To whom it may concern,
I am writing to request for help. Our team is now porting RX(tp2854) on Xavier NX, and receiving images from 4 channels by using virtual channels at the same time. However, the error occurs while we are using Video4Linux to capture video images.
The inaccurate log datas are shown below: (L4T version: R32.4.4)
a part of trace log
vi-output, tp28-7122 [003] … 1356.381807: tegra_channel_capture_frame: eof:1366.789406944
vi-output, tp28-7122 [005] … 1356.415065: tegra_channel_capture_frame: sof:0.0
vi-output, tp28-7122 [005] … 1356.415067: tegra_channel_capture_frame: eof:1366.822740512
vi-output, tp28-7122 [005] … 1356.448407: tegra_channel_capture_frame: sof:0.0
vi-output, tp28-7122 [005] … 1356.448418: tegra_channel_capture_frame: eof:1366.856074080
vi-output, tp28-7122 [005] … 1356.481754: tegra_channel_capture_frame: sof:0.0
vi-output, tp28-7122 [005] … 1356.481755: tegra_channel_capture_frame: eof:1366.889407680
vi-output, tp28-7122 [005] … 1356.515068: tegra_channel_capture_frame: sof:0.0
vi-output, tp28-7122 [005] … 1356.515069: tegra_channel_capture_frame: eof:1366.922741312
vi-output, tp28-7122 [005] … 1356.515088: tegra_channel_capture_frame: sof:1366.890775744
vi-output, tp28-7122 [005] … 1356.515089: tegra_channel_capture_frame: eof:1366.922741344
vi-output, tp28-7122 [003] … 1356.548440: tegra_channel_capture_frame: sof:0.0
vi-output, tp28-7122 [003] … 1356.548449: tegra_channel_capture_frame: eof:1366.956074912 -
a part of trace log
kworker/0:1-722 [000] … 1356.574788: rtcpu_nvcsi_intr: tstamp:42717754882 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574788: rtcpu_nvcsi_intr: tstamp:42717756519 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574789: rtcpu_nvcsi_intr: tstamp:42717756519 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574790: rtcpu_nvcsi_intr: tstamp:42717758151 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574791: rtcpu_nvcsi_intr: tstamp:42717759610 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717759610 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717761241 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717761241 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717761241 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717761241 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574792: rtcpu_nvcsi_intr: tstamp:42717761241 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717761241 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717761241 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717761241 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717762867 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717762867 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717762867 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574793: rtcpu_nvcsi_intr: tstamp:42717762867 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717762867 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717762867 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717764152 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717764152 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717764152 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717764152 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574794: rtcpu_nvcsi_intr: tstamp:42717764152 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717764152 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717764152 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717764152 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717765785 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717765785 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717765785 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574795: rtcpu_nvcsi_intr: tstamp:42717765785 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717765785 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717765785 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717765785 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717767247 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717767247 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717767247 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574796: rtcpu_nvcsi_intr: tstamp:42717767247 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717767247 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717767247 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717767247 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717768706 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717768706 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717768706 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574797: rtcpu_nvcsi_intr: tstamp:42717768706 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717768706 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717768706 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717768706 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717770160 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717770160 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717770160 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574798: rtcpu_nvcsi_intr: tstamp:42717770160 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717770160 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717770160 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717770160 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717771620 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717771620 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717771620 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574799: rtcpu_nvcsi_intr: tstamp:42717771620 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717771620 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717771620 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717771620 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717771620 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717773254 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717773254 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574800: rtcpu_nvcsi_intr: tstamp:42717773254 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717773254 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717773254 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717773254 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717773254 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717774716 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574801: rtcpu_nvcsi_intr: tstamp:42717774716 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717774716 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574802: rtcpu_nvcsi_intr: tstamp:42717776346 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717776346 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574803: rtcpu_nvcsi_intr: tstamp:42717777854 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:2 status:0x00000004
kworker/0:1-722 [000] … 1356.574804: rtcpu_nvcsi_intr: tstamp:42717777854 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:3 status:0x00000004
Please assist us with this situation, we will be grateful for any help you can provide.
Best regards,
HS Allison
