I am using the PGI 9.0 License.
I want to use pgprof for profiling.
I executed the command
pgcc -mp –Minfo=ccff myfile.c
& then executed
pgcollect ./a.out
but i am getting the error like this :
/opt/pgi/linux86/9.0-2/bin/pgsampt: error while loading shared libraries: libpgc.so: cannot open shared object file: No such file or directory
Can anybody help me out???
Hi Infosavant,
Sorry about that. This was a manufacturing error on our part where pgsampt was dynamically linked instead of statically linked. We have fixed this issue in the upcoming 9.0-3 release.
The work around is simple though. Just set your LD_LIBRARY_PATH to the location of our PGI 32-bit library directory. For example:
in csh:
setenv LD_LIBRARY_PATH /opt/pgi/linux86/9.0-2/lib:$LD_LIBRARY_PATH
In bash:
export LD_LIBRARY_PATH=/opt/pgi/linux86/9.0-2/lib:$LD_LIBRARY_PATH
Hope this helps,
Mat
Thank you.
That fixed the problem.
