Isaac-sim
Hello, has this problem been solved? I saw someone raise a similar question in 2022. At that time, Docker did not support isaac of wsl/wsl2.
2024-06-03 05:54:20 [1,131ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:20 [1,131ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[1.182s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-06-03 05:54:20 [1,172ms] [Warning] [omni.platforminfo.plugin] failed to open the default display. Can’t verify X Server version.
2024-06-03 05:54:20 [1,287ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2024-06-03 05:54:20 [1,288ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2024-06-03 05:54:20 [1,288ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2024-06-03 05:54:20 [1,549ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2024-06-03 05:54:20 [1,549ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2024-06-03 05:54:20 [1,549ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2024-06-03 05:54:20 [1,649ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create any GPU devices, including an attempt with compatibility mode.
sh: 1: zenity: not found
[1.726s] [ext: omni.kit.pipapi-0.0.0] startup
[1.728s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.729s] [ext: omni.pip.compute-1.2.0] startup
[1.730s] [ext: omni.pip.cloud-1.0.1] startup
[1.783s] [ext: omni.isaac.core_archive-2.2.1] startup
[1.783s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[1.857s] [ext: omni.kit.telemetry-0.5.0] startup
[1.886s] [ext: omni.kit.loop-isaac-1.1.0] startup
[1.888s] [ext: omni.kit.test-0.0.0] startup
[1.890s] [ext: omni.isaac.ml_archive-1.1.3] startup
[1.891s] [ext: omni.mtlx-0.1.0] startup
[1.892s] [ext: omni.usd.config-1.0.3] startup
[1.901s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.902s] [ext: omni.usd.libs-1.0.0] startup
[2.040s] [ext: omni.appwindow-1.1.5] startup
2024-06-03 05:54:20 [1,992ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:20 [1,992ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[2.044s] [ext: omni.kit.renderer.core-0.0.0] startup
2024-06-03 05:54:20 [1,996ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
2024-06-03 05:54:20 [1,999ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:20 [1,999ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[2.053s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.057s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2024-06-03 05:54:21 [2,012ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:21 [2,012ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-03 05:54:21 [2,014ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
[2.067s] [ext: carb.audio-0.1.0] startup
[2.070s] [ext: omni.ui-2.18.5] startup
[2.087s] [ext: omni.uiaudio-1.0.0] startup
[2.089s] [ext: omni.kit.mainwindow-1.0.1] startup
[2.091s] [ext: omni.kit.uiapp-0.0.0] startup
[2.091s] [ext: omni.usd.schema.physics-0.0.0] startup
[2.294s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.302s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[2.311s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.321s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[2.324s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.338s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.392s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.420s] [ext: omni.anim.navigation.schema-105.2.0] startup
[2.426s] [ext: omni.anim.graph.schema-105.2.2] startup
[2.439s] [ext: omni.usd.schema.isaac-2.0.1] startup
[2.448s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.452s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.459s] [ext: omni.resourcemonitor-105.0.0] startup
[2.463s] [ext: omni.timeline-1.0.9] startup
[2.466s] [ext: omni.usd_resolver-1.0.1] startup
[2.472s] [ext: omni.kit.window.popup_dialog-2.0.23] startup
[2.478s] [ext: omni.graph.exec-0.3.0] startup
[2.480s] [ext: omni.kit.actions.core-1.0.0] startup
[2.482s] [ext: omni.usd.core-1.1.8] startup
[2.487s] [ext: omni.kit.widget.nucleus_connector-1.1.4] startup
[2.490s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[2.492s] [ext: omni.kit.exec.core-0.5.0] startup
[2.495s] [ext: omni.kit.commands-1.4.6] startup
[2.501s] [ext: omni.hydra.usdrt_delegate-7.2.34] startup
[2.517s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[2.526s] [ext: omni.usd-1.10.18] startup
[2.617s] [ext: omni.kit.widget.versioning-1.4.6] startup
[2.622s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[2.662s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[2.663s] [ext: omni.kit.widget.filebrowser-2.3.35] startup
[2.671s] [ext: omni.kit.search_core-1.0.5] startup
[2.673s] [ext: omni.kit.widget.path_field-2.0.8] startup
[2.675s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[2.677s] [ext: omni.kit.widget.browser_bar-2.0.9] startup
[2.679s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[2.680s] [ext: omni.kit.menu.utils-1.5.6] startup
[2.699s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[2.701s] [ext: omni.ui.scene-1.7.0] startup
[2.712s] [ext: omni.kit.notification_manager-1.0.6] startup
[2.715s] [ext: omni.kit.clipboard-1.0.3] startup
[2.716s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[2.718s] [ext: omni.kit.usd.layers-2.1.27] startup
[2.733s] [ext: omni.kit.window.filepicker-2.10.13] startup
[2.753s] [ext: omni.kit.widget.filter-1.1.2] startup
[2.754s] [ext: omni.kit.menu.create-1.0.11] startup
[2.757s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[2.760s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[2.767s] [ext: omni.kit.context_menu-1.6.8] startup
[2.770s] [ext: omni.kit.widget.stage-2.9.6] startup
[2.786s] [ext: omni.kit.primitive.mesh-1.0.15] startup
[2.792s] [ext: omni.kit.usd_undo-0.1.2] startup
[2.793s] [ext: omni.kit.stage_templates-1.1.20] startup
[2.799s] [ext: omni.kit.widget.searchfield-1.1.3] startup
[2.802s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[2.803s] [ext: omni.kit.window.file_importer-1.0.22] startup
[2.805s] [ext: omni.kit.window.property-1.9.6] startup
[2.810s] [ext: omni.ui_query-1.1.1] startup
[2.811s] [ext: omni.inspect-1.0.1] startup
[2.814s] [ext: usdrt.scenegraph-7.2.34] startup
[2.899s] [ext: omni.graph.tools-1.41.3] startup
[2.927s] [ext: omni.graph.core-2.139.12] startup
[2.934s] [ext: omni.kit.window.file-1.3.44] startup
[2.938s] [ext: omni.graph-1.106.1] startup
[3.020s] [ext: omni.kvdb-0.0.0] startup
[3.025s] [ext: omni.convexdecomposition-105.1.12-5.1] startup
[3.032s] [ext: omni.localcache-0.0.0] startup
[3.036s] [ext: omni.iray.libs-0.0.0] startup
[3.049s] [ext: omni.physx.foundation-105.1.12-5.1] startup
[3.051s] [ext: omni.usdphysics-105.1.12-5.1] startup
[3.058s] [ext: omni.mdl.neuraylib-0.2.0] startup
[3.063s] [ext: omni.isaac.version-1.0.3] startup
[3.065s] [ext: omni.physx.cooking-105.1.12-5.1] startup
[3.078s] [ext: omni.mdl-0.2.1] startup
[3.131s] [ext: omni.physics.tensors-0.1.0] startup
[3.143s] [ext: omni.physx-105.1.12-5.1] startup
2024-06-03 05:54:22 [3,121ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[3.177s] [ext: omni.kit.material.library-1.3.41] startup
[3.189s] [ext: omni.volume-0.4.0] startup
[3.197s] [ext: omni.physx.tensors-0.1.0] startup
[3.738s] [ext: omni.kit.numpy.common-0.1.2] startup
[3.742s] [ext: omni.hydra.rtx-0.1.0] startup
[3.764s] [ext: omni.warp.core-1.0.0-beta.2] startup
Warp 1.0.0-beta.2 initialized:
CUDA Toolkit: 11.5, Driver: 12.4
Devices:
“cpu” | x86_64
“cuda:0” | NVIDIA GeForce RTX 3060 (sm_86)
Kernel cache: /root/.cache/warp/1.0.0-beta.2
[4.112s] [ext: omni.isaac.dynamic_control-1.2.6] startup
[4.132s] [ext: omni.debugdraw-0.1.2] startup
[4.143s] [ext: omni.isaac.core-3.3.2] startup
[6.379s] [ext: omni.hydra.pxr-1.1.6] startup
[6.388s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[6.392s] [ext: omni.kit.widget.prompt-1.0.6] startup
[6.394s] [ext: omni.kit.hydra_texture-1.1.12] startup
[6.403s] [ext: omni.hydra.engine.stats-1.0.1] startup
[6.410s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[6.417s] [ext: omni.kit.widget.viewport-105.1.7] startup
[6.428s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[6.431s] [ext: omni.kit.window.drop_support-1.0.1] startup
[6.433s] [ext: omni.kit.viewport.registry-104.0.5] startup
[6.435s] [ext: omni.kit.widget.settings-1.0.6] startup
[6.440s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[6.443s] [ext: omni.kit.viewport.window-105.1.12] startup
[6.483s] [ext: omni.kit.window.preferences-1.3.23] startup
[6.502s] [ext: omni.kit.widget.graph-1.8.4] startup
[6.512s] [ext: omni.kit.window.content_browser-2.7.17] startup
[6.544s] [ext: omni.kit.viewport.utility-1.0.16] startup
[6.548s] [ext: omni.kit.widget.live_session_management-1.2.22] startup
[6.558s] [ext: omni.kit.window.extensions-1.3.0] startup
[6.571s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[6.576s] [ext: omni.kit.property.usd-3.21.15] startup
[6.600s] [ext: omni.kit.manipulator.viewport-104.0.9] startup
[6.604s] [ext: omni.graph.ui-1.48.0] startup
[6.643s] [ext: omni.kit.ui_test-1.2.13] startup
[6.647s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[6.880s] [ext: omni.graph.action-1.55.1] startup
[7.449s] [ext: omni.isaac.ui-0.13.5] startup
[7.473s] [ext: omni.isaac.surface_gripper-0.7.0] startup
[7.506s] [ext: omni.isaac.lula-2.1.0] startup
[7.526s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[7.529s] [ext: omni.isaac.manipulators-1.1.0] startup
[7.542s] [ext: omni.isaac.motion_generation-6.1.0] startup
[7.565s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[7.574s] [ext: omni.kit.graph.delegate.modern-1.9.1] startup
[7.579s] [ext: omni.isaac.franka-0.4.0] startup
[7.587s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[7.592s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[7.595s] [ext: omni.isaac.universal_robots-0.3.3] startup
[7.602s] [ext: omni.isaac.cortex-0.3.5] startup
[7.606s] [ext: omni.graph.window.core-1.84.0] startup
[7.634s] [ext: omni.isaac.dofbot-0.3.1] startup
[7.642s] [ext: omni.isaac.cortex.sample_behaviors-1.0.4] startup
[7.649s] [ext: omni.graph.window.generic-1.9.3] startup
[7.659s] [ext: omni.isaac.kit-1.4.7] startup
[7.661s] [ext: omni.graph.window.action-1.11.2] startup
[7.674s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[7.676s] [ext: omni.graph.image.core-0.1.0] startup
[7.678s] [ext: omni.kit.window.cursor-1.1.2] startup
[7.680s] [ext: omni.kit.browser.core-2.3.10] startup
[7.691s] [ext: omni.kit.widget.spinner-1.0.6] startup
[7.696s] [ext: omni.graph.nodes-1.106.3] startup
[15.633s] [ext: omni.kit.widget.material_preview-1.0.8] startup
[15.641s] [ext: omni.kit.browser.folder.core-1.9.7] startup
[15.654s] [ext: omni.kit.viewport.menubar.core-105.0.19] startup
[15.702s] [ext: omni.kit.renderer.cuda_interop-1.0.1] startup
[15.708s] [ext: omni.kit.window.material_graph-1.8.11] startup
[15.781s] [ext: omni.kit.browser.sample-1.4.6] startup
[15.787s] [ext: omni.syntheticdata-0.4.10] startup
[15.854s] [ext: omni.kit.livestream.core-2.3.0] startup
[15.860s] [ext: omni.kit.streamsdk.plugins-2.5.2] startup
[15.861s] [ext: omni.warp-1.0.0-beta.2] startup
[16.706s] [ext: omni.graph.scriptnode-1.1.6] startup
[16.725s] [ext: omni.command.usd-1.0.2] startup
[16.729s] [ext: omni.kit.livestream.native-2.4.0] startup
2024-06-03 05:54:35 [16,729ms] [Warning] [omni.kit.livestream.plugin] Failed to acquire rtx::resourcemanager::ResourceManager!
[16.781s] [ext: omni.replicator.core-1.10.20] startup
2024-06-03 05:54:35 [16,776ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[20.216s] [ext: omni.kit.viewport.menubar.lighting-105.0.7] startup
[20.225s] [ext: omni.isaac.urdf-1.1.0] startup
2024-06-03 05:54:39 [20,175ms] [Warning] [omni.isaac.urdf] The extension omni.isaac.urdf has been deprecated. Please use omni.importer.urdf instead.
[20.227s] [ext: omni.isaac.core_nodes-1.7.1] startup
[20.488s] [ext: omni.isaac.cloner-0.7.2] startup
[20.492s] [ext: omni.isaac.utils-0.6.0] startup
[20.512s] [ext: omni.isaac.wheeled_robots-0.9.0] startup
[20.553s] [ext: omni.isaac.gym-0.10.0] startup
[20.556s] [ext: omni.kit.selection-0.1.3] startup
[20.559s] [ext: omni.kit.menu.common-1.1.4] startup
[20.564s] [ext: omni.kit.widget.layers-1.6.32] startup
[20.588s] [ext: omni.kit.menu.edit-1.1.14] startup
[20.597s] [ext: omni.kit.menu.file-1.1.7] startup
[20.603s] [ext: omni.kit.property.layer-1.1.5] startup
[20.610s] [ext: semantics.schema.editor-0.3.4] startup
[20.621s] [ext: omni.kit.property.camera-1.0.5] startup
[20.627s] [ext: omni.kit.property.audio-1.0.9] startup
[20.636s] [ext: omni.kit.profiler.window-2.1.2] startup
2024-06-03 05:54:39 [20,835ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.lt and use insort ‘key’ arg instead
[20.893s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[20.896s] [ext: omni.hydra.scene_api-0.1.2] startup
[20.911s] [ext: omni.kit.property.light-1.0.8] startup
[20.917s] [ext: omni.kit.property.skel-1.0.4] startup
[20.925s] [ext: omni.kit.window.stage-2.4.4] startup
[20.934s] [ext: omni.kit.property.transform-1.3.10] startup
[20.943s] [ext: omni.kit.property.render-1.1.1] startup
[20.948s] [ext: omni.kit.property.material-1.8.36] startup
[20.955s] [ext: omni.kit.property.geometry-1.2.11] startup
[20.963s] [ext: omni.isaac.debug_draw-0.6.1] startup
2024-06-03 05:54:39 [20,920ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[20.981s] [ext: omni.kit.menu.stage-1.2.3] startup
[20.986s] [ext: omni.kit.property.bundle-1.2.9] startup
[20.990s] [ext: omni.kit.property.isaac-0.2.2] startup
[20.996s] [ext: omni.isaac.occupancy_map-0.3.2] startup
[21.033s] [ext: omni.isaac.mjcf-1.0.0] startup
2024-06-03 05:54:39 [20,983ms] [Warning] [omni.isaac.mjcf] The extension omni.isaac.mjcf has been deprecated. Please use omni.importer.mjcf instead.
[21.034s] [ext: omni.kit.viewport.actions-105.1.6] startup
[21.044s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[21.060s] [ext: omni.kit.raycast.query-1.0.1] startup
[21.072s] [ext: omni.kit.manipulator.transform-104.6.15] startup
[21.076s] [ext: omni.rtx.window.settings-0.6.9] startup
[21.086s] [ext: omni.kit.viewport.menubar.display-105.1.0] startup
[21.090s] [ext: omni.kit.manipulator.tool.snap-1.4.2] startup
[21.103s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[21.107s] [ext: omni.activity.pump-1.0.0] startup
[21.111s] [ext: omni.physx.commands-105.1.12-5.1] startup
[21.117s] [ext: omni.usdphysics.ui-105.1.12-5.1] startup
[21.178s] [ext: omni.kit.widget.live-2.1.6] startup
[21.182s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[21.183s] [ext: omni.kit.viewport.ready-1.0.5] startup
[21.186s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[21.187s] [ext: omni.physx.ui-105.1.12-5.1] startup
[21.239s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
2024-06-03 05:54:40 [21,194ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
[21.245s] [ext: usdrt.gf-1.0.2] startup
[21.245s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[21.249s] [ext: omni.kit.window.commands-0.2.4] startup
[21.253s] [ext: omni.kit.window.console-0.2.10] startup
[21.281s] [ext: omni.kit.property.physx-0.1.0] startup
[21.431s] [ext: omni.kit.actions.window-1.1.0] startup
[21.438s] [ext: omni.physx.demos-105.1.12-5.1] startup
[21.446s] [ext: omni.kit.manipulator.prim-105.0.11] startup
[21.460s] [ext: omni.kit.window.toolbar-1.5.4] startup
[21.466s] [ext: omni.kit.manipulator.selection-104.0.8] startup
[21.470s] [ext: omni.kit.window.script_editor-1.7.4] startup
[21.476s] [ext: omni.kit.hotkeys.window-1.4.1] startup
[21.489s] [ext: omni.physx.camera-105.1.12-5.1] startup
[21.504s] [ext: omni.physx.cct-105.1.12-5.1] startup
[21.533s] [ext: omni.physx.graph-105.1.12-5.1] startup
[21.555s] [ext: omni.physx.supportui-105.1.12-5.1] startup
[21.583s] [ext: omni.physx.vehicle-105.1.12-5.1] startup
[21.608s] [ext: omni.kit.stage_column.payload-1.0.12] startup
[21.614s] [ext: omni.graph.ui_nodes-1.5.10] startup
[22.432s] [ext: omni.sensors.nv.common-1000.0.0-isaacsim.2023.1.1] startup
[22.444s] [ext: omni.sensors.nv.materials-1000.0.0-isaacsim.2023.1.1] startup
[22.448s] [ext: omni.sensors.nv.wpm-1000.0.0-isaacsim.2023.1.1] startup
[22.449s] [ext: omni.kit.window.status_bar-0.1.6] startup
[22.458s] [ext: omni.physx.bundle-105.1.12-5.1] startup
[22.459s] [ext: omni.graph.bundle.action-2.0.4] startup
[22.459s] [ext: omni.isaac.range_sensor-2.0.2] startup
[22.550s] [ext: omni.sensors.nv.lidar-1000.0.1-isaacsim.2023.1.1] startup
[22.560s] [ext: omni.sensors.nv.radar-1000.0.0-isaacsim.2023.1.1] startup
[22.569s] [ext: omni.kit.window.title-1.1.3] startup
2024-06-03 05:54:41 [22,522ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:41 [22,522ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
2024-06-03 05:54:41 [22,524ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2024-06-03 05:54:41 [22,524ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.4]) (impl: carb.windowing-glfw.plugin)
[22.577s] [ext: omni.replicator.composer-1.2.17] startup
[22.718s] [ext: omni.replicator.isaac-1.11.3] startup
[22.798s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[22.807s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[22.820s] [ext: omni.isaac.sensor-9.11.1] startup
[23.033s] [ext: omni.kit.viewport.menubar.render-105.1.1] startup
[23.039s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[23.049s] [ext: omni.replicator.replicator_yaml-2.0.4] startup
[23.178s] [ext: omni.rtx.settings.core-0.5.13] startup
[23.189s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[23.193s] [ext: omni.isaac.quadruped-1.4.1] startup
[23.221s] [ext: semantics.schema.property-1.0.2] startup
[23.225s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[23.226s] [ext: omni.isaac.scene_blox-0.1.0] startup
[23.230s] [ext: omni.importer.urdf-1.6.1] startup
[23.310s] [ext: omni.importer.mjcf-1.1.0] startup
[23.326s] [ext: omni.kit.window.stats-0.1.4] startup
[23.329s] [ext: omni.isaac.sim.python-2023.1.1] startup
[23.333s] Simulation App Starting
2024-06-03 05:54:42 [23,617ms] [Warning] [omni.hydratexture.plugin] rtx::raytracing::RaycastQueryManager is not available
2024-06-03 05:54:42 [23,649ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-06-03 05:54:42 [23,649ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[23.711s] app ready
2024-06-03 05:54:43 [24,326ms] [Warning] [omni.kit.imgui_renderer.plugin] _createExtendCursor: No windowing.
2024-06-03 05:54:43 [24,327ms] [Warning] [omni.kit.imgui_renderer.plugin] _createExtendCursor: No windowing.
2024-06-03 05:54:43 [24,327ms] [Error] [omni.kit.livestream.plugin] Failed to acquire rtx::resourcemanager::ResourceManager!
2024-06-03 05:54:43 [24,521ms] [Warning] [rtx.neuraylib.plugin] [GPU:RENDER] 0.1 GPU rend warn : It appears that the “nvidia” kernel module is not loaded.
2024-06-03 05:54:43 [24,522ms] [Warning] [rtx.neuraylib.plugin] [GPU:RENDER] 0.1 GPU rend warn : It appears that there are no “nvidia” device nodes. This configuration is unlikely to work at all. Verify that your runlevel is sufficient and “nvidia” device nodes are present, e.g., /dev/nvidia0.
What’s next?
Hi. We are currently not able to support WSL 2. Isaac Sim on Linux requires Vulkan for rendering and Vulkan is not fully supported on WSL 2 yet.
