ERROR: something wrong with flag 'network_type' in yolo_config_parser.cpp One possibility: file 'deepstream/deepstream_reference_apps/yolo/lib/yolo_config_parser.cpp
For Tx2, I assume you want to save the output video to a file. To do that, please change the sink type here to type=5
and also provide a path to the output file in the same config group. “output-file=out.mp4”
I would also suggest you to wait for DS4.0 release since currently tx2 is running on DS 1.5
Hi @NvCJR,
I want to recompile deep stream1.5 SDK on TX2 ,but there was a error “usr/bin/ld: cannot find -lnvid_mapper” , do you know how to install lnvid_mapper?
thanks
Please create a new post with more information regarding your setup/issues and someone from Nvidia will respond.
I have solved this problem lnvid_mapper,thanks
Dear supporter,
This question have confused me several days . I want to get the image data from GstBuffer after recognized. I have reference the function of gst_yoloplugin_transform_ip() and get_converted_mat().
My plotform is on TX2 deepstream 1.5 ,using gst-yoloplugin-tegra.
I added below code at the last function of attach_metadata_full_frame.
The recognized bbox have attached to GstBuffer(inbuf) by function gst_buffer_add_iva_meta_full,right?
It will have Segmentation fault error using below code,can you give me some suggeations for it.
[code][/dsmeta = gst_buffer_add_nvds_meta (inbuf, bbparams, free_ds_meta);
dsmeta->meta_type = NVDS_META_FRAME_INFO;
//my code below*
static gint coun=0;
gchar file[100];
cv::Mat save_in_mat,save_out_mat;
gpointer state = NULL;
GstMeta *gst_meta = NULL;
NvBufferParams buf_params;
GstMapInfo in_map_info;
int in_dmabuf_fd = 0;
gpointer mapped_ptr = NULL;
GstFlowReturn flow_ret = GST_FLOW_OK;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
flow_ret = GST_FLOW_ERROR;
goto done;
if (ExtractFdFromNvBuffer (in_map_info.data, &in_dmabuf_fd)) {
  goto done;
for (guint i = 0; i < batch_size; i++) {
  if (NvBufferGetParams (in_dmabuf_fd, &buf_params) != 0) {
    goto done;
	//NvBufferGetParams (in_dmabuf_fd, &buf_params);
	if (NvBufferMemMap(in_dmabuf_fd, 0, NvBufferMem_Read,&mapped_ptr) != 0) {
goto done;
	coun=coun+1;
	sprintf(file,"%u.jpg",coun);
	//cv::imwrite(file, batchBlob);
	//GstBuffer *buf = (GstBuffer *) inbuf->data;
	GstMapInfo map;
	//gst_buffer_map (inbuf, &map, GST_MAP_READ);
	gint width=1280;
	gint height=720;
	save_in_mat=cv::Mat (width, height, CV_8UC4, mapped_ptr, buf_params.pitch[0]);//cv::Mat::AUTO_STEP
	cv::cvtColor (save_in_mat, save_out_mat, CV_BGRA2BGR);
	cv::imwrite(file, save_out_mat);
done:
  if (mapped_ptr){
    NvBufferMemUnMap (in_dmabuf_fd, 0, &mapped_ptr);
  if (in_dmabuf_fd){
	NvReleaseFd (in_dmabuf_fd);
  gst_buffer_unmap (inbuf, &in_map_info);
  std::cout << "debug save image " <<":done end!"<< std::endl;
 //return flow_ret;
code]
code
//*****my code below******
	static gint coun=0;
	gchar file[100];
    goto done;
	  goto done;
	    goto done;
    goto done;
		coun=coun+1;
		GstMapInfo map;
		gint width=1280;
		gint height=720;
	done:
	  if (mapped_ptr){
	  if (in_dmabuf_fd){
	 //return flow_ret;
Can you please create a new post with all the information and also post a backtrace of the segfault from gdb ?
