I have an ESXi 6.7 host with 2 x V100 GPUs. There is 384 GB RAM on the host. I have two VMs with vGPU profiles: grid_v100d-8c. Machine A has 16 GB RAM allocated and machine B has 256 GB RAM.
If A is running, B can be started and both operate fine. However if B is running first, A cannot start and will give the error:
The amount of graphics resource available in the parent resource pool is insufficient for the operation.
It does not make sense as there is plenty of graphics resource available and adequate RAM.
While this might not seem like a problem as both machines can be made to boot, I cannot then add any further machines without stopping the larger one. So am only able to use 16/64GB of GPU memory.
We’re currently running 460.73.02. Any advice would be greatly appreciated.
