jetson nano jp 4.6.4
l4t 32.7.1
i want to install opencv_4.1.1 with cuda
installed cuda 10.2 …tensor-rt,cudnn,… using sdkmanager
here s the jtop status
i tried to install using the following script
#!/bin/bash
# Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
version="4.1.1"
folder="workspace"
set -e
for (( ; ; ))
do
echo "Do you want to remove the default OpenCV (yes/no)?"
read rm_old
if [ "$rm_old" = "yes" ]; then
echo "** Remove other OpenCV first"
sudo apt -y purge *libopencv*
break
elif [ "$rm_old" = "no" ]; then
break
fi
done
echo "------------------------------------"
echo "** Install requirement (1/4)"
sudo apt-get update
sudo apt-get install -y build-essential cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev
sudo apt-get install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
sudo apt-get install -y python3.8-dev python-dev python-numpy python3-numpy
sudo apt-get install -y libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libdc1394-22-dev
sudo apt-get install -y libv4l-dev v4l-utils qv4l2 v4l2ucp
sudo apt-get install -y curl
echo "** Download opencv "${version}" (2/4)"
mkdir $folder
cd ${folder}
curl -L https://github.com/opencv/opencv/archive/${version}.zip -o opencv-${version}.zip
curl -L https://github.com/opencv/opencv_contrib/archive/${version}.zip -o opencv_contrib-${version}.zip
unzip opencv-${version}.zip
unzip opencv_contrib-${version}.zip
rm opencv-${version}.zip opencv_contrib-${version}.zip
cd opencv-${version}/
echo "** Build opencv "${version}" (3/4)"
mkdir release
cd release/
cmake -D WITH_CUDA=ON -D WITH_CUDNN=ON -D CUDA_ARCH_BIN="5.3" -D CUDA_ARCH_PTX="" -D OPENCV_GENERATE_PKGCONFIG=ON -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-${version}/modules -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_opencv_python3=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=OFF -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
make -j$(nproc)
echo "** Install opencv "${version}" (4/4)"
sudo make install
echo 'export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH' >> ~/.bashrc
echo 'export PYTHONPATH=/usr/local/lib/python3.8/site-packages/:$PYTHONPATH' >> ~/.bashrc
source ~/.bashrc
echo "** Install opencv "${version}" successfully"
echo "** Bye :)"
i got with an error
[ 99%] Built target opencv_stitching
Scanning dependencies of target opencv_cudaoptflow
[ 99%] Building CXX object modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/farneback.cpp.o
[ 99%] Building CXX object modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/pyrlk.cpp.o
[ 99%] Building CXX object modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/brox.cpp.o
[ 99%] Building CXX object modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/nvidiaOpticalFlow.cpp.o
[ 99%] Building CXX object modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/src/tvl1flow.cpp.o
[ 99%] Linking CXX shared library ../../lib/libopencv_cudaoptflow.so
[ 99%] Built target opencv_cudaoptflow
[ 99%] Processing OpenCL kernels (superres)
[ 99%] Building NVCC (Device) object modules/superres/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_btv_l1_gpu.cu.o
[ 99%] Building NVCC (Device) object modules/videostab/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_global_motion.cu.o
Scanning dependencies of target opencv_superres
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/btv_l1.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/frame_source.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/btv_l1_cuda.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/input_array_utility.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/optical_flow.cpp.o
Scanning dependencies of target opencv_videostab
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/deblurring.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/src/super_resolution.cpp.o
[ 99%] Building CXX object modules/superres/CMakeFiles/opencv_superres.dir/opencl_kernels_superres.cpp.o
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/fast_marching.cpp.o
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/frame_source.cpp.o
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/global_motion.cpp.o
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/inpainting.cpp.o
In file included from /home/nano/workspace/opencv_contrib-4.1.1/modules/videostab/src/global_motion.cpp:50:0:
/home/nano/workspace/opencv-4.1.1/modules/core/include/opencv2/core/private.cuda.hpp:75:0: warning: "NPP_VERSION" redefined
# define NPP_VERSION (NPP_VERSION_MAJOR * 1000 + NPP_VERSION_MINOR * 100 + NPP_VERSION_BUILD)
In file included from /home/nano/workspace/opencv-4.1.1/modules/core/include/opencv2/core/private.cuda.hpp:71:0,
/usr/local/cuda/include/npp.h:62:0: note: this is the location of the previous definition
#define NPP_VERSION (NPP_VER_MAJOR * 1000 + \
[ 99%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/log.cpp.o
[ 99%] Linking CXX shared library ../../lib/libopencv_superres.so
[100%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/motion_stabilizing.cpp.o
[100%] Built target opencv_superres
[100%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/optical_flow.cpp.o
[100%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/outlier_rejection.cpp.o
[100%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/stabilizer.cpp.o
[100%] Building CXX object modules/videostab/CMakeFiles/opencv_videostab.dir/src/wobble_suppression.cpp.o
In file included from /home/nano/workspace/opencv_contrib-4.1.1/modules/videostab/src/wobble_suppression.cpp:47:0:
[100%] Linking CXX shared library ../../lib/libopencv_videostab.so
[100%] Built target opencv_videostab
Scanning dependencies of target opencv_python3
Scanning dependencies of target opencv_python2
[100%] Building CXX object modules/python3/CMakeFiles/opencv_python3.dir/__/src2/cv2.cpp.o
[100%] Building CXX object modules/python2/CMakeFiles/opencv_python2.dir/__/src2/cv2.cpp.o
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
modules/python3/CMakeFiles/opencv_python3.dir/build.make:62: recipe for target 'modules/python3/CMakeFiles/opencv_python3.dir/__/src2/cv2.cpp.o' failed
make[2]: *** [modules/python3/CMakeFiles/opencv_python3.dir/__/src2/cv2.cpp.o] Error 4
CMakeFiles/Makefile2:10744: recipe for target 'modules/python3/CMakeFiles/opencv_python3.dir/all' failed
make[1]: *** [modules/python3/CMakeFiles/opencv_python3.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[100%] Linking CXX shared module ../../lib/cv2.so
[100%] Built target opencv_python2
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2```
how to resolve the error
