hi
I am developing my own mipi camera module. In the trace log, I got
kworker/0:2-1582 [000] .... 81.228748: rtcpu_nvcsi_intr: tstamp:2957209221 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:2-1582 [000] .... 81.228749: rtcpu_nvcsi_intr: tstamp:2957209221 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
Referred from other topics, I have apply “Boost clock” from Jetson/l4t/Camera BringUp - eLinux.org
Follow instructions in How to disable ECC check
but I still get CRC error
kworker/0:2-1582 [000] … 81.170471: rtcpu_vinotify_error: tstamp:2956898506 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:2956896931 data:0x00400060
Here is a short summary from log
v4l2-ctl-8813 [002] .... 81.096223: tegra_channel_capture_setup: vnc_id 0 W 1440 H 720 fmt c4
kworker/0:2-1582 [000] .... 81.168661: rtcpu_vinotify_error: tstamp:2955572228 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2955570740 data:0x00000001
kworker/0:2-1582 [000] .... 81.168763: rtcpu_vinotify_event: tstamp:2955647894 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2955570740 data:0x00000001
kworker/0:2-1582 [000] .... 81.169209: rtcpu_vinotify_event: tstamp:2955986456 tag:FS channel:0x00 frame:1 vi_tstamp:2955958813 data:0x00000010
kworker/0:2-1582 [000] .... 81.169211: rtcpu_vinotify_event: tstamp:2955987199 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:2955958814 data:0x00000000
kworker/0:2-1582 [000] .... 81.169212: rtcpu_vinotify_event: tstamp:2955987364 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:2955965134 data:0x00000001
kworker/0:2-1582 [000] .... 81.169844: rtcpu_vinotify_error: tstamp:2956422980 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:2956421349 data:0x00400060
kworker/0:2-1582 [000] .... 81.169845: rtcpu_vinotify_event: tstamp:2956423415 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:2956419590 data:0x02cf0002
kworker/0:2-1582 [000] .... 81.169846: rtcpu_vinotify_event: tstamp:2956423558 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:2956419610 data:0x00000000
kworker/0:2-1582 [000] .... 81.169848: rtcpu_vinotify_event: tstamp:2956423855 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:2956421349 data:0x00400060
kworker/0:2-1582 [000] .... 81.169849: rtcpu_vinotify_event: tstamp:2956424013 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:2956421349 data:0x00000000
It looks like driver can get whole frame data, but not sure why it can’t transfer data in?
Please help advise,
thanks,
hal.
