I am trying to install opencv 3.1 on Jetson TX1 (on a SD card) using the instructions given in:
http://dev.t7.ai/jetson/opencv/ and I’m getting the following error. Also please note that I made the following modification to address a previous error while compiling(https://devtalk.nvidia.com/default/topic/1007290/jetson-tx2/building-opencv-with-opengl-support-/post/5141945/#5141945)
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.16uc1.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.8uc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.16sc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.32fc1.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.8uc4.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.16sc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_median_filter.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.16uc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_filter2d.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.32sc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.8uc3.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.32fc4.cu.o
[ 55%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.16uc4.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.16uc3.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.32fc1.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.8uc1.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.32sc4.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_column_filter.16sc1.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.16sc1.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.32fc3.cu.o
[ 56%] Building NVCC (Device) object modules/cudafilters/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_row_filter.32sc3.cu.o
Scanning dependencies of target opencv_cudafilters
[ 56%] Building CXX object modules/cudafilters/CMakeFiles/opencv_cudafilters.dir/src/filtering.cpp.o
[ 56%] Linking CXX shared library …/…/lib/libopencv_cudafilters.so
[ 56%] Built target opencv_cudafilters
Makefile:160: recipe for target ‘all’ failed
make: *** [all] Error 2
