I am using camera Sony convert image via LT6911 in jetson xavier NX (4.6) - L4T 32.6.1 but I have a problem and don’t know how to fix it.
The log is in the attachment. What is the reason?
or anything else should be configured, too? What is that?
Any help would be appreciated. error.txt (81.0 MB)
interesting, I don’t see errors reported by VI engine related to signaling.
for example,
there shows start-of-frame, and also end-of-frame…etc, you should already have valid stream on the CSI brick.
however, the frame-id looks odd. is it the signaling keep sending out?
one thing you should try is reset the signal on the HDMI2CSI chip before s_stream.
is your sensor device tree configure the same pixel formats as your stream?
you should able to control your HDMI2CSI chip, right? it basically a register setting for sending reset signal, you may refer to spec for details.
what is the relevant between reset the signal on the HDMI2CSI chip before s_stream and error tag:CHANSEL_NOMATCH 0x000003c9 ? Because the main reason I usually receive is 3c9?
so, is your sensor device tree configure the same pixel formats as your stream?
reset the stream is due to my previous comments, >> the frame-id looks odd.
