Error while loading shared libraries when using deepstream-app on jetson
• Hardware Platform (Jetson / GPU) Jetson NX
• DeepStream Version 6.1 (via docker)
• JetPack Version (valid for Jetson only) L4T: R32 (release), REVISION: 6.1, JetPack 4.6
• TensorRT Version 8.4 (via DeepStream docker)
Hi, I am trying to use deepstream-app from a docker container, but it seems that some dependencies are missing.
sudo docker run --rm -it --runtime nvidia nvcr.io/nvidia/deepstream-l4t:6.1-triton bash
cd bin
ldd deepstream-app | grep "not found"
outputs:
libnvmedia_tensor.so => not found
libnvmedia_dla.so => not found
I also tried running the container with
sudo docker run --rm -it --gpus all nvcr.io/nvidia/deepstream-l4t:6.1-triton bash
but the results were the same.
Any ideas about this?
change it to --runtime=nvidia and try again.
The problem was older version of JetPack.
Solution is either to use newer JetPack, or to use older version of DeepStream container.
Btw, it seems that both --runtime nvidia and --runtime=nvidia do identical thing, I didn’t observe any difference between the two.
