In the Events View, clicking on a column header sorts the listed events by the value in that column.
However, if you:
- click on one column header (to sort the events by the value in that column) and then
- click on another column header (" " ")
the events with value matches in the 2nd-selected column are not sub-sorted by the values in the 1st-selected column.
FEATURE REQUEST: Please consider changing the sorting algorithm for columns in the events view to use a stable sort, so that this sorting/subsorting is built-in and automatic, using the above procedure. Thanks!
