I’m working on a Jetson Orin AGX that has a Rogue carrier board from CTI. I’m using JetPack 6 and I’d like more information regarding the following error message.
I’ve been working on a driver port and I’ve successfully captured frames but whenever I execute the v4l2-ctl command for capturing frames I get the following error on dmesg
The frame capture works fine and the content of frames is what I expect but I’m curios about this error because I haven’t seen it before and I didn’t find much information regarding the error
[ 1499.578554] tegra-mc 2c00000.memory-controller: vifalr: read @0x0000007ffc260000: EMEM address decode error (EMEM decode error)
[ 1499.578569] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
[ 1499.578579] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc260000: EMEM address decode error (EMEM decode error)
[ 1499.582781] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
[ 1499.582821] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
[ 1499.678547] tegra-mc 2c00000.memory-controller: vifalr: read @0x0000007ffc260000: EMEM address decode error (EMEM decode error)
[ 1499.678582] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
[ 1499.678596] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc260000: EMEM address decode error (EMEM decode error)
[ 1499.682783] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
[ 1499.682823] tegra-mc 2c00000.memory-controller: vifalw: write @0x0000007ffc250000: EMEM address decode error (EMEM decode error)
Can you please elaborate on the meaning of this message please?
