MIT License
Copyright (c) 2018 NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#include "gstyoloplugin.h"
#include <fstream>
#include <iostream>
#include <stdexcept>
#include <npp.h>
#include <ostream>
#include <sstream>
#include <string.h>
#include <string>
#include <sys/time.h>
#include <stdio.h>
#include <execinfo.h>
#include <signal.h>
#include <stdlib.h>
#include <unistd.h>
#include <glib.h>
//#include <Python.h>
#include <gst/gst.h>
//#include "/home/test/Documents/deepstream/deepstream_reference_apps/yolo/plugins/gst-yoloplugin-tesla/gstyoloplugin.h"
#include "gstnvdsmeta.h"
#include <tuple>
#include <iostream>
/* As defined in the yolo plugins header*/
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
//#include </usr/include/boost/python.hpp>
#define YOLO_UNIQUE_ID 15
gint frame_number = 0;
/* osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and get a count of objects of interest */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstMeta *gst_meta = NULL;
NvDsMeta *nvdsmeta = NULL;
gpointer state = NULL;
static GQuark _nvdsmeta_quark = 0;
GstBuffer *buf = (GstBuffer *) info->data;
NvDsFrameMeta *frame_meta = NULL;
guint num_rects = 0, rect_index = 0;
NvDsObjectParams *obj_meta = NULL;
guint car_count = 0;
guint person_count = 0;
guint bicycle_count = 0;
guint truck_count = 0;
if (!_nvdsmeta_quark)
_nvdsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
while ((gst_meta = gst_buffer_iterate_meta (buf, &state))) {
if (gst_meta_api_type_has_tag (gst_meta->info->api, _nvdsmeta_quark)) {
nvdsmeta = (NvDsMeta *) gst_meta;
/* We are interested only in intercepting Meta of type
* "NVDS_META_FRAME_INFO" as they are from our infer elements. */
if (nvdsmeta->meta_type == NVDS_META_FRAME_INFO) {
frame_meta = (NvDsFrameMeta *) nvdsmeta->meta_data;
if (frame_meta == NULL) {
g_print ("NvDS Meta contained NULL meta \n");
return GST_PAD_PROBE_OK;
num_rects = frame_meta->num_rects;
/* This means we have num_rects in frame_meta->obj_params.
* Now lets iterate through them and count the number of cars,
* trucks, persons and bicycles in each frame */
for (rect_index = 0; rect_index < num_rects; rect_index++) {
obj_meta = (NvDsObjectParams *) & frame_meta->obj_params[rect_index];
if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
"car"))
car_count++;
else if (!g_strcmp0 (obj_meta->attr_info[YOLO_UNIQUE_ID].attr_label,
"person"))
person_count++;
"bicycle"))
bicycle_count++;
"truck"))
truck_count++;
g_print ("Frame Number = %d Number of objects = %d "
"Car Count = %d Person Count = %d "
"Bicycle Count = %d Truck Count = %d \n",
frame_number, num_rects, car_count, person_count, bicycle_count,
truck_count);
//gst_helperd::cout<<t<<l<<wd<<ht;
//gst_helperd::cout<<muldeep;
frame_number++;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n", GST_OBJECT_NAME (msg->src),
error->message);
g_free (debug);
g_printerr ("Error: %s\n", error->message);
g_error_free (error);
break;
default:
break;
return TRUE;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL, *decoder =
NULL, *sink = NULL, *nvvidconv = NULL, *nvosd = NULL, *filter1 =
NULL, *filter2 = NULL, *yolo = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstCaps *caps1 = NULL, *caps2 = NULL;
gulong osd_probe_id = 0;
GstPad *osd_sink_pad = NULL;
/* Check input arguments */
if (argc != 4) {
g_printerr
("Usage: %s <Platform-Telsa/Tegra> <H264 filename> <yolo-plugin config file> \n",
argv[0]);
return -1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("ds-yolo-pipeline");
/* Source element for reading from the file */
source = gst_element_factory_make ("filesrc", "file-source");
/* Since the data format in the input file is elementary h264 stream,
* we need a h264parser */
h264parser = gst_element_factory_make ("h264parse", "h264-parser");
/* Use nvdec_h264/omxh264dec for hardware accelerated decode on GPU */
if (!g_strcmp0 ("Tesla", argv[1])) {
decoder = gst_element_factory_make ("nvdec_h264", "nvh264-decoder");
} else if (!g_strcmp0 ("Tegra", argv[1])) {
decoder = gst_element_factory_make ("omxh264dec", "openmax-decoder");
} else {
g_printerr ("Incorrect platform. Choose between Telsa/Tegra. Exiting.\n");
return -1;
/* Use convertor to convert from NV12 to RGBA as required by nvosd and yolo plugins */
nvvidconv = gst_element_factory_make ("nvvidconv", "nvvideo-converter");
/* Use yolo to run inference instead of pgie */
yolo = gst_element_factory_make ("nvyolo", "yolo-inference-engine");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvosd", "nv-onscreendisplay");
/* Finally render the osd output */
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
sink = gst_element_factory_make ("nvoverlaysink", "nvvideo-renderer");
} else {
return -1;
/* caps filter for nvvidconv to convert NV12 to RGBA as nvosd expects input
* in RGBA format */
filter1 = gst_element_factory_make ("capsfilter", "filter1");
filter2 = gst_element_factory_make ("capsfilter", "filter2");
if (!pipeline || !source || !h264parser || !decoder || !filter1 || !nvvidconv
|| !filter2 || !nvosd || !sink || !yolo) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
/* we set the input filename to the source element */
g_object_set (G_OBJECT (source), "location", argv[2], NULL);
g_object_set (G_OBJECT (yolo), "config-file-path", argv[3], NULL);
/* we set the osd properties here */
g_object_set (G_OBJECT (nvosd), "font-size", 15, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), source, h264parser, decoder, filter1,
nvvidconv, filter2, yolo, nvosd, sink, NULL);
caps1 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12");
g_object_set (G_OBJECT (filter1), "caps", caps1, NULL);
gst_caps_unref (caps1);
caps2 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=RGBA");
g_object_set (G_OBJECT (filter2), "caps", caps2, NULL);
gst_caps_unref (caps2);
/* we link the elements together */
/* file-source -> h264-parser -> nvh264-decoder ->
* filter1 -> nvvidconv -> filter2 -> yolo -> nvosd -> video-renderer */
gst_element_link_many (source, h264parser, decoder, filter1, nvvidconv,
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
if (!osd_sink_pad)
g_print ("Unable to get sink pad\n");
else
osd_probe_id = gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing: %s\n", argv[2]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
GST_DEBUG_CATEGORY_STATIC (gst_yoloplugin_debug);
#define GST_CAT_DEFAULT gst_yoloplugin_debug
static GQuark _dsmeta_quark = 0;
/* Enum to identify properties */
enum
PROP_0,
PROP_UNIQUE_ID,
PROP_PROCESSING_WIDTH,
PROP_PROCESSING_HEIGHT,
PROP_PROCESS_FULL_FRAME,
PROP_GPU_DEVICE_ID,
PROP_CONFIG_FILE_PATH
/* Default values for properties */
#define DEFAULT_UNIQUE_ID 15
#define DEFAULT_PROCESSING_WIDTH 640
#define DEFAULT_PROCESSING_HEIGHT 480
#define DEFAULT_PROCESS_FULL_FRAME TRUE
#define DEFAULT_GPU_ID 0
#define DEFAULT_CONFIG_FILE_PATH ""
#define RGB_BYTES_PER_PIXEL 3
#define RGBA_BYTES_PER_PIXEL 4
#define Y_BYTES_PER_PIXEL 1
#define UV_BYTES_PER_PIXEL 2
//cv::Mat muldeep;
//int t=NULL;
//int l=NULL;
//int wd=NULL;
//int ht=NULL;
#define CHECK_NPP_STATUS(npp_status,error_str) do { \
if ((npp_status) != NPP_SUCCESS) { \
g_print ("Error: %s in %s at line %d: NPP Error %d\n", \
error_str, __FILE__, __LINE__, npp_status); \
goto error; \
} while (0)
#define CHECK_CUDA_STATUS(cuda_status,error_str) do { \
if ((cuda_status) != cudaSuccess) { \
g_print ("Error: %s in %s at line %d (%s)\n", \
error_str, __FILE__, __LINE__, cudaGetErrorName(cuda_status)); \
goto error; \
} while (0)
/* By default NVIDIA Hardware allocated memory flows through the pipeline. We
* will be processing on this type of memory only. */
#define GST_CAPS_FEATURE_MEMORY_NVMM "memory:NVMM"
static GstStaticPadTemplate gst_yoloplugin_sink_template =
GST_STATIC_PAD_TEMPLATE ("sink", GST_PAD_SINK, GST_PAD_ALWAYS,
GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE_WITH_FEATURES
(GST_CAPS_FEATURE_MEMORY_NVMM, "{ RGBA }")));
static GstStaticPadTemplate gst_yoloplugin_src_template =
GST_STATIC_PAD_TEMPLATE ("src", GST_PAD_SRC, GST_PAD_ALWAYS,
/* Define our element type. Standard GObject/GStreamer boilerplate stuff */
#define gst_yoloplugin_parent_class parent_class
G_DEFINE_TYPE (GstYoloPlugin, gst_yoloplugin, GST_TYPE_BASE_TRANSFORM);
static void gst_yoloplugin_set_property (GObject * object, guint prop_id,
const GValue * value, GParamSpec * pspec);
static void gst_yoloplugin_get_property (GObject * object, guint prop_id,
static gboolean gst_yoloplugin_set_caps (GstBaseTransform * btrans,
GstCaps * incaps, GstCaps * outcaps);
static gboolean gst_yoloplugin_start (GstBaseTransform * btrans);
static gboolean gst_yoloplugin_stop (GstBaseTransform * btrans);
static GstFlowReturn gst_yoloplugin_transform_ip (GstBaseTransform * btrans,
GstBuffer * inbuf);
static void attach_metadata_full_frame (GstYoloPlugin * yoloplugin,
GstBuffer * inbuf, gdouble scale_ratio, YoloPluginOutput * output,
guint batch_id);
static void attach_metadata_object (GstYoloPlugin * yoloplugin,
NvDsObjectParams * obj_param, YoloPluginOutput * output);
/* Install properties, set sink and src pad capabilities, override the required
* functions of the base class, These are common to all instances of the
* element.
//std::tuple<cv::Mat,int, int, int, int> initialize()
// return std::make_tuple(muldeep, t, l, wd, ht);
static void
gst_yoloplugin_class_init (GstYoloPluginClass * klass)
GObjectClass *gobject_class;
GstElementClass *gstelement_class;
GstBaseTransformClass *gstbasetransform_class;
gobject_class = (GObjectClass *) klass;
gstelement_class = (GstElementClass *) klass;
gstbasetransform_class = (GstBaseTransformClass *) klass;
/* Overide base class functions */
gobject_class->set_property = GST_DEBUG_FUNCPTR (gst_yoloplugin_set_property);
gobject_class->get_property = GST_DEBUG_FUNCPTR (gst_yoloplugin_get_property);
gstbasetransform_class->set_caps =
GST_DEBUG_FUNCPTR (gst_yoloplugin_set_caps);
gstbasetransform_class->start = GST_DEBUG_FUNCPTR (gst_yoloplugin_start);
gstbasetransform_class->stop = GST_DEBUG_FUNCPTR (gst_yoloplugin_stop);
gstbasetransform_class->transform_ip =
GST_DEBUG_FUNCPTR (gst_yoloplugin_transform_ip);
/* Install properties */
g_object_class_install_property (gobject_class, PROP_UNIQUE_ID,
g_param_spec_uint ("unique-id", "Unique ID",
"Unique ID for the element. Can be used to identify output of the"
" element",
0, G_MAXUINT, DEFAULT_UNIQUE_ID,
(GParamFlags) (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
g_object_class_install_property (gobject_class, PROP_PROCESSING_WIDTH,
g_param_spec_int ("processing-width", "Processing Width",
"Width of the input buffer to algorithm", 1, G_MAXINT,
DEFAULT_PROCESSING_WIDTH,
g_object_class_install_property (gobject_class, PROP_PROCESSING_HEIGHT,
g_param_spec_int ("processing-height", "Processing Height",
"Height of the input buffer to algorithm", 1, G_MAXINT,
DEFAULT_PROCESSING_HEIGHT,
g_object_class_install_property (gobject_class, PROP_PROCESS_FULL_FRAME,
g_param_spec_boolean ("full-frame", "Full frame",
"Enable to process full frame or disable to process objects detected"
"by primary detector",
DEFAULT_PROCESS_FULL_FRAME,
g_object_class_install_property (gobject_class, PROP_GPU_DEVICE_ID,
g_param_spec_uint ("gpu-id", "Set GPU Device ID", "Set GPU Device ID", 0,
G_MAXUINT, 0,
GParamFlags (G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS |
GST_PARAM_MUTABLE_READY)));
g_object_class_install_property (gobject_class, PROP_CONFIG_FILE_PATH,
g_param_spec_string ("config-file-path", "Plugin config file path",
"Set plugin config file path",
DEFAULT_CONFIG_FILE_PATH,
/* Set sink and src pad capabilities */
gst_element_class_add_pad_template (gstelement_class,
gst_static_pad_template_get (&gst_yoloplugin_src_template));
gst_static_pad_template_get (&gst_yoloplugin_sink_template));
/* Set metadata describing the element */
gst_element_class_set_details_simple (gstelement_class, "NvYolo", "NvYolo",
"Process a 3rdparty example algorithm on objects / full frame", "Nvidia");
static void
gst_yoloplugin_init (GstYoloPlugin * yoloplugin)
GstBaseTransform *btrans = GST_BASE_TRANSFORM (yoloplugin);
/* We will not be generating a new buffer. Just adding / updating
* metadata. */
gst_base_transform_set_in_place (GST_BASE_TRANSFORM (btrans), TRUE);
/* We do not want to change the input caps. Set to passthrough. transform_ip
* is still called. */
gst_base_transform_set_passthrough (GST_BASE_TRANSFORM (btrans), TRUE);
/* Initialize all property variables to default values */
yoloplugin->unique_id = DEFAULT_UNIQUE_ID;
yoloplugin->processing_width = DEFAULT_PROCESSING_WIDTH;
yoloplugin->processing_height = DEFAULT_PROCESSING_HEIGHT;
yoloplugin->process_full_frame = DEFAULT_PROCESS_FULL_FRAME;
yoloplugin->gpu_id = DEFAULT_GPU_ID;
yoloplugin->config_file_path = g_strdup (DEFAULT_CONFIG_FILE_PATH);
/* This quark is required to identify NvDsMeta when iterating through
* the buffer metadatas */
if (!_dsmeta_quark)
_dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
/* Function called when a property of the element is set. Standard boilerplate.
static void
GstYoloPlugin *yoloplugin = GST_YOLOPLUGIN (object);
switch (prop_id) {
case PROP_UNIQUE_ID:
yoloplugin->unique_id = g_value_get_uint (value);
break;
case PROP_PROCESSING_WIDTH:
yoloplugin->processing_width = g_value_get_int (value);
break;
case PROP_PROCESSING_HEIGHT:
yoloplugin->processing_height = g_value_get_int (value);
break;
case PROP_PROCESS_FULL_FRAME:
yoloplugin->process_full_frame = g_value_get_boolean (value);
break;
case PROP_GPU_DEVICE_ID:
yoloplugin->gpu_id = g_value_get_uint (value);
break;
case PROP_CONFIG_FILE_PATH:
if (g_value_get_string (value)) {
g_free (yoloplugin->config_file_path);
yoloplugin->config_file_path = g_value_dup_string (value);
break;
default:
G_OBJECT_WARN_INVALID_PROPERTY_ID (object, prop_id, pspec);
break;
/* Function called when a property of the element is requested. Standard
* boilerplate.
static void
gst_yoloplugin_get_property (GObject * object, guint prop_id, GValue * value,
GParamSpec * pspec)
switch (prop_id) {
g_value_set_uint (value, yoloplugin->unique_id);
break;
g_value_set_int (value, yoloplugin->processing_width);
break;
g_value_set_int (value, yoloplugin->processing_height);
break;
g_value_set_boolean (value, yoloplugin->process_full_frame);
break;
g_value_set_uint (value, yoloplugin->gpu_id);
break;
g_value_set_string (value, yoloplugin->config_file_path);
break;
default:
break;
* Initialize all resources and start the output thread
static gboolean
GstYoloPlugin *yoloplugin = GST_YOLOPLUGIN (btrans);
YoloPluginInitParams init_params =
{ yoloplugin->processing_width, yoloplugin->processing_height,
yoloplugin->process_full_frame, yoloplugin->config_file_path
GstQuery *queryparams = NULL;
guint batch_size = 1;
if ((!yoloplugin->config_file_path)
|| (strlen (yoloplugin->config_file_path) == 0)) {
g_print ("ERROR: Yolo plugin config file path not set \n");
goto error;
yoloplugin->batch_size = 1;
queryparams = gst_nvquery_batch_size_new ();
if (gst_pad_peer_query (GST_BASE_TRANSFORM_SINK_PAD (btrans), queryparams)
|| gst_pad_peer_query (GST_BASE_TRANSFORM_SRC_PAD (btrans), queryparams)) {
if (gst_nvquery_batch_size_parse (queryparams, &batch_size)) {
yoloplugin->batch_size = batch_size;
GST_DEBUG_OBJECT (yoloplugin, "Setting batch-size %d \n",
yoloplugin->batch_size);
gst_query_unref (queryparams);
/* Algorithm specific initializations and resource allocation. */
yoloplugin->yolopluginlib_ctx =
YoloPluginCtxInit (&init_params, yoloplugin->batch_size);
g_assert (yoloplugin->yolopluginlib_ctx
&& "Unable to create yolo plugin lib ctx \n ");
GST_DEBUG_OBJECT (yoloplugin, "ctx lib %p \n", yoloplugin->yolopluginlib_ctx);
CHECK_CUDA_STATUS (cudaSetDevice (yoloplugin->gpu_id),
"Unable to set cuda device");
cudaStreamCreate (&yoloplugin->npp_stream);
// Create host memory for conversion/scaling
CHECK_CUDA_STATUS (cudaMallocHost (&yoloplugin->hconv_buf,
yoloplugin->processing_width * yoloplugin->processing_height *
RGBA_BYTES_PER_PIXEL), "Could not allocate cuda host buffer");
GST_DEBUG_OBJECT (yoloplugin, "allocated cuda buffer %p \n",
yoloplugin->hconv_buf);
yoloplugin->cvmats =
std::vector < cv::Mat * >(yoloplugin->batch_size, nullptr);
for (uint k = 0; k < batch_size; ++k) {
yoloplugin->cvmats.at (k) =
new cv::Mat (cv::Size (yoloplugin->processing_width,
yoloplugin->processing_height), CV_8UC3);
if (!yoloplugin->cvmats.at (k))
goto error;
GST_DEBUG_OBJECT (yoloplugin, "created CV Mat\n");
return TRUE;
error:
if (yoloplugin->hconv_buf) {
cudaFreeHost (yoloplugin->hconv_buf);
yoloplugin->hconv_buf = NULL;
if (yoloplugin->npp_stream) {
cudaStreamDestroy (yoloplugin->npp_stream);
yoloplugin->npp_stream = NULL;
if (yoloplugin->yolopluginlib_ctx)
YoloPluginCtxDeinit (yoloplugin->yolopluginlib_ctx);
return FALSE;
* Stop the output thread and free up all the resources
static gboolean
GST_DEBUG_OBJECT (yoloplugin, "Freed cuda host buffer \n");
for (uint i = 0; i < yoloplugin->batch_size; ++i) {
delete yoloplugin->cvmats.at (i);
GST_DEBUG_OBJECT (yoloplugin, "deleted CV Mat \n");
// Deinit the algorithm library
GST_DEBUG_OBJECT (yoloplugin, "ctx lib released \n");
return TRUE;
* Called when source / sink pad capabilities have been negotiated.
static gboolean
gst_yoloplugin_set_caps (GstBaseTransform * btrans, GstCaps * incaps,
GstCaps * outcaps)
/* Save the input video information, since this will be required later. */
gst_video_info_from_caps (&yoloplugin->video_info, incaps);
return TRUE;
error:
return FALSE;
* Scale the entire frame to the processing resolution maintaining aspect ratio.
* Or crop and scale objects to the processing resolution maintaining the aspect
* ratio. Remove the padding requried by hardware and convert from RGBA to RGB
* using openCV. These steps can be skipped if the algorithm can work with
* padded data and/or can work with RGBA.
get_converted_mat_dgpu (GstYoloPlugin * yoloplugin, void *input_buf,
NvOSD_RectParams * crop_rect_params, cv::Mat & out_mat,
gdouble & ratio, gint input_width, gint input_height)
//std::cout<< out_mat;
//cv::imwrite("/home/test/a.jpg", out_mat);
cv::Mat in_mat;
//muldeep = out_mat;
gint src_left = (crop_rect_params->left);
gint src_top = (crop_rect_params->top);
gint src_width = (crop_rect_params->width);
gint src_height = (crop_rect_params->height);
// size of source
NppiSize oSrcSize = { input_width, input_height };
// source ROI
NppiRect oSrcROI =
{ (gint) 0, (gint) 0, (gint) src_width, (gint) src_height };
// Destination ROI
NppiRect DstROI = { 0, 0, (gint) yoloplugin->processing_width,
(gint) yoloplugin->processing_height
GST_DEBUG_OBJECT (yoloplugin, "Scaling and converting input buffer\n");
// Calculate scaling ratio while maintaining aspect ratio
ratio = MIN (1.0 * yoloplugin->processing_width / crop_rect_params->width,
1.0 * yoloplugin->processing_height / crop_rect_params->height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
return GST_FLOW_ERROR;
// Memset the memory
CHECK_CUDA_STATUS (cudaMemset (yoloplugin->hconv_buf, 0,
yoloplugin->processing_width * RGBA_BYTES_PER_PIXEL *
yoloplugin->processing_height), "Failed to memset cuda buffer");
nppSetStream (yoloplugin->npp_stream);
// Perform cropping and resizing
CHECK_NPP_STATUS (nppiResizeSqrPixel_8u_C4R (
(const Npp8u *) input_buf + (src_left +
src_top * input_width) * RGBA_BYTES_PER_PIXEL, oSrcSize,
input_width * RGBA_BYTES_PER_PIXEL, oSrcROI,
(Npp8u *) yoloplugin->hconv_buf,
yoloplugin->processing_width * RGBA_BYTES_PER_PIXEL, DstROI, ratio,
ratio, 0, 0, NPPI_INTER_LINEAR), "Failed to scale RGBA frame");
CHECK_CUDA_STATUS (cudaStreamSynchronize (yoloplugin->npp_stream),
"Failed to synchronize cuda stream");
// Use openCV to remove padding and convert RGBA to RGB. Can be skipped if
// algorithm can handle padded RGBA data.
in_mat =
cv::Mat (yoloplugin->processing_height, yoloplugin->processing_width,
CV_8UC4, yoloplugin->hconv_buf,
yoloplugin->processing_width * RGBA_BYTES_PER_PIXEL);
cv::cvtColor (in_mat, out_mat, CV_RGBA2BGR);
return GST_FLOW_OK;
error:
* Called when element recieves an input buffer from upstream element.
gst_yoloplugin_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
GstMapInfo in_map_info;
GstFlowReturn flow_ret = GST_FLOW_OK;
gdouble scale_ratio;
std::vector < YoloPluginOutput * >outputs (yoloplugin->batch_size, nullptr);
NvBufSurface *surface = NULL;
guint batch_size = yoloplugin->batch_size;
GstNvStreamMeta *streamMeta = NULL;
cv::Mat in_mat;
yoloplugin->frame_num++;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
surface = (NvBufSurface *) in_map_info.data;
"Processing Frame %" G_GUINT64_FORMAT " Surface %p\n",
yoloplugin->frame_num, surface);
if (CHECK_NVDS_MEMORY_AND_GPUID (yoloplugin, surface))
goto error;
/* Stream meta for batched mode */
streamMeta = gst_buffer_get_nvstream_meta (inbuf);
if (streamMeta) {
batch_size = MIN (streamMeta->num_filled, batch_size);
if (yoloplugin->process_full_frame) {
for (guint i = 0; i < batch_size; i++) {
NvOSD_RectParams rect_params;
// Scale the entire frame to processing resolution
rect_params.left = 0;
rect_params.top = 0;
rect_params.width = yoloplugin->video_info.width;
rect_params.height = yoloplugin->video_info.height;
// Scale and convert the frame
if (get_converted_mat_dgpu (yoloplugin, surface->buf_data[i],
&rect_params, *yoloplugin->cvmats.at (i), scale_ratio,
yoloplugin->video_info.width, yoloplugin->video_info.height)
!= GST_FLOW_OK) {
goto error;
// Process to get the outputs
outputs =
YoloPluginProcess (yoloplugin->yolopluginlib_ctx, yoloplugin->cvmats);
for (uint k = 0; k < outputs.size (); ++k) {
if (!outputs.at (k))
continue;
// Attach the metadata for the full frame
attach_metadata_full_frame (yoloplugin, inbuf, scale_ratio,
outputs.at (k), k);
free (outputs.at (k));
} else {
// Using object crops as input to the algorithm. The objects are detected by
// the primary detector
GstMeta *gst_meta;
NvDsMeta *dsmeta;
// NOTE: Initializing state to NULL is essential
NvDsFrameMeta *bbparams;
// Standard way of iterating through buffer metadata
while ((gst_meta = gst_buffer_iterate_meta (inbuf, &state)) != NULL) {
// Check if this metadata is of NvDsMeta type
if (!gst_meta_api_type_has_tag (gst_meta->info->api, _dsmeta_quark))
continue;
// Check if the metadata of NvDsMeta contains object bounding boxes
if (dsmeta->meta_type != NVDS_META_FRAME_INFO)
continue;
bbparams = (NvDsFrameMeta *) dsmeta->meta_data;
// Check if these parameters have been set by the primary detector /
// tracker
if (bbparams->gie_type != 1) {
continue;
// Iterate through all the objects
for (guint i = 0; i < bbparams->num_rects; i++) {
NvDsObjectParams *obj_param = &bbparams->obj_params[i];
// Crop and scale the object
surface->buf_data[bbparams->batch_id], &obj_param->rect_params,
!= GST_FLOW_OK) {
continue;
if (!obj_param->text_params.display_text) {
bbparams->num_strings++;
// Process the object crop to obtain label
outputs =
continue;
NvDsObjectParams *obj_param = &bbparams->obj_params[k];
// Attach labels for the object
attach_metadata_object (yoloplugin, obj_param, outputs.at (k));
error:
gst_buffer_unmap (inbuf, &in_map_info);
return flow_ret;
* Free the metadata allocated in attach_metadata_full_frame
static void
free_ds_meta (gpointer meta_data)
NvDsFrameMeta *params = (NvDsFrameMeta *) meta_data;
for (guint i = 0; i < params->num_rects; i++) {
g_free (params->obj_params[i].text_params.display_text);
g_free (params->obj_params);
g_free (params);
//void handler(int sig) {
// void *array[10];
// size_t size;
// // get void*'s for all entries on the stack
// size = backtrace(array, 10);
// // print out all the frames to stderr
// fprintf(stderr, "Error: signal %d:\n", sig);
// backtrace_symbols_fd(array, size, STDERR_FILENO);
// exit(1);
//void baz() {
// int *foo = (int*)-1; // make a bad pointer
// printf("%d\n", *foo); // causes segfault
//void bar() { baz(); }
//void foo() { bar(); }
* Attach metadata for the full frame. We will be adding a new metadata.
static void
attach_metadata_full_frame (GstYoloPlugin * yoloplugin, GstBuffer * inbuf,
gdouble scale_ratio, YoloPluginOutput * output, guint batch_id)
NvDsMeta *dsmeta;
NvDsFrameMeta *bbparams =
(NvDsFrameMeta *) g_malloc0 (sizeof (NvDsFrameMeta));
// Allocate an array of size equal to the number of objects detected
(NvDsObjectParams *) g_malloc0 (sizeof (NvDsObjectParams) *
output->numObjects);
// Should be set to 3 for custom elements
bbparams->gie_type = 3;
// Use HW for overlaying boxes
bbparams->nvosd_mode = NV_OSD_MODE_GPU;
bbparams->batch_id = batch_id;
// Font to be used for label text
static gchar font_name[] = "Arial";
GST_DEBUG_OBJECT (yoloplugin, "Attaching metadata %d\n", output->numObjects);
for (gint i = 0; i < output->numObjects; i++) {
YoloPluginObject *obj = &output->object[i];
NvOSD_RectParams & rect_params = obj_param->rect_params;
NvOSD_TextParams & text_params = obj_param->text_params;
// Assign bounding box coordinates
rect_params.left = obj->left;
rect_params.top = obj->top;
rect_params.width = obj->width;
rect_params.height = obj->height;
// Semi-transparent yellow background
rect_params.has_bg_color = 0;
rect_params.bg_color = (NvOSD_ColorParams) {
1, 1, 0, 0.4};
// Red border of width 6
rect_params.border_width = 1;
rect_params.border_color = (NvOSD_ColorParams) {
1, 0, 0, 1};
// Scale the bounding boxes proportionally based on how the object/frame was
// scaled during input
rect_params.left /= scale_ratio;
rect_params.top /= scale_ratio;
rect_params.width /= scale_ratio;
rect_params.height /= scale_ratio;
//std::cout<<rect_params.left<<"left\n";
//l = rect_params.left;
//std::cout<<rect_params.top<<"top\n";
//t = rect_params.top;
//std::cout<<rect_params.width<<"wid\n";
//wd = rect_params.width;
//ht = rect_params.height;
//signal(SIGSEGV, handler); // install our handler
//foo(); // this will call foo, bar, and baz. baz segfaults.
"Attaching rect%d of batch%u"
" left->%u top->%u width->%u"
" height->%u label->%s\n",
i, batch_id, rect_params.left, rect_params.top, rect_params.width,
rect_params.height, obj->label);
bbparams->num_rects++;
// has_new_info should be set to TRUE whenever adding new/updating
// information to NvDsAttrInfo
obj_param->has_new_info = TRUE;
// Update the approriate element of the attr_info array. Application knows
// that output of this element is available at index "unique_id".
strcpy (obj_param->attr_info[yoloplugin->unique_id].attr_label, obj->label);
// is_attr_label should be set to TRUE indicating that above attr_label field is
// valid
obj_param->attr_info[yoloplugin->unique_id].is_attr_label = 1;
// Obj not yet tracked
obj_param->tracking_id = -1;
// display_text required heap allocated memory
text_params.display_text = g_strdup (obj->label);
// Display text above the left top corner of the object
text_params.x_offset = rect_params.left;
text_params.y_offset = rect_params.top - 10;
// Set black background for the text
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams) {
0, 0, 0, 1};
// Font face, size and color
text_params.font_params.font_name = font_name;
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams) {
1, 1, 1, 1};
// Attach the NvDsFrameMeta structure as NvDsMeta to the buffer. Pass the
// function to be called when freeing the meta_data
dsmeta = gst_buffer_add_nvds_meta (inbuf, bbparams, free_ds_meta);
dsmeta->meta_type = NVDS_META_FRAME_INFO;
* Only update string label in an existing object metadata. No bounding boxes.
* We assume only one label per object is generated
static void
if (output->numObjects == 0)
return;
output->object[0].label);
// valid
if (text_params.display_text) {
gchar *conc_string
= g_strconcat (text_params.display_text, " ", output->object[0].label,
NULL);
g_free (text_params.display_text);
text_params.display_text = conc_string;
} else {
text_params.display_text = g_strdup (output->object[0].label);
text_params.font_params.font_name = "Arial";
1, 1, 1, 1};
0, 0, 0, 1};
* Boiler plate for registering a plugin and an element.
static gboolean
yoloplugin_plugin_init (GstPlugin * plugin)
GST_DEBUG_CATEGORY_INIT (gst_yoloplugin_debug, "yolo", 0, "yolo plugin");
return gst_element_register (plugin, "nvyolo", GST_RANK_PRIMARY,
GST_TYPE_YOLOPLUGIN);
GST_PLUGIN_DEFINE (GST_VERSION_MAJOR, GST_VERSION_MINOR, yoloplugin,
DESCRIPTION, yoloplugin_plugin_init, VERSION, LICENSE, BINARY_PACKAGE, URL)
This is my current gstyoloplugin.cpp code. I got the build commands from running make -n and instead of creating an so, created an executable. When I run the executable I get the following error that has been mentioned above.
