I keep getting this error in VS2008:
argument of type “int *” is incompatible with parameter of type “size_t *”
all i did was follow the programming guide 2.2
my code is:
[codebox] float* d_2d;
cudaMallocPitch((void**)&d_2d, &pitch, N*sizeof(float), N);[/codebox]
thank you in advance!
I’m guessing you are referring to the following in the programming guide?
[codebox]// Host code
float* devPtr;
int pitch;
cudaMallocPitch((void**)&devPtr, &pitch, width * sizeof(float), height);
myKernel<<<100, 512>>>(devPtr, pitch);[/codebox]
It’s defined as a size_t in the reference manual:
[codebox]cudaError_t cudaMallocPitch( void** devPtr, size_t* pitch, size_t widthInBytes, size_t height)[/codebox]
Try changing int pitch to size_t pitch in your code…
I posted a message on here almost a year ago about this typo (that was when it was v2.0). Looks like they still haven’t corrected it.
oh it’s a typo? so what’s the typo? you mean the “int” part?
edit: nevermind i got it thanks guys!
