Eth0 can't work after reboot
Hi
We are using a custom baseboard + Orin NX core board.
software version is Jetson Linux R36.3.
The issue is that occasionally after rebooting the Orin NX, it is not possible to ping eth0 from the computer. Restarting the system will restore the connection, or manually executing
ifconfig eth0 down
ifconfig eth0 up
when the issue occurs will most likely restore the connection, but sometimes it does not. I saw on the forum that there might be some bugs with r8168 driver.
Based on the issue described, I would like to ask if this is a known problem.
root@tegra-ubuntu:~# ethtool eth0
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: Unknown
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
nx_err.cap.txt (33.9 KB)
dmesg_nx.txt (70.0 KB)
please upgrade to rel-36.4.4. The r8168 driver has an upgrade in that version.
Hi WayneWWW,
Based on the problem description, can it be confirmed that the issue is related to r8168? Currently, we are unable to update to rel-36.4.4. Could you provide a patch for the r8168 driver?
Sorry that only those new release have the driver.
