Hello I am testing the Pacbio pipeline using minimap2 and haplotypeCaller here is my code (running images using podman on cluster):
podman run --gpus all --rm --device nvidia.com/gpu=all \
--volume $(pwd):/workdir \
--volume $(pwd):/outputdir \
--workdir /workdir \
nvcr.io/nvidia/clara/clara-parabricks:4.3.0-1 \
pbrun minimap2 \
--ref workdir/ref/NCBI_genome.fasta \
--in-fq workdir/St_001_1.hifi.fastq \
--out-bam outputdir/bam_files/St_001_1.hifi.bam \
--num-gpus 1 \
--gpuwrite \
--preset map-hifi \
--read-group-sm St_001_1 \
--read-group-lb St_001_1 \
--read-group-pl PACBIO \
--read-group-id-prefix St_001_1
mv ./outputdir/bam_files/* ./workdir/bam_files/
podman run --gpus all --rm --device nvidia.com/gpu=all --volume $(pwd):/workdir --volume $(pwd):/outputdir \
pbrun haplotypecaller \
--in-bam workdir/bam_files/St_001_1.hifi.bam \
--gvcf \
--out-variants outputdir/St_001_1.hifi.g.vcf.gz \
--num-gpus 1
Minimap works great but I am getting the following error when running haplotypecaller:
[PB Info 2024-Apr-23 20:09:38] ------------------------------------------------------------------------------
[PB Info 2024-Apr-23 20:09:38] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Apr-23 20:09:38] || Version 4.3.0-1 ||
[PB Info 2024-Apr-23 20:09:38] || GPU-GATK4 HaplotypeCaller ||
[PB Info 2024-Apr-23 20:09:38] 0 /workdir/workdir/bam_files/St_001_1.hifi.bam/workdir/outputdir/St_001_1.hifi.g.vcf.gz
[PB Info 2024-Apr-23 20:09:38] ProgressMeter - Current-Locus Elapsed-Minutes Regions-Processed Regions/Minute
htvc: src/PBFilter.cpp:650: bool applyFilters(bam1_t*, FilterSetting): Assertion `numCigOps <= MAX_CIGAR_SIZE' failed.
[PB Error 2024-Apr-23 20:09:38][-unknown-:0] Received signal: 6
For technical support visit https://docs.nvidia.com/clara/index.html#parabricks, exiting.
[PB Error 2024-Apr-23 20:09:38][src/stage.cu:24] cudaSetDevice failed, expected cudaSetDevice(device_id) == cudaSuccess, exiting.
/usr/local/parabricks/binaries/bin/htvc /workdir/workdir/ref/NCBI_genome.fasta /workdir/workdir/bam_files/St_001_1.hifi.bam 1 -o /workdir/outputdir/St_001_1.hifi.g.vcf.gz -nt 5 -g
Exit with error: 1
Exiting...
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
Could not run haplotypecaller
Exiting pbrun ...
Any ideas?
