We have a NX carrier board with two csi devices and NX previewed failed.
The device stream are from RX(TP2854).
However, the same carrier board with Nano module works well.
Plus, if set descr->status.status = CAPTURE_STATUS_SUCCESS always, NX previews ok.
( see the modified below – with added 2-24-2021) modifiedsrc.docx (16.8 KB)
Thank you for your prompt support.
Yes. Vendor just said senor did not send ECC package.
We are looking for a proper way to disable ECC check.
If TX2 can be disabled ECC check like below, can NX be disabled like this? ecc_error_tx2_p.docx (15.0 KB)
