I ran the cmake on top level as you mentioned (/usr/local/driveworks/samples) . However,I got the below errors:
saq@saq-XPS:/usr/local/driveworks-0.3/samples$ cmake /usr/local/driveworks/samples .
CMake Warning at cmake/SamplesSetBuildType.cmake:19 (message):
CMAKE_BUILD_TYPE not defined. Using Release as default.
Call Stack (most recent call first):
CMakeLists.txt:9 (include)
CMake Error at /usr/local/share/cmake-3.2/Modules/CMakeDetermineSystem.cmake:175 (file):
file failed to open for writing (No such file or directory):
/usr/local/driveworks-0.3/samples/CMakeFiles/CMakeOutput.log
CMakeLists.txt:17 (project)
CMake Error: Could not open file for write in copy operation /usr/local/driveworks-0.3/samples/CMakeFiles/3.2.3/CMakeSystem.cmake.tmp
CMake Error: : System Error: No such file or directory
CMake Error at /usr/local/share/cmake-3.2/Modules/CMakeDetermineSystem.cmake:187 (configure_file):
configure_file Problem configuring file
CMake Error at /usr/local/share/cmake-3.2/Modules/CMakeDetermineCompilerId.cmake:125 (file):
file problem creating directory:
/usr/local/driveworks-0.3/samples/CMakeFiles/3.2.3/CompilerIdC
/usr/local/share/cmake-3.2/Modules/CMakeDetermineCompilerId.cmake:39 (CMAKE_DETERMINE_COMPILER_ID_BUILD)
/usr/local/share/cmake-3.2/Modules/CMakeDetermineCCompiler.cmake:108 (CMAKE_DETERMINE_COMPILER_ID)
I then run the cmake on /usr/local/driveworks/samples/src/ .
CMake Error: The source directory “/usr/local/driveworks-0.3/samples/src” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
I then copied the CmakeList.txt inside the src directory but still no luck.
saq@saq-XPS:/usr/local/driveworks-0.3/samples/src$ cmake /usr/local/driveworks/samples/src/ .
CMake Error at CMakeLists.txt:9 (include):
include could not find load file:
SamplesSetBuildType
/usr/local/driveworks-0.3/samples/src/CMakeFiles/CMakeOutput.log
Below is my directory structure:
saq@saq-XPS:/usr/local/driveworks-0.3/samples/src$ tree /usr/local/driveworks/samples
├── cmake
│ ├── ArchConfiguration.cmake
│ ├── CMakeParseArguments.cmake
│ ├── CommonConfiguration.cmake
│ ├── FindCUDA
│ │ ├── make2cmake.cmake
│ │ ├── parse_cubin.cmake
│ │ ├── run_nvcc.cmake
│ │ └── run_nvcc_deps.cmake
│ ├── FindCUDA.cmake
│ ├── FindDriveworks.cmake
│ ├── FindEGL.cmake
│ ├── FindPackageHandleStandardArgs.cmake
│ ├── FindPackageMessage.cmake
│ ├── LibFindMacros.cmake
│ ├── Samples3rdparty.cmake
│ ├── SamplesConfiguration.cmake
│ ├── SamplesInstallConfiguration.cmake
│ ├── SamplesSetBuildType.cmake
│ └── Toolchain-V4L.cmake
├── CMakeLists.txt
├── README.md
└── src
├── CMakeLists.txt
├── colorcorrection
│ ├── CMakeLists.txt
│ ├── main.cpp
│ └── README.md
├── common
│ ├── Checks.hpp
│ ├── ConsoleColor.cpp
│ ├── ConsoleColor.hpp
│ ├── CudaTimer.hpp
│ ├── DataPath.hpp.in
│ ├── GPUProgram.cpp
│ ├── GPUProgram.hpp
│ ├── Grid.cpp
│ ├── Grid.hpp
│ ├── Mat4.hpp
│ ├── MathUtils.cpp
│ ├── MathUtils.hpp
│ ├── MouseView3D.cpp
│ ├── MouseView3D.hpp
│ ├── ProfilerCUDA.cpp
│ ├── ProfilerCUDA.hpp
│ ├── ProgramArguments.cpp
│ ├── ProgramArguments.hpp
│ ├── SampleFramework.cpp
│ ├── SampleFramework.hpp
│ ├── Shader.cpp
│ ├── Shader.hpp
│ ├── StatsCounter.hpp
│ ├── VBO.cpp
│ ├── VBO.hpp
│ ├── WindowEGL.cpp
│ ├── WindowEGL.hpp
│ ├── WindowGLFW.cpp
│ ├── WindowGLFW.hpp
│ └── Window.hpp
├── dnn
│ ├── CMakeCache.txt
│ ├── CMakeFiles
│ │ ├── 3.2.3
│ │ │ ├── CMakeCCompiler.cmake
│ │ │ ├── CMakeCXXCompiler.cmake
│ │ │ ├── CMakeDetermineCompilerABI_C.bin
│ │ │ ├── CMakeDetermineCompilerABI_CXX.bin
│ │ │ ├── CMakeSystem.cmake
│ │ │ ├── CompilerIdC
│ │ │ │ ├── a.out
│ │ │ │ └── CMakeCCompilerId.c
│ │ │ └── CompilerIdCXX
│ │ │ ├── a.out
│ │ │ └── CMakeCXXCompilerId.cpp
│ │ ├── cmake.check_cache
│ │ ├── CMakeOutput.log
│ │ ├── CMakeTmp
│ │ ├── feature_tests.bin
│ │ ├── feature_tests.c
│ │ └── feature_tests.cxx
│ ├── dnn_common
│ │ ├── CMakeFiles
│ │ ├── CMakeLists.txt
│ │ ├── DNNInference.cpp
│ │ ├── DNNInference.hpp
│ │ ├── ISensorIO.hpp
│ │ ├── SensorIOCuda.cpp
│ │ ├── SensorIOCuda.hpp
│ │ ├── SensorIONvmedia.cpp
│ │ └── SensorIONvmedia.hpp
│ ├── sample_object_detector
│ │ ├── main.cpp
│ │ └── README.md
│ ├── sample_object_dwdetector
│ │ ├── main.cpp
│ │ └── README.md
│ └── sample_object_tracker
│ ├── FeatureTracker2D.cpp
│ ├── FeatureTracker2D.hpp
│ ├── main.cpp
│ └── README.md
To shorten the comment I have removed other sample folders.
