How can we find out which containers share same base image, which wont share?
Any method to find out them.
We have 240 GB NVM M2 memory slot currently. Can I select this “NVM…” in the SDK manager instead of “eMMC” to flash my “software components”. Hope it flashs on to NVM memory only and things work fine. Please confirm.
oh ok.
Thanks for the info. So it means we can update the mounted folders from the container terminal itself and these updates will be reflected automatically in the folders in the file system outside the containers.
Basically this can be used for the working folders of the CUDA developers, where they can work inside the container terminal itself and can have access to there code/files etc of the outside file system from here itself. Pls confirm if my understanding is correct.
ok fine. Thanks for the information.
uninstalling via apt commands method, will be from the target. As there are many software components that are installed, uninstalling all of them individually through apt may not workout properly. Some dependency files might remain in some folders itself, that might have side effects with application functionalities later on.
As I will be installing many components of all related to deep learning package, can we uninstall all these fully from the SDK manager from Host PC. Just wanted to know?
Anyhow, I might be opening a new thread seperately for SDK manager installations queries soon.
You would have to look at their dockerfiles and what base images they used, I don’t think there is a way to realistically determine it. If you are so concerned about the disk space it is probably best to just pull all the containers you need and see what it actually takes.
I believe so, although I haven’t flashed the OS to NVME before (I tend to flash the OS to eMMC or SD card and use NVME for projects, data, containers, and code). If you encounter problems with flashing to NVME, I recommend you open a new topic about SDK Manager as you alluded to later in your post.
Then I suggest after your initial development, if you end up using containers and don’t need the JetPack packages installed on the device’s native filesystem (outside container), then just re-flash your device again and this time don’t have SDK Manager install them.
I was able to successfully install Nvidia-Jetpack on my device.
Later I was trying to install pytorch, in that when executing the below step, it is giving error as shown below:
Kindly let us know, how to resolve this.
root@trident-desktop:/home/trident# pip3 install Cython<3
bash: 3: No such file or directory
I am following the below steps to install as shared by you in the beginning of the thread:
Finally I was able to completely install jetpack 5.1.2 component (with the command “sudo apt-get install nvidia-jetpack”) +pytorch+ opencv built with CUDA on my Jetson Agx Xavier.
Next in case of any further queries or issue, execution of sample programs of CUDa, open cv, torch, onn, tensorrr ,etc from customer will ask here.
