Flash OrinX error
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
[@] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[@] Linux
QNX
other
Hardware Platform
[@] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[@] 1.9.3.10904
other
Host Machine Version
[@] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hello ,there are some errors when i flash DriveOS605 to my NV OrinX EB, the error log listed below. But DriveOS 606 can be flashed . Can you tell we what is going on.
21:39:12 ERROR: Flash DRIVE OS - flash: [bootburnTegra-A]: [executeShellCommand(166)] : Output: b"adb: error: failed to get feature set: device ‘8S2TQH3K000000403020’ not found\n"
21:39:12 INFO: Flash DRIVE OS - flash: [bootburnTegra-A]: [executeShellCommand(168)] : Return code: 1
21:39:12 ERROR: Flash DRIVE OS - flash: [bootburnTegra-A]: [executeShellCommand(170)] : stdout: b"adb: error: failed to get feature set: device ‘8S2TQH3K000000403020’ not found\n"
Dear @FYJ,
Could you confirm if you are using DRIVE AGX Orin Devkit?
Do you see the same errors when flashing DRIVE OS 6.0.6? If not, it is ok as we suggest to use latest version of DRIVE OS release for bug fixes and new features. FYI, we have released DRIVE OS 6.0.8.1 via NGC docker. Could you please check using it?
Please try the latest version, 6.0.8.1, available on https://developer.nvidia.com/drive/downloads.
