errors doing a sudo apt-get update on new jetpack 2.3.1 install
hello, i get the following errors when i do a sudo apt-get update on a jetpack 2.3.1 install i did a week or so ago. is there anything i can do to eliminate them? thanks.
W: file:///var/cuda-repo-8-0-local/Release.gpg: Signature by key 889BEE522DA690103C4B085ED88C3D385C37D3BE uses weak digest algorithm (SHA1)
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_visionworks-repo_Release
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_visionworks-sfm-repo_Release
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_visionworks-tracking-repo_Release
Hi dkryder,
Looks like these are warnings that can be safely ignored. They will NOT block you from installing other packages.
