• Hardware Platform (Jetson / GPU) : nvidia A100
• DeepStream Version: 6.1
• Issue Type( questions, new requirements, bugs): Bug
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):
deepstream-app -c samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I got the docker image and run it with docker run --gpus "device=0" -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -e CUDA_CACHE_DISABLE=0 nvcr.io/nvidia/deepstream:6.1.1-triton
But when I try to run the sample app, I’m getting this errors
0:03:44.063805152 125 0x55edf6404980 ERROR v4l2allocator gstv4l2allocator.c:784:gst_v4l2_allocator_start:<sink_sub_bin_encoder2:pool:src:allocator> error requesting 2 buffers: Invalid argument
0:03:44.063827725 125 0x55edf6404980 ERROR v4l2bufferpool gstv4l2bufferpool.c:1185:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder2:pool:src> we received 0 buffer from device '/dev/v4l2-nvenc', we want at least 2
0:03:44.063835430 125 0x55edf6404980 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<sink_sub_bin_encoder2:pool:src> start failed
ERROR from sink_sub_bin_encoder2: Could not get/set settings from/on resource.
Debug info: gstv4l2object.c(3511): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin2/nvv4l2h264enc:sink_sub_bin_encoder2:
Device is in streaming mode
My config is this one:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=15
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=15
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 7=nv3dsink (Jetson only)
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
