Hello
If the log is output after the problem occurs, there is no message
root@linux:~/_script/test# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
The test is as follows
#!/bin/bash
SENSOR_ID=0
COUNT=1
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
while [ true ] ; do
v4l2-ctl -d /dev/video$SENSOR_ID \
--stream-mmap \
--stream-count=$COUNT
sleep 1; echo "sleep 1"
done
In kernel dmesg, the following message is output.
[ 2698.282636] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.316101] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.349344] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.382618] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.415981] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.449354] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.482626] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.515954] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.549287] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.582616] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.615897] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.649280] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.682625] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.715954] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.749342] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.782673] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.815890] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.849293] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.882678] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.915951] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.949282] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2698.982613] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.016015] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.049277] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.082668] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.115948] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.149274] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.182607] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.216003] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.249226] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.282669] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.316002] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.349263] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.382681] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.416015] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.449233] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.482739] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.515986] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.549506] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.582619] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.615949] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.649340] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.682618] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.715959] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.749340] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.782612] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.815949] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.849385] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.882608] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.916007] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.949283] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2699.982681] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.015940] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.049296] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.082612] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.115959] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.149277] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.182618] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.215942] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.249325] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.282615] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.315947] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.349223] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.382617] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.415944] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.449272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.482733] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.516007] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.549223] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.582646] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.615996] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.649222] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.682670] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.716009] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.749275] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.782729] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.816017] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.849229] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.882674] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.915947] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.949328] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2700.982609] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.015944] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.049276] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.082603] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.115998] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.149270] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.182614] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.215943] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.249270] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.282548] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.315937] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.349325] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.382668] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.415930] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.449327] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.482673] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.515877] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.549388] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.582666] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.615933] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.649265] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.682684] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.715932] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.749215] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.782609] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.816003] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.849274] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.882642] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.916006] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.949263] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2701.982606] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.016004] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.049325] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.082603] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.115991] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.149271] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.182645] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.216000] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.249269] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.282541] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.315944] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.349334] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.382609] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.415949] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.449332] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.482628] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.515958] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.549347] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.582542] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.615879] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.649272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.682594] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.715955] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.749328] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.782599] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.815948] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.849334] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.882665] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.915923] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.949328] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2702.982661] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.015934] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.049324] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.082655] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.115937] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.149272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.182604] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.215928] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.249235] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.282603] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.316124] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.349202] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 160, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.382616] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.416002] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.449269] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.482652] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.515983] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.549270] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.582599] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.615987] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
[ 2703.649269] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160 capture_state 1 func tegra_channel_kthread_capture_dequeue
