Hi
I am running haplotypecaller nvcr.io/nvidia/clara/clara-parabricks:4.2.0-1
on AWS g4dn.12xlarge and I get this error message below. Interestingly, the job exits with Exit Code 0
[PB Info 2023-Oct-17 02:52:14] ProgressMeter - Current-Locus Elapsed-Minutes Regions-Processed Regions/Minute
[PB Debug 2023-Oct-17 02:52:15][src/assembleRegions_GPU.cu:333] The gpu memory used by Stage 0 is 3097207948
[PB Debug 2023-Oct-17 02:52:15][src/assembleRegions_GPU.cu:414] The cpu memory used by Stage 0 is 810178340
[PB Error 2023-Oct-17 02:52:15][src/likehood_test.cu:951] cudaSafeCall() failed: out of memory, exiting.
The command used with haplotypecaller
is shown below and the --in-bam
file is the file that was output from fq2bam
pbrun haplotypecaller \
--ref hs38DH.fa \
--in-bam HA2WPADXX_2.pb.bam \
--in-recal-file HA2WPADXX_2.pb.BQSR-REPORT.txt \
--out-variants "HA2WPADXX_2.HAPLOTYPECALLER.pb.vcf" \
--logfile "HA2WPADXX_2.HAPLOTYPECALLER.log.txt" \
--run-partition \
--gpu-num-per-partition 1 \
--verbose --x3 \
--num-gpus 4
fq2bam
had a --low-memory
option. Is there something similar for haplotypecaller
? Also, do I need to change/enable --htvc-low-memory
and/or --num-htvc-threads
to overcome this error?
FWIW, the same --in-bam
file works well with deepvariant
pbrun deepvariant \
--ref hs38DH.fa \
--out-variants "HA2WPADXX_2.DEEPVARIANT.pb.vcf" \
--logfile "HA2WPADXX_2.DEEPVARIANT.log.txt" \
--num-streams-per-gpu 4 \
--run-partition \
--verbose --x3 \
--num-gpus 4
Thanks in advance.
