Evaluating and resolving Heating issue Jetson orin nx
• Hardware Platform (Jetson / GPU) :Jerson Orin NX
• DeepStream Version :Deepstream 7.1
• JetPack Version (valid for Jetson only) Jetpack 6.2
• TensorRT Version: TensorRT 10.3.0
• Issue Type( questions, new requirements, bugs) : Benchmarking performance
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other
I am working with a Jetson Orin NX (Super SSD version) and have developed a custom streaming pipeline that will be shipped to a client. During long-duration runtime, the device consistently restarts around midnight.
After investigating the logs, I found repeated “hot surface” thermal errors, followed by an automatic restart. I also observed that:
  • The CPU, SSD, and fan area become extremely hot
  • The fan is running, but cooling seems insufficient
  • I tried switching the fan mode from quiet to cool, but the temperature is still very high
  • This test was performed in a cool environment, but the final product will be:
    • Deployed in a hot environment
    • Installed inside an enclosure, which will further increase temperature
Because of this, I am concerned about long-term stability and safety.
I would appreciate guidance on the following:
  1. Thermal Management & Monitoring
    • Recommended methods to track thermal behavior (CPU, GPU, SSD, surface temperature)
    • How to identify which component is triggering the hot surface error
  2. Power & Performance Configuration
    • Best practices for configuring to reduce CPU/GPU power consumption
    • Recommended power modes for continuous streaming workloads
    • Any Jetson-specific configurations to limit thermal throttling or peak power
  3. Cooling & Hardware Recommendations
    • Suggested heatsinks for Jetson Orin NX and SSD
    • Recommended thermal pads / thermal paste
    • Whether an SSD heatsink is required for the Super SSD version and suggested product
    • Fan recommendations or fan curve tuning options
  4. Deployment Considerations
    • Best practices for enclosure design (airflow, vents, active cooling)
    • Any NVIDIA-recommended thermal design guides for Orin NX
Any working configurations, documentation, or real-world recommendations would be extremely helpful.
Please check Jetson Orin Nano Series, Jetson Orin NX Series and Jetson AGX Orin Series — NVIDIA Jetson Linux Developer Guide to get more understanding of thermal management and workflow.
Also can refer to if want to the thermal solution: Jetson Orin NX Series Thermal Design Guide
