31 [10,553ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.anim.graph.ui. Error: No module named 'omni.anim.graph.core'. Traceback:
File "/isaac-sim/extscache/omni.anim.graph.ui-104.2.0+104.2/omni/anim/graph/ui/__init__.py", line 2, in <module>
File "/isaac-sim/extscache/omni.anim.graph.ui-104.2.0+104.2/omni/anim/graph/ui/scripts/__init__.py", line 1, in <module>
File "/isaac-sim/extscache/omni.anim.graph.ui-104.2.0+104.2/omni/anim/graph/ui/scripts/extension.py", line 4, in <module>
from .animation_graph_manager import AnimationGraphManager
File "/isaac-sim/extscache/omni.anim.graph.ui-104.2.0+104.2/omni/anim/graph/ui/scripts/animation_graph_manager.py", line 2, in <module>
import omni.anim.graph.core as ag
ModuleNotFoundError: No module named 'omni.anim.graph.core'
2023-09-09 10:46:31 [10,553ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.anim.graph.ui' in '/isaac-sim/extscache/omni.anim.graph.ui-104.2.0+104.2' failed to load.
At:
2023-09-09 10:46:31 [10,553ms] [Error] [omni.ext.plugin] [ext: omni.anim.graph.ui-104.2.0] Failed to startup python extension.
[10.726s] [ext: omni.kit.property.bundle-1.2.6] startup
[10.735s] [ext: omni.isaac.examples-1.5.6] startup
[12.123s] [ext: omni.graph.window.core-1.43.3] startup
[12.138s] [ext: omni.slangnode-104.2.3] startup
[12.185s] [ext: omni.anim.graph.bundle-104.2.0] startup
[12.186s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[12.191s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-09-09 10:46:32 [12,165ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[12.193s] [ext: omni.graph.window.generic-1.3.15] startup
2023-09-09 10:46:32 [12,169ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.graph.window.generic. Error: No module named 'omni.graph.ui'. Traceback:
File "/isaac-sim/extscache/omni.graph.window.generic-1.3.15/omni/graph/window/generic/__init__.py", line 9, in <module>
from .generic_graph_extension import GenericGraphExtension
File "/isaac-sim/extscache/omni.graph.window.generic-1.3.15/omni/graph/window/generic/generic_graph_extension.py", line 28, in <module>
from omni.graph.ui import add_create_menu_type, remove_create_menu_type
ModuleNotFoundError: No module named 'omni.graph.ui'
2023-09-09 10:46:32 [12,169ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.graph.window.generic' in '/isaac-sim/extscache/omni.graph.window.generic-1.3.15' failed to load.
At:
2023-09-09 10:46:32 [12,169ms] [Error] [omni.ext.plugin] [ext: omni.graph.window.generic-1.3.15] Failed to startup python extension.
[12.339s] [ext: omni.activity.freeze_monitor-1.0.1] startup
2023-09-09 10:46:33 [12,433ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-09-09 10:46:33 [12,433ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-09-09 10:46:33 [12,434ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip' for upload.
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'f7acb3d6-1443-408a-42bc219d-00b98a9b'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1694256380'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '13'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'startup'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ''
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 5.4412/7.45811GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = ''
2023-09-09 10:46:33 [12,597ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '2275780497808146057'
2023-09-09 10:46:33 [12,598ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'default'
2023-09-09 10:46:33 [12,598ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-09-09 10:46:33 [12,598ms] [Warning] [carb.crashreporter-breakpad.plugin] upload_file_minidump = '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip'
2023-09-09 10:46:36 [15,619ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip', code:200, response:
2023-09-09 10:46:36 [15,619ms] [Warning] [carb.crashreporter-breakpad.plugin] 00000189096d03ac-27ab8a
2023-09-09 10:46:36 [15,619ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
2023-09-09 10:46:36 [15,619ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/f7acb3d6-1443-408a-42bc219d-00b98a9b.dmp.zip'
2023-09-09 10:46:36 [15,619ms] [Error] [carb.crashreporter-breakpad.plugin] the dump file was deleted due to a successful upload. Its originalsize was 309853 bytes and was readable.
2023-09-09 10:46:36 [15,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 1141 thread 1141
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'f7acb3d6-1443-408a-42bc219d-00b98a9b'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1694256380'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '13'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'startup'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ''
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 5.4412/7.45811GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = ''
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '2275780497808146057'
2023-09-09 10:46:36 [15,620ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'default'
2023-09-09 10:46:36 [15,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 1141 backtrace follows:
2023-09-09 10:46:36 [15,642ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60
2023-09-09 10:46:36 [15,656ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libomni.activity.freeze_monitor.plugin.so!std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release()+0x27a3
2023-09-09 10:46:36 [15,670ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libomni.activity.freeze_monitor.plugin.so!_init+0x1b8d
2023-09-09 10:46:36 [15,687ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libcarb.so!omniCoreStart+0x2b396
2023-09-09 10:46:36 [15,705ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.so!omniCoreStart+0x2bfaa
2023-09-09 10:46:36 [15,723ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libcarb.so!quickReleaseFrameworkAndTerminate+0xad9c
2023-09-09 10:46:36 [15,743ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libcarb.so!quickReleaseFrameworkAndTerminate+0xb98a
2023-09-09 10:46:36 [15,762ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)+0x2d1e
2023-09-09 10:46:36 [15,783ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libomni.ext.plugin.so!std::pair<std::__detail::_Node_iterator<std::string, true, true>, bool> std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::_M_insert<std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > >(std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > const&, std::integral_constant<bool, true>)+0x2b89
2023-09-09 10:46:36 [15,801ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)+0x1800b
2023-09-09 10:46:36 [15,819ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.ext.plugin.so!carbOnPluginShutdown+0x6358
2023-09-09 10:46:36 [15,837ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.ext.plugin.so!carbOnPluginShutdown+0xd883
2023-09-09 10:46:36 [15,854ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.ext.plugin.so!carbOnPluginShutdown+0xf099
2023-09-09 10:46:36 [15,872ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.kit.app.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&&)+0x12de2
2023-09-09 10:46:36 [15,890ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.kit.app.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&&)+0x135b3
2023-09-09 10:46:36 [15,907ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.kit.app.plugin.so!_init+0x4e9e
2023-09-09 10:46:36 [15,924ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x6f6
2023-09-09 10:46:36 [15,939ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: kit!_init+0x630
2023-09-09 10:46:36 [15,958ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libc.so.6!__libc_start_main+0xf3
2023-09-09 10:46:36 [15,972ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: kit!_init+0x9cb
Segmentation fault
