Platform: Win32
I am trying to install a C++ API (torch_scatter:GitHub - rusty1s/pytorch_scatter: PyTorch Extension Library of Optimized Scatter Operations). To install it I ran cmake -G “Unix Makefiles” … to generate makefiles, But I got error as follows:
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- The C compiler identification is GNU 6.3.0
-- The CXX compiler identification is GNU 6.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/MinGW/bin/gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/MinGW/bin/c++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Python3: D:/Anaconda3/envs/NewGDNv2/libs/python310.lib (found version "3.10.14") found components: Development Development.Module Development.Embed
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - not found
-- Check if compiler accepts -pthread
-- Check if compiler accepts -pthread - no
-- Found Threads: TRUE
-- Found CUDA: C:/v11.3 (found version "11.3")
-- The CUDA compiler identification is NVIDIA 11.3.58
-- Detecting CUDA compiler ABI info
-- Detecting CUDA compiler ABI info - failed
-- Check for working CUDA compiler: C:/v11.3/bin/nvcc.exe
-- Check for working CUDA compiler: C:/v11.3/bin/nvcc.exe - broken
CMake Error at C:/Program Files/CMake/share/cmake-3.28/Modules/CMakeTestCUDACompiler.cmake:59 (message):
The CUDA compiler
"C:/v11.3/bin/nvcc.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: 'G:/pytorch_scatter-2.0.9/build/CMakeFiles/CMakeScratch/TryCompile-ns435e'
Run Build Command(s): "C:/Program Files/CMake/bin/cmake.exe" -E env VERBOSE=1 C:/PROGRA~2/GnuWin32/bin/make.exe -f Makefile cmTC_1ec6f/fast
C:/PROGRA~2/GnuWin32/bin/make.exe -f CMakeFiles/cmTC_1ec6f.dir/build.make CMakeFiles/cmTC_1ec6f.dir/build
make.exe[1]: Entering directory `G:/pytorch_scatter-2.0.9/build/CMakeFiles/CMakeScratch/TryCompile-ns435e'
Building CUDA object CMakeFiles/cmTC_1ec6f.dir/main.cu.obj
C:/v11.3/bin/nvcc.exe -forward-unknown-to-host-compiler -D_WINDOWS -Xcompiler="/W3 /GR /EHsc" -Xcompiler="-MDd -Zi -Ob0 -Od /RTC1" -MD -MT CMakeFiles/cmTC_1ec6f.dir/main.cu.obj -MF CMakeFiles/cmTC_1ec6f.dir/main.cu.obj.d -x cu -c G:/pytorch_scatter-2.0.9/build/CMakeFiles/CMakeScratch/TryCompile-ns435e/main.cu -o CMakeFiles/cmTC_1ec6f.dir/main.cu.obj -Xcompiler=-FdCMakeFiles/cmTC_1ec6f.dir/,-FS
Program
c1xx: fatal error C1083: cannot open source file: “C:/Program”: No such file or directory
W3
c1xx: fatal error C1083: cannot open source file: “Files/Git/W3”: No such file or directory
main.cu
main.cu
make.exe[1]: *** [CMakeFiles/cmTC_1ec6f.dir/main.cu.obj] error 2
make.exe[1]: Leaving directory `G:/pytorch_scatter-2.0.9/build/CMakeFiles/CMakeScratch/TryCompile-ns435e'
make.exe: *** [cmTC_1ec6f/fast] error 2
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
G:/libtorch/share/cmake/Caffe2/public/cuda.cmake:41 (enable_language)
G:/libtorch/share/cmake/Caffe2/Caffe2Config.cmake:88 (include)
G:/libtorch/share/cmake/Torch/TorchConfig.cmake:68 (find_package)
CMakeLists.txt:16 (find_package)
-- Configuring incomplete, errors occurred!
