Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I am trying to use the common_if_testapp application, but every time I execute a command i get errors, for example:
nvidia@tegra-ubuntu:~$ common_if_testapp -get_fw_version
CommonIf: Receive Timeout!
Query FW Version failed: CommonIf_E_TIMEOUT
nvidia@tegra-ubuntu:~$ common_if_testapp -get_default_bootchain x1
DU_MCC_SendRecvPacket: Failed to wait for IPC read event. ret is: 0x9
Failed to get default boot chain selection for Tegra A
CommonIf_E_NOK
Is there something I need to set up first before being able to use this command?
Also, I couldn’t find the source code of the app, is it available in the docker containers?
Thanks in advance.
