dear,I have a problem about the frame lost when I using TX2NX CSI interface to acquire frame in externel trigger mode.
Very occasionally, we encounter a frame lost every 10K or even more without any error.
I can find the abnorm from the timestamp。
what is your suggestion about the inconsistency between CHANSEL_LOAD_FRAMED and CHANSEL_PXL_SOF?
I have tried to maxim the CPU frequency or lower the fps,all of this doesn‘t work.
按<q>,再按<enter>退出,按其他键继续
2023-09-27 09:14:49.595600 开始一个循环
2023-09-27 09:14:49.795720 , before trigger
2023-09-27 09:14:49.800605 , after trigger
2023-09-27 09:14:49.816558 /dev/video0 read frame 1
2023-09-27 09:14:49.817736 /dev/video1 read frame 1
2023-09-27 09:14:49.825028 /dev/video0 read frame 2
2023-09-27 09:14:49.825624 /dev/video1 read frame 2
2023-09-27 09:14:49.833406 /dev/video0 read frame 3
2023-09-27 09:14:49.833980 /dev/video1 read frame 3
2023-09-27 09:14:49.841671 /dev/video0 read frame 4
2023-09-27 09:14:49.842277 /dev/video1 read frame 4
2023-09-27 09:14:49.850070 /dev/video0 read frame 5
2023-09-27 09:14:49.850651 /dev/video1 read frame 5
2023-09-27 09:14:49.858444 /dev/video0 read frame 6
2023-09-27 09:14:49.858786 /dev/video1 read frame 6
2023-09-27 09:14:49.866759 /dev/video0 read frame 7
2023-09-27 09:14:49.867361 /dev/video1 read frame 7
2023-09-27 09:14:49.875045 /dev/video0 read frame 8
2023-09-27 09:14:49.875662 /dev/video1 read frame 8
2023-09-27 09:14:49.883431 /dev/video0 read frame 9
2023-09-27 09:14:49.884026 /dev/video1 read frame 9
2023-09-27 09:14:49.891904 /dev/video0 read frame 10
2023-09-27 09:14:49.891955 /dev/video1 read frame 10
2023-09-27 09:14:49.900265 /dev/video0 read frame 11
2023-09-27 09:14:49.900425 /dev/video1 read frame 11
2023-09-27 09:14:49.908522 /dev/video0 read frame 12
2023-09-27 09:14:49.908561 /dev/video1 read frame 12
2023-09-27 09:14:49.916880 /dev/video1 read frame 13
2023-09-27 09:14:49.916926 /dev/video0 read frame 13
2023-09-27 09:14:49.925183 /dev/video0 read frame 14
2023-09-27 09:14:49.925213 /dev/video1 read frame 14
2023-09-27 09:14:49.933396 /dev/video0 read frame 15
2023-09-27 09:14:49.933977 /dev/video1 read frame 15
2023-09-27 09:14:49.941665 /dev/video0 read frame 16
2023-09-27 09:14:49.942270 /dev/video1 read frame 16
2023-09-27 09:14:49.958245 /dev/video1 read frame 17
2023-09-27 09:14:49.958349 /dev/video0 read frame 17
2023-09-27 09:14:49.966917 /dev/video0 read frame 18
2023-09-27 09:14:49.966972 /dev/video1 read frame 18
2023-09-27 09:14:49.975244 /dev/video1 read frame 19
2023-09-27 09:14:49.975283 /dev/video0 read frame 19
2023-09-27 09:14:59.982883 /dev/video0 select timeout
2023-09-27 09:14:59.985358 /dev/video1 select timeout
2023-09-27 09:15:39.808101 Timeout reached!
2023-09-27 09:15:39.808173 不满足条件,return 19, 19
terminate called without an active exception
Aborted (core dumped)
ubuntu@localhost:~/camera_nvidia_v5_platform/projector/build/samples$
94000.txt (10.8 MB)
2.log (2.4 MB)
