2023-09-30 01:24:07 [22,673ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.replicator.core. Error: cannot import name ‘DEFAULT_CIPHERS’ from 'urllib3.util.ssl’ (d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\python\lib\site-packages\urllib3\util\ssl_.py). Traceback:
File “d:/appdata/local/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext_impl\custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\python\lib\importlib_init_.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in gcd_import
File “”, line 983, in find_and_load
File “”, line 967, in find_and_load_unlocked
File “”, line 677, in load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in call_with_frames_removed
File "d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core_init.py", line 1, in
from .scripts import create, distribution, example, get, modify, orchestrator, physics, randomizer, settings, trigger
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\create.py”, line 21, in
from . import modify
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\modify.py”, line 22, in
from .distribution import choice, uniform, sequence
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\distribution.py”, line 15, in
from .orchestrator import add_named_node
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\orchestrator.py”, line 23, in
from omni.replicator.core.scripts.backends.dispatcher import BackendDispatch
File "d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\backends_init.py", line 12, in
from .dispatcher import BackendDispatch
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\backends\dispatcher.py”, line 23, in
from .s3 import S3Backend, S3BackendError
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37\omni\replicator\core\scripts\backends\s3.py”, line 19, in
import boto3
File "d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core_archive\pip_prebundle\boto3_init.py", line 16, in
from boto3.session import Session
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core_archive\pip_prebundle\boto3\session.py”, line 17, in
import botocore.session
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\session.py”, line 30, in
import botocore.credentials
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\credentials.py”, line 34, in
from botocore.config import Config
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\config.py”, line 16, in
from botocore.endpoint import DEFAULT_TIMEOUT, MAX_POOL_CONNECTIONS
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\endpoint.py”, line 22, in
from botocore.awsrequest import create_request_object
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\awsrequest.py”, line 26, in
import botocore.utils
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\utils.py”, line 33, in
import botocore.httpsession
File “d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\extscore\omni.kit.pip_archive\pip_prebundle\botocore\httpsession.py”, line 8, in
from urllib3.util.ssl import (
ImportError: cannot import name ‘DEFAULT_CIPHERS’ from 'urllib3.util.ssl’ (d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\python\lib\site-packages\urllib3\util\ssl.py)
2023-09-30 01:24:07 [22,674ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.replicator.core’ in ‘d:\appdata\local\ov\pkg\isaac_sim-2022.2.1\extscache\omni.replicator.core-1.7.8+104.2.wx64.r.cp37’ failed to load.
At:
d:/appdata/local/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext_impl_internal.py(189): startup
d:/appdata/local/ov/pkg/isaac_sim-2022.2.1/kit/kernel/py\omni\ext_impl_internal.py(285): startup_extension
PythonExtension.cpp::startup()(2):
2023-09-30 01:24:07 [22,674ms] [Error] [omni.ext.plugin] [ext: omni.replicator.core-1.7.8] Failed to startup python extension.
