Hi Dave,
I am developing a code and compile it on my laptop with PGI compiler. It has a DLL and executable, which just calls the DLL. It runs fine on the laptop where it is compiled. But when it runs on my PC, it gives error message:
The application was unable to start correctly (0xc00007b).
and cannot proceed further.
The PGI redistribute dlls are in the same directory as that of the executable and DLL.
You should only download and install the 64-bit packages for 64-bit Windows systems. The older 64-bit packages also had 32-bit in them, but we
have dropped the 32-bit support in all our current packages.
I enabled all intel processors in Fortran ->Target Processors in PVF and it did not work.
From your comment that “Difficult to use a DLL built on a newer version of Windows to work on an older version of Windows”, I tried to just create a single executable, without the DLL. And it works.
It does the job I want to do at the moment. So leave it for now and may need to come back when I need the DLL.
