ERROR: Unable to load the kernel module 'nvidia-modeset.ko'., Facing this error during driver installation
I am using azure vm with NC4as_T4_v3 GPU.
I have tried backlisting the follows from /etc/modprobe.d/blacklist.conf
blacklist amd76x_edac
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
blacklist mlx5_core
running sudo update-initramfs -u and restarting my vm but that hasn’t helped
How should i go about resolving this error.
Hi. Follow these steps to setup the VM and install the drivers.
https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_advanced_cloud_setup_azure.html
The drivers can be installed automatically using NVIDIA GPU Driver Extension for Linux.
Thank you, I resolved the the error by following steps from the following site -CUDA 6.5 on AWS GPU instance running Ubuntu 14.04 - Seven Story Rabbit Hole
You could follow our AWS deployment guide if you are using AWS too.
