For h264 encode example :
After using this command :
gst-launch-1.0 videotestsrc ! ‘video/x-raw, format=(string)I420, width=(int)640, height=(int)480’ ! omxh264enc ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! qtmux ! filesink location=test.mp4 -e
or this one :
gst-launch-1.0 videotestsrc ! omxh264enc ! h264parse ! qtmux ! filesink location=test.mp4 -e
I obtain these line commands :
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is PREROLLING …
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
===== MSENC blits (mode: 1) into tiled surfaces =====
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
and a process still run till I stop it using ctrl-c and then I obtain these new line commands :
^Chandling interrupt.
Interrupt: Stopping pipeline …
EOS on shutdown enabled – Forcing EOS on the pipeline
Waiting for EOS…
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:08:46.168642568
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
