Tegra194-vi5 15c10000.vi: corr_err: discarding frame 128, flags: 6, err_data 512
When capturing from my MIPI camera, the following error is displayed. What does this error indicate?
[  375.462221] tegra194-vi5 15c10000.vi: corr_err: discarding frame 128, flags: 6, err_data 512
[  375.490694] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[  375.505805] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  375.525085] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  375.565865] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583520
[  375.586653] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.607389] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  375.629489] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.649237] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.669193] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.690692] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.734850] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  375.753043] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160
[  375.795456] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583520
[  375.836580] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  375.857432] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160
[  375.877652] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.918882] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 102, err_data 12583008
[  375.919303] tegra194-vi5 15c10000.vi: corr_err: discarding frame 133, flags: 0, err_data 512
[  375.939161] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  375.940057] tegra194-vi5 15c10000.vi: corr_err: discarding frame 135, flags: 0, err_data 512
[  376.001559] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583520
[  376.022409] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008
[  376.023258] tegra194-vi5 15c10000.vi: corr_err: discarding frame 139, flags: 0, err_data 512
[  376.084718] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  376.085566] tegra194-vi5 15c10000.vi: corr_err: discarding frame 142, flags: 0, err_data 512
[  376.105387] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  376.126537] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  376.127195] tegra194-vi5 15c10000.vi: corr_err: discarding frame 144, flags: 0, err_data 512
[  376.189360] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  376.190133] tegra194-vi5 15c10000.vi: corr_err: discarding frame 128, flags: 0, err_data 512
[  376.230772] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583520
[  376.250948] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583520
Get the trace log to check if more information.
https://elinux.org/Jetson/l4t/Camera_BringUp#Steps_to_enable_more_debug_messages
I don’t understand this error. Please help me check where the issue is.
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
          vl_bgr-8709  [003] ....   259.297570: tegra_channel_open: vi-output, mvfpga 9-0010
          vl_bgr-8709  [003] ....   259.300005: tegra_channel_set_power: mvfpga 9-0010 : 0x1
          vl_bgr-8709  [003] ....   259.300016: camera_common_s_power: status : 0x1
          vl_bgr-8709  [003] ....   259.300077: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
          vl_bgr-8709  [003] ....   259.300081: csi_s_power: enable : 0x1
          vl_bgr-8709  [003] ....   259.353642: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 9
          vl_bgr-8709  [003] ....   259.359967: tegra_channel_set_stream: enable : 0x1
          vl_bgr-8709  [003] ....   259.362737: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
          vl_bgr-8709  [003] ....   259.362742: csi_s_stream: enable : 0x1
          vl_bgr-8709  [003] ....   259.362751: tegra_channel_set_stream: mvfpga 9-0010 : 0x1
##### CPU 0 buffer started ####
     kworker/0:2-1320  [000] ....   285.795700: rtcpu_nvcsi_intr: tstamp:9746234930 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795700: rtcpu_nvcsi_intr: tstamp:9746234930 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795700: rtcpu_nvcsi_intr: tstamp:9746234930 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795700: rtcpu_nvcsi_intr: tstamp:9746236048 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795700: rtcpu_nvcsi_intr: tstamp:9746236048 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746238217 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746238217 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746238217 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746238217 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746238217 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746239339 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746239339 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746241500 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795701: rtcpu_nvcsi_intr: tstamp:9746241500 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746241500 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746241500 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746241500 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746242627 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746242627 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746244786 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746244786 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746244786 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795702: rtcpu_nvcsi_intr: tstamp:9746244786 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746244786 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746245907 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746245907 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746248067 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746248067 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746248067 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746248067 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746248067 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795703: rtcpu_nvcsi_intr: tstamp:9746249185 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746249185 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746251353 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746251353 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746251353 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746251353 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746251353 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746252472 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746252472 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795704: rtcpu_nvcsi_intr: tstamp:9746254637 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746254637 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746254637 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746254637 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746254637 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746255761 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746255761 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746257922 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746257922 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795705: rtcpu_nvcsi_intr: tstamp:9746257922 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746257922 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746258833 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746261161 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746261161 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746261161 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/0:2-1320  [000] ....   285.795706: rtcpu_nvcsi_intr: tstamp:9746261161 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
Boost the clocks to try.
sudo jetson_clocks
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
After entering four “echo” commands, the new trace information is as follows:
#                              _-----=> irqs-off
#                            ||| /     delay
          vl_bgr-8730  [000] ....   199.008177: tegra_channel_open: vi-output, mvfpga 9-0010
          vl_bgr-8730  [000] ....   199.009519: tegra_channel_set_power: mvfpga 9-0010 : 0x1
          vl_bgr-8730  [000] ....   199.009529: camera_common_s_power: status : 0x1
          vl_bgr-8730  [000] ....   199.009580: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
          vl_bgr-8730  [000] ....   199.009582: csi_s_power: enable : 0x1
          vl_bgr-8730  [000] ....   199.055065: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 9
          vl_bgr-8730  [000] ....   199.058801: tegra_channel_set_stream: enable : 0x1
          vl_bgr-8730  [000] ....   199.060028: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
          vl_bgr-8730  [000] ....   199.060032: csi_s_stream: enable : 0x1
          vl_bgr-8730  [000] ....   199.060040: tegra_channel_set_stream: mvfpga 9-0010 : 0x1
     kworker/0:4-2132  [000] ....   199.085997: rtcpu_start: tstamp:7036169687
     kworker/0:4-2132  [000] ....   199.086002: rtcpu_string: tstamp:7036185342 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:4-2132  [000] ....   199.086023: rtcpu_string: tstamp:7036185544 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
     kworker/0:4-2132  [000] ....   199.086028: rtcpu_string: tstamp:7036185798 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
     kworker/0:4-2132  [000] ....   199.086033: rtcpu_string: tstamp:7036186042 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
     kworker/0:4-2132  [000] ....   199.086037: rtcpu_string: tstamp:7036186273 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
     kworker/0:4-2132  [000] ....   199.086064: rtcpu_string: tstamp:7036186522 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
     kworker/0:4-2132  [000] ....   199.086068: rtcpu_string: tstamp:7036186753 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
     kworker/0:4-2132  [000] ....   199.086072: rtcpu_string: tstamp:7036195522 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
     kworker/0:4-2132  [000] ....   199.086073: rtcpu_string: tstamp:7036195640 id:0x04010000 str:"on 2.2
     kworker/0:4-2132  [000] ....   199.086078: rtcpu_string: tstamp:7036212922 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
     kworker/0:4-2132  [000] ....   199.086084: rtcpu_nvcsi_intr: tstamp:7036254753 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
     kworker/0:4-2132  [000] ....   199.086086: rtcpu_vinotify_error: tstamp:7036260591 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:7036259724 data:0x00000001
     kworker/0:4-2132  [000] ....   199.086093: rtcpu_vinotify_event: tstamp:7036534535 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6115522848 data:0x10000000
     kworker/0:4-2132  [000] ....   199.086094: rtcpu_vinotify_event: tstamp:7036534678 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6115531040 data:0x31000001
     kworker/0:4-2132  [000] ....   199.086095: rtcpu_vinotify_event: tstamp:7036534837 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:6115533184 data:0x07020001
     kworker/0:4-2132  [000] ....   199.086095: rtcpu_vinotify_event: tstamp:7036534976 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6115566848 data:0x10000000
     kworker/0:4-2132  [000] ....   199.086096: rtcpu_vinotify_event: tstamp:7036535133 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6115575136 data:0x31000002
     kworker/0:4-2132  [000] ....   199.086097: rtcpu_vinotify_event: tstamp:7036535277 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:7036259724 data:0x00000001
     kworker/0:4-2132  [000] ....   199.086098: rtcpu_vinotify_event: tstamp:7036535435 tag:FS channel:0x00 frame:137 vi_tstamp:7036492544 data:0x00000010
     kworker/0:4-2132  [000] ....   199.086115: rtcpu_vinotify_event: tstamp:7036535575 tag:ATOMP_FS channel:0x00 frame:137 vi_tstamp:7036492545 data:0x00000000
     kworker/0:4-2132  [000] ....   199.086116: rtcpu_vinotify_event: tstamp:7036535732 tag:CHANSEL_PXL_SOF channel:0x23 frame:137 vi_tstamp:7036495614 data:0x00000001
     kworker/0:4-2132  [000] ....   199.086117: rtcpu_vinotify_event: tstamp:7036535865 tag:RESERVED_19 channel:0x23 frame:137 vi_tstamp:6124528672 data:0x08020001
     kworker/0:4-2132  [000] ....   199.142008: rtcpu_vinotify_event: tstamp:7038273013 tag:FE channel:0x00 frame:137 vi_tstamp:7038269103 data:0x00000020
     kworker/0:4-2132  [000] ....   199.142012: rtcpu_vinotify_event: tstamp:7038273154 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:137 vi_tstamp:7038269103 data:0x01000000
     kworker/0:4-2132  [000] ....   199.142013: rtcpu_vinotify_event: tstamp:7038273314 tag:RESERVED_19 channel:0x23 frame:137 vi_tstamp:6181283648 data:0x01020001
     kworker/0:4-2132  [000] ....   199.142014: rtcpu_vinotify_event: tstamp:7038273454 tag:ATOMP_FE channel:0x00 frame:137 vi_tstamp:7038269104 data:0x00000000
     kworker/0:4-2132  [000] ....   199.142015: rtcpu_vinotify_event: tstamp:7038273613 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:6181291904 data:0x07020002
     kworker/0:4-2132  [000] ....   199.142016: rtcpu_vinotify_event: tstamp:7038273748 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6181368192 data:0x10000000
     kworker/0:4-2132  [000] ....   199.142023: rtcpu_vinotify_event: tstamp:7038603073 tag:FS channel:0x00 frame:138 vi_tstamp:7038272087 data:0x00000010
     kworker/0:4-2132  [000] ....   199.142024: rtcpu_vinotify_event: tstamp:7038603215 tag:ATOMP_FS channel:0x00 frame:138 vi_tstamp:7038272088 data:0x00000000
     kworker/0:4-2132  [000] ....   199.142024: rtcpu_vinotify_event: tstamp:7038603375 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6181401408 data:0x31000003
     kworker/0:4-2132  [000] ....   199.142025: rtcpu_vinotify_event: tstamp:7038603511 tag:CHANSEL_PXL_SOF channel:0x23 frame:138 vi_tstamp:7038275158 data:0x00000001
     kworker/0:4-2132  [000] ....   199.142026: rtcpu_vinotify_event: tstamp:7038603666 tag:RESERVED_19 channel:0x23 frame:138 vi_tstamp:6181474016 data:0x08020002
     kworker/0:4-2132  [000] ....   199.197992: rtcpu_vinotify_event: tstamp:7040056013 tag:FE channel:0x00 frame:138 vi_tstamp:7040048646 data:0x00000020
     kworker/0:4-2132  [000] ....   199.197996: rtcpu_vinotify_event: tstamp:7040056178 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:138 vi_tstamp:7040048646 data:0x01000000
     kworker/0:4-2132  [000] ....   199.197997: rtcpu_vinotify_event: tstamp:7040056318 tag:RESERVED_19 channel:0x23 frame:138 vi_tstamp:6238229024 data:0x01020002
     kworker/0:4-2132  [000] ....   199.197998: rtcpu_vinotify_event: tstamp:7040056480 tag:ATOMP_FE channel:0x00 frame:138 vi_tstamp:7040048646 data:0x00000000
     kworker/0:4-2132  [000] ....   199.197998: rtcpu_vinotify_event: tstamp:7040056616 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:6238237344 data:0x07020003
     kworker/0:4-2132  [000] ....   199.197999: rtcpu_vinotify_event: tstamp:7040056773 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6238313280 data:0x10000000
     kworker/0:4-2132  [000] ....   199.198000: rtcpu_vinotify_event: tstamp:7040056911 tag:FS channel:0x00 frame:139 vi_tstamp:7040051631 data:0x00000010
     kworker/0:4-2132  [000] ....   199.198000: rtcpu_vinotify_event: tstamp:7040057069 tag:ATOMP_FS channel:0x00 frame:139 vi_tstamp:7040051631 data:0x00000000
     kworker/0:4-2132  [000] ....   199.198001: rtcpu_vinotify_event: tstamp:7040057203 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6238325152 data:0x31000004
This message tell the output size less than expected.
Can you determine if it’s a width issue or a height issue?
After switching to YUYV format and boosting the clock, image capture is successful. Why is it necessary to boost the clock?
You may need to increase the pix_clk_hz or serdes_pix_clk_hz in device tree to allocate more bandwidth instead of boost by the command.
