I need to compile opencV with CUDA acceleration, using OpencV version 4.5.5, and compiled according to the following steps.
- Install nV-codec-headers SDK-10.0 and make install.
- Compile FFMPEG with nvcuvid.
- Download and install the Video Codec SDK 10.0.26, and copy libnvcuvid.so and the associated header file to /usr/local/cuda/lib64 (/include).
- Compile the opencv.
The opencV cmake compilation options used are as follows:
cmake -D WITH_CUDA=ON \
-D WITH_CUDNN=ON \
-D WITH_CUBLAS=ON \
-D CUDA_ARCH_BIN="5.3" \
-D CUDA_ARCH_PTX="" \
-D BUILD_CUDA_STUBS=ON \
-D ENABLE_FAST_MATH=ON \
-D CUDA_FAST_MATH=ON \
-D OPENCV_DNN_CUDA=ON \
-D OPENCV_ENABLE_NONFREE=ON \
-D OPENCV_EXTRA_MODULES_PATH=../opencv_contrib-4.5.5/modules \
-D WITH_GSTREAMER=ON \
-D WITH_LIBV4L=ON \
-D WITH_NVCUVID=ON \
-D BUILD_opencv_cudacodec=ON \
-D WITH_FFMPEG=ON \
-D WITH_CUFFT=ON \
-D OPENCV_GENERATE_PKGCONFIG=ON \
-D BUILD_opencv_python2=OFF \
-D BUILD_opencv_python3=ON \
-D BUILD_TESTS=OFF \
-D BUILD_PERF_TESTS=OFF \
-D BUILD_EXAMPLES=OFF \
-D CMAKE_BUILD_TYPE=RELEASE \
-D CMAKE_INSTALL_PREFIX=/usr/local \
-D CUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-10.2 \
-D CUDA_nvcuvid_LIBRARY=/usr/local/cuda-10.2/lib64/libnvcuvid.so \
../opencv-4.5.5
The following error occurred while making.
[ 55%] Building NVCC (Device) object modules/cudacodec/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_nv12_to_rgb.cu.o
[ 55%] Building CXX object modules/highgui/CMakeFiles/opencv_highgui.dir/src/backend.cpp.o
[ 55%] Building CXX object modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/cuvid_video_source.cpp.o
In file included from /opt/opencv/opencv-4.5.5/modules/core/include/opencv2/core.hpp:53:0,
from /opt/opencv/opencv-4.5.5/modules/core/include/opencv2/core/cuda.hpp:51,
from /opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/include/opencv2/cudacodec.hpp:51,
from /opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/precomp.hpp:54,
from /opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/cuvid_video_source.cpp:44:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/cuvid_video_source.cpp: In constructor ‘cv::cudacodec::detail::CuvidVideoSource::CuvidVideoSource(const String&)’:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/cuvid_video_source.cpp:71:51: warning: comparison between ‘enum cv::cudacodec::Codec’ and ‘enum cudaVideoCodec_enum’ [-Wenum-compare]
CV_Assert(Codec::NumCodecs == cudaVideoCodec::cudaVideoCodec_NumCodecs);
/opt/opencv/opencv-4.5.5/modules/core/include/opencv2/core/base.hpp:342:38: note: in definition of macro ‘CV_Assert’
#define CV_Assert( expr ) do { if(!!(expr)) ; else cv::error( cv::Error::StsAssert, #expr, CV_Func, __FILE__, __LINE__ ); } while(0)
[ 55%] Building CXX object modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/ffmpeg_video_source.cpp.o
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/ffmpeg_video_source.cpp: In function ‘int StartCodeLen(unsigned char*, int)’:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/ffmpeg_video_source.cpp:116:5: warning: no previous declaration for ‘int StartCodeLen(unsigned char*, int)’ [-Wmissing-declarations]
int StartCodeLen(unsigned char* data, const int sz) {
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/ffmpeg_video_source.cpp: In function ‘bool ParamSetsExist(unsigned char*, int, unsigned char*, int)’:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/ffmpeg_video_source.cpp:125:6: warning: no previous declaration for ‘bool ParamSetsExist(unsigned char*, int, unsigned char*, int)’ [-Wmissing-declarations]
bool ParamSetsExist(unsigned char* parameterSets, const int szParameterSets, unsigned char* data, const int szData) {
[ 55%] Building CXX object modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/frame_queue.cpp.o
[ 55%] Building CXX object modules/highgui/CMakeFiles/opencv_highgui.dir/src/window.cpp.o
[ 55%] Building CXX object modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/thread.cpp.o
[ 55%] Building CXX object modules/dnn/CMakeFiles/opencv_dnn.dir/src/op_halide.cpp.o
[ 55%] Building CXX object modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/video_decoder.cpp.o
[ 55%] Building CXX object modules/dnn/CMakeFiles/opencv_dnn.dir/src/op_inf_engine.cpp.o
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp: In member function ‘void cv::cudacodec::detail::VideoDecoder::create(const cv::cudacodec::FormatInfo&)’:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:81:29: error: ‘cudaVideoCodec_AV1’ was not declared in this scope
cudaVideoCodec_AV1 == _codec ||
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:81:29: note: suggested alternative: ‘cudaVideoCodec_NV12’
cudaVideoCodec_NV12
from /opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:44:
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:106:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
videoFormat.ulWidth <= decodeCaps.nMaxWidth &&
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:107:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
videoFormat.ulHeight <= decodeCaps.nMaxHeight);
/opt/opencv/opencv_contrib-4.5.5/modules/cudacodec/src/video_decoder.cpp:109:67: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CV_Assert((videoFormat.width >> 4)* (videoFormat.height >> 4) <= decodeCaps.nMaxMBCount);
modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/build.make:805: recipe for target 'modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/video_decoder.cpp.o' failed
make[2]: *** [modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/src/video_decoder.cpp.o] Error 1
CMakeFiles/Makefile2:4873: recipe for target 'modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/all' failed
make[1]: *** [modules/cudacodec/CMakeFiles/opencv_cudacodec.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
What is the reason for this? Please help me, thanks.
